Question about Ranger Left Corrective Lens -8.0 by Zeagle
1988 ford ranger overheating
Oil not milky, going through anti freeze, replaced thermostat. no antifreeze on ground.
    Master:
  • 638 Answers
This is one of the best link to help and guide you
http://www.ptdoityourself.net/tl/tl_indexmain.html
go to Group 7 Engine Cooling of this link
feel free 4 further assistance .rate the particular experts solution as fixya that helps u understand n solve ur problem
Posted on Jun 22, 2008
    Sergeant:
  • 260 Answers
Sounds like you may need to flush your water coolant system. you should test your antifreeze to make sure it is the correct level and solution. Ether way it sounds like you need to fluch your radiator.
  • 197 Answers
Well..ok...sounds like the head's NOT blown, that's a good thing..
did you flush out the cooling system, yet?
Why does my 1988 ford ranger f-150 over heat
Thermostat is stuck or the radiator or heater core is blocked up.
Apr 27, 2017 | Ford Cars & Trucks
2002 Nissan Altman looseing anti freeze but nothing under the car
Many possible causes. Leak can be when you drive, but not show on your driveway. The heater could be leaking into the passenger area, though you'd likely smell the "maple syrup" smell of anti-freeze.
It's also possible that you have a head gasket leak into the coolant, causing the overheating, and blowing some of your coolant out. Get a compression test on the cooling system, and a compression check on the cylinders.
Sep 21, 2014 | 2002 Nissan Altima
I have a 2002 ford ranger that runs normal while engine is running but gets hot when i shut off engine
SOUND LIKE ENGINE OVERHEATING.USE A INFRA THERMOMETER ENGINE TEMPERATURE SHOULD NOT EXCEED 104 CELSIUS WHICH IS 220 DEGREES IF ENGINE EMPERATURE GOING OVER 230. THERMOSTAT STICKING PARTIALLY CLOSED,WATER PUMP FAILING CHECK WEEP HOLE IF LEAKING REPLACE WATER PUMP.FLUSH RADIATOR ,HEATER CORE, AND ENGINE BLOCK. MAKE SURE YOU HAVE 50 / 50 ANTI FREEZE AND WATER.MAKE SURE ENGINE EXHAUST NOT STOPPED UP BECAUSE EXHAUST SYSTEM ALSO TAKE HEAT AWAY FROM ENGINE.
Aug 11, 2011 | Ford Ranger Cars & Trucks
2000 3.4 v6. i replaced head and manifold gaskets water pump,thermostat.about a month after it would overheat,i would fill it with water ,it would be fine ,now months later it overheats all the time,fans...
It sounds like you have a clogged radiator. You need to flush it out . If it won't unclog you will need to replace it. Sometimes if you ever use stop leak in your radiator, you need to flush that out if you ever replace anti freeze or add more stop leak. Remove radiator cap and start car and let it warm up to operating temp. Fill radiator where you can see the fluid with cap off. While looking at antifreeze gently give the engine a little gas and see if the antifreeze circulates by going down. If it doen't then it is either water pump, thermostat or a plugged up radiator. Good luck.
Apr 21, 2011 | Pontiac Grand Am Cars & Trucks
My oil is black and smells like gas. i want to change my oil because it scares me but i dont know what type of oil to use for my truck.it is a 1987 xlt ford ranger truck with a 2.9 l.engine from a 1988...
Sounds bad. Where is the transmission fluid going? I hope it's a leak and not getting into your antifreeze. DO NOT just run water.
Of course,change oil and filter to a good 10W30 synthetic to resist the heat (Pennzoil Platinum is good.
Now as to overheating.Change your thermostat(you need a thermostat in there) to make sure it isn't a problem.
Now as far as the leak...........you could pull the trans and fix the freeze plug(which is probably leaking) OR if it were mine and I wanted to postpone the expensive repair, I'd put a can of the liquid copper stop-leak in it(BAR'S LEAKS, I believe is the brand),then when it seals,drain the coolant out and after it cools, add pure concentrated antifreeze to achieve a 60/40 ratio. When you test your antifreeze it should show at least 45 below zero.
Do you think your radiator is plugged up? Could the fins be blocked with dirt or debris in front?
If you were running just water,it was probably boiling on you and that can ruin your engine because of air bubbles,voids.
If it IS a head gasket,you should see steady bubbles coming up the neck of the radiator,or the expansion tank even before it warms up.
don-ohio
Mar 10, 2017 | 1987 Ford Ranger
I noticed that when i put anti freeze and water in their is this brown milky stuff
the brown milky stuff is rust and you have mixed two different types of antifreeze together it formed a reaction,you will need to do a complete flush and top up with the correct antifreeze for your engine asap.DO NOT MIX ETHYLENE GLYCOL WITH ANY OTHER TYPE OF ANTIFREEZE..........
Jun 25, 2010 | 1999 Ford Taurus
Oil is smoking near dip stick,won't go over 10 mph, now won't even start.It had been overheating for a while we filled it up with anti freeze 50/50 then the oil started smoking. 1996 chrysler concorde.
you did put the antifreeze mix in the radiator and not in the oil cap didnt you?
Sounds like you put the water where the oil goes!
you may have a jammed thermostat if you didnt do this, or badly out of whack ignition timing.
Jan 13, 2010 | 1996 Chrysler Concorde
No heat, enginge died, antifreeze leaked, won't start again
car overheated.after it cools off try to start it again, if it dont start...check oil and see if it lookd like water is in it(milky)....if the oil looks like its milky or sludgy ..you may have a cracked head...thanks
Jan 04, 2010 | 1997 Ford Taurus
No heat , antifreez leak not visable...
A car this new should have a warranty right? the only other place for anti-freeze to go is through a blown headgasket into your oil. Pull out your oil dipstick and make sure it is not milky in color. If not check behind the engine and see if any coolant lines going into the firewall are leaking. When inside the car do you smell steaming coolant(anti-freeze) or hear gurgling? The temp gauge that stays on is the overheat indicator?
Need details
xxsodasipperxx@yahoo.com
Dec 14, 2009 | 1998 Chevrolet Malibu
Cameras Logo
83 people viewed this question
Top Ranger Cameras Experts
Are you a Ranger Camera Expert? Answer questions, earn points and help others
