How do you connect the outside antennae to both the dvd player and digital converter box and the television
  • 43 Answers
If its a dvd recorder first connect arial to recorder,then connect arial out to arial in on next device,and so on,it will say uhf in and out,on back the tv should be the last one connected,and you can also link them using scart leads and then use av on remote control, hope this helps andy
Posted on Jun 22, 2008
I have samsung old tv dvd vhs built but can't get into programming so I can hook dital box and antenna?
Yes. Connect antenna to digital converter box and then connect box to tv antenna connection. Use ch 3 or ch 4 on the t.v.
Oct 28, 2016 | Samsung Televison & Video
No antenna port for Olevia TV How do I connect outside antenna to Olevia monitor
you will have to use a VCR, DVD player that has a built in tuner, or an HD converter box. The HD converter box will have an antenna connection for the outside antenna. But will also have RCA outputs to connect your TV to the converter
Feb 05, 2013 | Olevia 237T 37 in. LCD TV
I have rca STB7766G1 converter box can I connect my dvd player
Trial and error. There is no list of products that will work together and how, so when you have situations that come up such as these you have to connect the electronic devices and see what happens. What's worse is that the combination will not always work with the same brands and even if you do get this to work today it might not work tomorrow.
Ok connect the DVD player to the television. Where it says out on the DVD player you connect the connecting cables either yellow, white, and red or green, blue, red, white, red. You connect the other end of them to the television. Put the television on the correct input. Try playing a movie to make sure the dvd player and television are connected properly.
Ok now where it says IN on the DVD player. Connect a yellow, red, and white cable. The other end of that cable connects to the converter box where it says out.
You can also connect the converter box and the dvd player in this way if applicable. If the dvd player has an RF (coax) IN connect a coaxial cable there and connect it to where it says OUT on the converter box.
Then you connect an antenna to where it says ANTENNA IN on the converter box. Now you will have to be able to put your dvd player in input (aux) or turn it to channel 3. You will always leave your dvd player in input (aux) or on channel 3. You will only change channels on the converter box with its remote control or the buttons directly on it. Good luck!
Apr 23, 2011 | Televison & Video
How to connect to tv using converter boxs
DVD does not need to go through converter box.
The converter is only to receive the digital TV through the antenna. DVD might have to switch to another connection on the TV, and if it doesn't have enough connections, you have a problem.
Dec 29, 2009 | Cyberhome CH-DVD 300 DVD Player
Hooking up converter box when i have a dvd player and direct tv
Hook your Insignia box between your antenna and your television. You still need the antenna.
Jan 01, 2009 | Insignia Digital-to-Analog Converter for...
Cannot connect the coverter box
When you have your converter box hooked directly with coax to your tv, is your antenna then plugged into your converter box in the "antenna in" port? What do you mean by it doesn't work? Does it say no signal? If so, you just need a stronger antenna. If not, you may have a defective box, bring it back to the place you got it and see if they can help.
Dec 27, 2008 | Symphonic ST420FF 20" TV
Connect tv vcr and dvd player to digital converter box
Yes you can first connect the converter box to the antenna first. Next hook the tv out on converter box to vcr in on vcr. Next hook the vcr out to the tv in and watch vcr and converter box on channel 3 sometimes channel 4.on the actual tv and of course change channels with converter box remote. For dvd player hook it straight to tv with red,white,and yellow cables that come with your dvd player. Then to watch dvd player if it's hooked up that way you have to put your tv on a input like video 1 or input 1. This can be done by using the tv remote and looking for a button that says tv/video or input or source button. This is some common names for that button on tv remotes.
Nov 02, 2008 | Insignia Digital-to-Analog Converter for...
Have a problem
Currently, your switch box likely has several inputs, which as you said are occupied by your DVD Player, XBOX, and your television source. The output of the switch is then fed to your TV.
What you will need to do is insert the DTV converter box BEFORE the switch box. If you have an analog antenna on your TV (rabbit ears) you will need to put the converter box between your antenna and the switch box (the cables, not the box itself) so that your wiring goes like this:
Antenna ---- converter box ---- Switch box
XBOX ---------------------------------switch box
DVD -----------------------------------switch box
And the switch box still goes to the TV. However, you do not NEED to use the converter box until February of 2009.
Jun 11, 2008 | Insignia Digital-to-Analog Converter for...
How to install DTV Digital to Analog Converter
Your outside antenna connects to the input of the d/a converter box then the output goes to your tv...1.2.3.... If your on cable you do not need a converter box.
May 08, 2008 | Televison & Video
Using vcd/dvd combo with digital converter box
"Sounds" correct to me.  Are you going by the instructions that came with the converter box?  And, "ANT In" to the box from your antenna?
Apr 04, 2008 | Samsung DVD-V8600 DVD Player/VCR
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
Electro Med Services...
