Question about Dometic Rooftop RV Air Conditioner
Coleman rooftop a/c unit, fan runs, compressor come on/off
I have a Coleman roof top a/c unit. The fan runs fine, but the cold air kicks off and on. Suggestions???
  • Anonymous Aug 03, 2008
    my unit works fair during cloudy weather and at night but during the hot of the day the unit kiks on and aff the compressor will only run about 4 minutes I replaced the thermostat but its still doing the same
  • Dometic Master
  • 6,674 Answers
First of all, Shut off power to A/C unit. !! Next,You need to remove the filter /cover ceiling assy, and with a flashlight, look way up inside and you'll see the cooling fins etc, that look similar to the back of the AC on the roof. If they appear dusty/dirty, then they need to be cleaned. I use a shop vac with a couple of extra extensions to reach, and duct tape a pot scrubber brush (half round or round with nylon bristles) to the extension. Then start as high as you can get on the fins, and come straight down, kind of like combing the fins, but not pressing super ******* them. Move over, and down again, until you get them all, or at least as much as you can. (Thats basically the same as your return air at home) I use the nylon scrubber because the brush attachment with vacuum is usually softer bristles, and doesn't get in there as well. If yours does, great.Make sure you wash out your foam filter in a little dish soap & water before you put inside cover/filter back up. Now to the best part, The upper unit on the roof. You need to remove the plastic cover, by removing the 4 screws holding it on, or if it's dometic type, screws all around near the bottom of the cover, and lift it off. The front of the colemans have a lip that the cover is down over, so you may have to pull cover forward & up, then it should all lift up & off. Here's a spot to be real careful, and ready for wasps & bees. Very few, if any that I've done over the years, haven't had a bees or wasps nest under them, so if you can do it on a cloudy day, or at least be ready to move quick, and have a wasp blaster spray with you, it may be smart. Just don't forget your on a roof when you start moving !! Another thing to remember too, is that the roof can be very slippery when wet, or dew is on it, so watch out!! Be careful !! Now with cover off, look at the fins on back of the unit, and clean those the same way, or spray with a garden hose, and soft brush, and clean them up. Next, look at the opposite side of those coils/fins, where the fan blade is in front of it, and lightly wash it down as best as you can with the hose, spray nozzle, and a brush if possible. Remember when using brush, up & down as much as possible, to avoid bending the fins over. If you can't brush it , just spray it as good as you can, to clean it. Water should not enter trailer, unless maybe if you go overboard with spray, and pressure. If you have access to an air-line to use up on the roof, that's good to, but a lot of times, the water will wash it down better. This will more than likely cure your problem, if you get it cleaned out. At the RV resort where I work as a Technician, we usually have a flat rate of approx. $50 CDN. for me to do it for you. 95% of the time it cures the early cut-out of compressor, and people actually report it cools better than it has for a couple of seasons. It has to be clean to do it's job properly. When those areas are dirty, the upper unit (compressor etc) has to work so hard to cool, it overheats & cuts out, until compressor cools down a bit, then comes back on, until it heats up too much again, and kicks out again. That's why it doesn't do it as much in cooler times, because compressor doesn't get as hot. Your also shortening the life of your unit too.
Posted on Aug 14, 2008
My coleman work ok last year coils clean now the compressor tries to kick on loads up kicks out no cold air at all
Posted on Apr 27, 2009
  • 113 Answers
Check ur freon level
Posted on Jun 22, 2008
I have a dometic penguin ac rooftop unit. Model no. 630215.421. Fan blows Compressor does not kick on. Fan blows just no cold air. If put on auto and go up or down in temperature On the thermostat The fan...
Bad run capacitor or bad compressor. If you hear an occasional click from the compressor try a new run cap and then a hard start kit. Otherwise it's more economical to purchase a new unit.
Sep 25, 2013 | Dometic Rooftop RV Air Conditioner
Coleman RV Rooftop Air Conditioner - cage fan making a noise like it is hitting on something as it goes around. The motor works as it should, low and high fan and cool, the air is cold. The only thing...
Those squirrel cage fans have a habit of coming apart, or getting dirt in them and going out of balance...then they wobble and hit the sides of the fan housing...
Make sure the fan is clean and also move it around a bit to make sure it is not coming apart....
Often the only way to fix them is too replace the sqirrel cage part...
Mar 06, 2011 | Dometic Rooftop RV Air Conditioner
I have a rooftop coleman ac unit on my RV. It works good at night but in the day when its in the 90's the fan runs but the compressor cuts in for abot 2 sec, and kicks out and the is an electrical odor...
Sounds like your "Compressor Run Capacitor" has cooked. Need to replace it, but not something you should be doing if inexperienced with capacitors and electrical. Capacitors store voltage at a higher rating such as 250-370volts, and can give a fatal shock if not handled properly. Technician, or electrician should only charge about $25-$35 for part, and 1/2 hr. labor to replace it. Just watch for Bees/Wasps when removing the cover on roof, to get to it.
Jul 19, 2010 | Dometic Rooftop RV Air Conditioner
Not cooling
check the and see if the condenser fan is running. you will find it if you take the top off also check and see if the condenser coil is clean. if it is dirty or the fan under the top is not running it will cause the compressor to short cycle on limits or overload.
May 29, 2010 | Dometic Rooftop RV Air Conditioner
My coleman mah 3 roof top will not blowon fan side
Sounds like you have either a bad fan motor or a bad fan motor capacitor. When you turn the unit on with the fan not working, the compressor (the humming noise) runs and gets real hot real quick resulting in the compressor cutting off ( the nothing after) on it's inside high temp switch. This is what the compressor is designed to do so that when this happens, it does not burn the compressor out. Replace you fan capacitor, give the compressor an hour to cool, then try it. In most cases and if I'm correct, the unit will run just like you want it to. Good luck.
Please rate solution
Sep 09, 2009 | Coleman Mach III Air Conditioner
Coleman rooftop a/c hums in all modes, does not start
Replace the start capacitor for the fan and compressor. Check all the wires to the capacitor.
Aug 29, 2009 | Dometic Rooftop RV Air Conditioner
If everything works on the roof top unit; all the power is on and the lights dim when the compressor kicks in, so do you think it needs to be rechaged?
Probably not. Does it trip right away or after it runs a while? Check all your wiring connections at the unit including under the compressor terminal cap. Make sure your fan spins free & is lubricated. The condenser on the roof top could be dirty. A capacitor on the compressor could be weak or failing. It is possible there is a refrigerant leak that caused the compressor to run hot and start to draw high current as a result though.
Jun 28, 2009 | Dometic Rooftop RV Air Conditioner
My Dometic 620315 Penguin roof a/c does not produce cold air.
If the compressor is running with no cold air the unit is more than likely no good. It can not be recharged. you need a new unit. If the compressor is not running you need to check the capacitors.
Mar 16, 2009 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
1,711 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
mike cooper
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
