Question about Brother IntelliFAX 1270E Plain Paper Fax
Replace ink cartidge
I didnt look at the setup/direction of the ink refill..i think its backwards AND reversed or something...unknownsndr_1@yahoo.com
Having trouble with thecartrige
Posted on Aug 02, 2008
Problems with Lexmark X2550. I have refiled for the first time a lexmark 28 cartidge. Now I have paper jam all the time, I cannot print and I don`t know what to do. I blame the cartidge, because before...
“Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
Oct 03, 2009 | Lexmark X2550 All-In-One Printer
I have had my ink cartridges refilled rather then replace them, but display is still showing as out of ink, please help!!
it are posible thad you have to reset the cartidge normaly you can ignore this warning by pressing ok
Sep 27, 2009 | Office Equipment & Supplies
Replaced Ink on Samsung SF-330 and still says install ink
There is something wrong with the cartrige head. First try to take out the cartrige and in the head there is contact points. You can try and clean it with a dry cloth.
Aug 18, 2009 | Samsung SF-330 Plain Paper Inkjet Fax
Still getting message empty cartidge lexmark x2650
May 26, 2009 | Lexmark X2650 All-In-One InkJet Printer
Ink Refill for HP Photosmart c7280 not working
Hi Lisa,
If it responds ok with the old cartridge then the problem is with the cartridges' chip not the printer. Probably the manufactor has a problem with certain cartridge chip (contact them!). I would suggest to use the original at the problematic spot if it works without a problem.
- Gilberto
Dec 15, 2008 | HP Photosmart C7280 Laser Printer
Here is a link to the Setup Guide. Go to Step 5 for instructions for ink cartridge installation.
J5780 Setup Guide
Dec 07, 2008 | HP Officejet J5780 All-In-One InkJet...
Screen went blank
Sounds like you fried something by reversing the polarity. Repair will likely be expensive, but check with the manufacturer to find out if they have a flat-rate service charge, if so they will most likely replace it with a refurbished scanner.
Sep 25, 2008 | Radio Shack Pro-95 Handheld Scanner
After refilling cartidge it still says it is empty
IB4G2008: Do u actually have a solution or a better driver for this printer OR are u just out to promote your site?
Your solution is not helping & if u think it is, pls oh pls,let me know of a DIRECT link for it, as i havent found anything that makes the problem better, nor a better driver for that particular printer.
Pls advise.
eldiablo2008
Jan 23, 2008 | Lexmark Z1420 Printer
Refilling ink cartridges
hp74a.jpg HP #74 Cartridge Refill Instructions
Black cartridge
Instructions
1. Put the cartridge on some paper towels in an area where you can tolerate a spill.
3. Fill the syringe with 20ml. of black ink.
4. Very S-L-O-W-L-Y inject ink into any hole (they all go to the same sponge, HP just used the same color mold for the black ink cartridges).
5. When finished, replace the top label or leave it off (it will make no difference in the printing).
6. Replace the cartridge and run 1 - 3 cleaning cycles as per printer instructions.
Or print the following pages:
http://www.refillinstructions.com/black.htm for Black
For best results, leave cartridge in printer for 8 hours after refilling so the ink can saturate the entire sponge.
A Refill Kit should include Ink plus the following:
One 30cc Syringe
Jan 14, 2008 | Office Equipment & Supplies
Brother IntelliFAX 1270E Plain Paper Fax Logo
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
