Hummingbird GPS Matrix 12
Used Matrix yesterday. Unit kept shutting off and had to restart several times. Today unit will not even turn on. The fuse is good. Please help.
Evidently the installer put 2 inline fuses to the power line. After more investigating I located the second fuse which was blown.
Posted on Jun 23, 2008
Sunspot on screen humminbird matrix 27 can it fix ?
No, typically with led matrix screens, it is near impossible to find someone to replace screen for cheaper than new unit. Same goes for tvs and computers, etc. Also, and not to be rude but rather if you are faced with buying another unit, do not buy Hummingbird. They are a very cheap quality for not much less money. Best bet will be either Furuno or Garmin. Good luck!
May 14, 2014 | Humminbird Matrix 12 Fishing System
Premature power down.
Check for loose or corroded power connections.
Jul 12, 2013 | Lowrance LCX-113C HD GPS Receiver
Hummingbird matrix 12 not powering on
The Power Supply just crapped out, Sorry.....
Apr 12, 2013 | Humminbird Matrix 12 Fishing System
Need navionics mmc card for humminbird matrix 67
looking for mmc gold ma card for matrix 67 hummingbird unit one with mas of east coast and bays... and one blank for down loading soft ware. thanks bobbloss@gmail.com
Sep 15, 2011 | Humminbird Navionics HotMaps Classic -...
My unit shuts off whenever it wants even with the charger plugged in. When I try to turn it on it comes on for a few seconds and shuts off again.
Is the Unit being fully charged before using it. Your Unit should have a Reset on the bottom of the GPS. Use a paper clip and press into rest hole with the Unit turned on. It will now shut off, restart the Unit. Usually this will helps with a lot of the problems. Good Luck!!
Jun 25, 2011 | Tomtom GPS
Garmin 1300 worked an hour before yesterday then I turned it off and it won't turn back on, I didn't do anything to it, it just sat on my desk. It's not the battery, I tried plugging it several times and...
I had this happen to me on one occasion with a nuvi 1300. Pressing the power button any number of times would not turn on the unit. Also, plugging in the car charger did not turn on the unit or charge it either.
I found that holding the power button for 10-15 seconds forced the unit to reboot, and it started just fine after that.
Since then, I've had an even more irritating issue, where holding the power button for 10-15 seconds would restart the unit, but it would freeze at the "loading maps." part. I ended up plugging the unit into my PC, which started it for purposes of data transfer. I then disconnected it from the PC and it restarted properly.
Try those out and see if you have any better luck.
Apr 09, 2010 | Garmin nuvi 1300 Car GPS Receiver
I have a hummingbird matrix 67 gps chartplotter fish finder. It developed a problem with the screen. The outer edges are legible, but the center is damaged. Is it worth repairing. Are there any other...
Hummingbird will refurbish that one for around 150US dollars, better then 500+ for a new one. If the screen is subjected to direct sunlight and heats up it can go out. This is why they discontinued the 67 model and replaced it with the 767.
Apr 21, 2009 | Humminbird MATRIX 67 GPS Receiver
Older HUMMINGBIRD DEPTH SOUNDER LCR-3D . WAS WORKING FINE WHEN I PUT IT AWAY, NOW WONT POWER UP. HAVE CHECKED THE INPUT POWER AND IT IS OKAY. I DO NOT SEE A FUSE IN THE UNIT. ITEM IS OLDER UNIT BUT IS...
We have an old Hummingbird Depth Sounder (Wide 100, 94 model) and it turns on but must be on test mode or smething cause we can not get it off. Does anyone know or have a manual to solve this problem. Please help.
Aug 07, 2008 | Hummingbird GPS
GPS 2200T Just Quit Today
My 2200T developed similar problem and shut down and when attempting to start it, I received “low battery message”. After getting a run around from the manufacturer (out of warranty by a month), I decided to take a look myself. This does not men that I encourage just anyone to do this and if you break the unit more seriously I am not responsible. The process is as follows:
Unscrew the back panel (six screws), gently remove it (be careful of the speaker wires attached to the PC board). You do not have to remove the back panel any further than to get access to the power outlet (where you plug in the power supply). On the inside of the unit, on top of the outlet is a thin copper plate, it is likely that it was bend up with use and lost contact with the plug. Gently bend it inwards using a small screwdriver (be careful not to break it). That should do it. Your unit should be getting the power and battery should charge now.
Feb 03, 2008 | Magellan RoadMate 2200T GPS Receiver
The gps does not boot
Use with caution: This will delete your user data on the unit.
Try a reset:
  • Hold QUIT pressed when turning unit ON (will delete waypoints, routes and tracklogs)
(This worked for me when I had a similar problem.)
You could try a master reset;
  • Hold Zoom-OUT + QUIT + NAV and power ON. Hold keys for 10-12 seconds.
  • You lose all almanac and temperature compensation tables (it
  • reconstructs itself but takes time - several hours)
  • Be patient - it will take HOURS for the unit to recover
Fair warning: I have not personally tried the master reset.
Oct 02, 2007 | Garmin GPSMAP 276C GPS Receiver
69 people viewed this question
 Grubhead
Grubhead
