Question about Lexmark Office Equipment & Supplies
I installed my printer and it till wont work.It say's the printer is busy,and that there is no communication.
  • 197 Answers
Hmmm..ok...
turn off printer
unplug from computer
turn printer back on
plug back into computer
try a test page, from printer panel(right click on printer, properties)
Posted on Jun 22, 2008
Not communicating
try to clear printing queue in both printer and cpu. Also try a different cable.
Feb 14, 2015 | Lexmark X1155 X1155 All In One Inkjet...
Brother hl-5280dw printer just stopped printing. pc says doc failed to print - printer error or busy. test pages work directly from printer but printer does not recognize that documents are being sent to...
hi try re installing the software of the printer .completely uninstall first the previous software of your printer then install it again.to begin with the installation do no connect first the printer usb cable run first the CD the follow the wizard instruction installation.wait till the wizard prompt you to connect the printer and power it on.in this process the computer will automatically search your printer.then click next.until installation is successful.
you can also replace your USB connector for your printer if the computer cannot detect your printer..
good luck!
Jul 08, 2011 | Brother HL-5280DW Laser Printer
Hp Business inkjet 1000 wont stop printing garbage - a bit on lots of paper. It ran out of black ink - now replaced - but now wont stop printing .... Have tried unplugging power and usb. turned...
You need to view the print que and cancel all prints.
Do the following:
1.) Navigate to windows control panel and double click Printers and Faxes.
2.) Now double click on your Hp Business inkjet 1000 Printer it should come up with the que.
3.) Click Printer and then click Cancel all documents. That is the Printer tab on the top left of the box.
That should cancel the documents in the print que and you printer should be able to rest now.
Thanks
Till next time!
damnor01
Apr 13, 2011 | HP Business Inkjet 1000 Printer
Won't print says its busy
You need to clean NVRAM on Lexmark X7550 printer. Please follow the steps given below:
1. Power "Off" the All-In-One.
2. Press and hold the number button and turn the All-In-One back on. Press and hold the "Color Start" button and the "Check" button at the same time and turn the printer ON.
3. Release both the buttons once the printer is ON.
3. Press "Down" arrow button to go to the "Maintenance" menu entry. Press "Check" button.
4. Press "Down" arrow button until you reach "Manufacturers Test." Press "Check" button.
5. Press "Down" arrow button until you reach "Clear NVRAM." Press the "Check" button. The printer will restart by itself.
6. You will be prompted to go through setup again and to print an alignment page.
Next, try this printer self-test by following the steps given below:
1. Turn the printer ON.
2. Press the down arrow button till the screen displays “Maintenance.“
3. Press the "Check" button.
4. Press the "Down arrow" button till the screen displays “Print Test Page.”
5. Press the "Check" button.
The self-test should at least print out a set of either black or color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, please try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with the color cartridge installed. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues, we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault.
Apr 19, 2009 | Lexmark X7550 InkJet Printer
Lexmark 1270 scans but will not print
With the Lexmark printers communication subsystem you MUST let the driver ask for you to plug in the printer. DO NOT plug the printer into the USB port until told to do so.
To fix a fouled install :
(1) Uninstall the Lexmark drivers in Add Remove Programs
(2) Shutdown the computer
(3) Disconnect the printer from the USB port
(4) Restart the computer
(5) Run the Driver Installation software
(6) Cancel ALL attempts by windows to auto install the printer
(7) When the sofware asks for the printer connect it and continue
Dec 13, 2008 | Lexmark X1270 All-In-One InkJet Printer
Printiner not communicating
1)right click the my computer icon
2)click properties and then click hardware n go to device manager.
3)uninstall all usb ports and then scan for hardware changes
4)ur pc will detect your printer and ask for printer drivers
5)re load drivers and your pc will communicate with your printer
6)for reloding install the cd follow the instructions on the screen and click next
7)restart when the printer is loded.connect the wires and cords properly.
Drivers, Software, lost C.D....come this way!
If you have lost you cd or don't know how to install your printer then all you need to do is download the drivers and software from the manufactures website that suits your operating system and printer.
Sep 16, 2008 | Lexmark Color JetPrinter Z23 InkJet
Busy
Can you try with a new or different CF card,if there is read and write error into CF card camera will gives message "busy".
Dec 06, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Lexmark x3430 printer
X3430 lexmark wont let me scan any of my pictures.
it says it's to busy.
Nov 27, 2007 | Computers & Internet
Printer wont work
I need more information: Type of pc operating system etc type of printer etc If using ip address or usb or parrelle conection etc Steveo
Sep 11, 2007 | Office Equipment & Supplies
29 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
