Question about Cyberhome CH-DVD 300 DVD Player
Disk Scips I tried what you said about cleaning the lense but now whenever I play a DVD, it sounds like when the disc spins it sputters out and the "Stop" symbol appears on the screen.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 106 Answers
Hi. Make sure that the DVD case is assembled correctly with all the screws nice and tight (not superman tight, just enough though). When the disk is picked up by the spinning device, it also comes in contact with a round plastic on the top of the DVD lid or case that helps the spinning process. These must be aligned so a crooked or loose DVD case will prevent good contact. If this is not the case, then there is a mechanical problem that can't be easily fixed. I wold suggest getting a new one as fixing it might just be as costly.
Posted on Jun 23, 2008
"No Disk" message
Your dvd lense need cleaning .
For that buy lense cleaner disk from nearest computer shop then put that disk into cd/dvd rom then play it then it clean dust from lense then you can use it again .
But if still same issue then you need to replace your dvd lense .
Let me know if you need further assistance.
Thanks for using FixYa.
Feb 24, 2010 | Sony Bravia DAV-HDX265 Theater System
GO VIDEO UNIT
hi,
Please clean the disc lens with the lens cleaner.
Jun 30, 2008 | GoVideo Go Video DVD/VCR Combo
Dvd not spinning properly
I had the exact same problem.
There was a bad batch of spindle motors (why they didn't use brushless is any body's guess). I replaced mine and it is quite easy. I even soldered in the single-DVD player's (same basic model number, just not multi-disk) motor because I couldn't find the right part for the multi-disk model (or the single was cheaper, I forget). That was years ago and it still works great today (I didn't like the lack of features on a cheap replacement player).
Apr 08, 2008 | Sony DVP-NC675P Multi-disc DVD Player
DVD inserted tries to read disc eventually message says no disc
First purchase disk cleaner disk from nearest computer shop then put it in dvd then play it so it clean dust from dvd lense.
If still it not read disk then you have to change dvd lense.
If your dvd is in warrenty take it to service centre and they replaced lense and repair it.
Let me know if you need more assistanse.
Thanks.
Sep 07, 2009 | Televison & Video
PORTABLE DVD PLAYER NOT SPINNING DISCS AND SAYING NO DISC
When it is region lock it will say it on the display, if the player is not reading any disk, it is more likely a lens problem, see below:
Try first using a lens cleaner disk, like the ones here.
If that does not work, the unit must be disassembled, and lense cleaned with q tips and isopropyl alcohol or cleaning solution. See below:
How to Clean the Laser Pickup Lens on your DVD Player
How to safely clean a DVD lens?
Clean DVD lens, or replace player?
Clean CD or DVD ROM lens with a brush?
Cleaning your DVD drive
How to clean a DVD player
How do I clean my DVD player optical lens isoproponol alcohol
Feb 10, 2009 | Televison & Video
Samsung DVD R130
PLEASE TRY TO CLEAN THE LENSE OF THE DVD PLAYER OR REPLACE THE LENSE
Aug 03, 2008 | Samsung DVD-R130 DVD Recorder
Worked a few times not anymore
clean the disk with warm water and dish detergent >>> dry with a cotton towel >>> try again.
Hope this helps.
>>> check disk for excessive scratches .
May 22, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
DVP-NS50P will not load DVD
the lense could be only dirty, try cleaning it first. i suggest do a manual cleaning if you can. open the top cover of the unit, remove the disk retainer and you will find the lense somewhere in the middle. use a cotton bud, use a little of alcohol, dampen a little only and wipe the lense in circular motion. then use new dry bud to dry it.
May 04, 2008 | Sony DVP-NS50P DVD Player
DVR 120 Disc/Screen freezes half way through
CD does not run
Clean lens and adjust the disk level
Not spinning disc
If it spins with a little help from yourself replace the spindle motor with improved motor, part number: RXQ0749A
This fault would only occur on c.d play back. The sound would gradually start to distort, until all that could be heard was complete distortion. This fault was intermittent and would occur whenever it felt like
Believe it or not,this fault was cured by replacing the optical unit
Nov 24, 2007 | Samsung DVDR120 DVD Recorder
Playing dvd's
The laser lens in your player might be dirty or failing. Try the following solutions: Clean the laser lens with a DVD player lense cleaning disc. Lense cleaning discs are available at many electronics retail store. Sorry i can't help you more. P.S. please use line breaks between paragraphs and one "dot" at the end of a sentence is enough.
Nov 30, 2005 | JVC TH-A9 System
Cyberhome CH-DVD 300 DVD Player Logo
Top Cyberhome Televison & Video Experts
zappal
Level 1 Expert
Electro Med Services...
Henry  Thomas
Henry Thomas
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
