Question about Amana ALG331RAW Gas Dryer
Dryer stuck amana wont turn off
  • Michael Sunnaa Jun 22, 2008
    Thanx you nailed it ,my vent tube was scrunched.
  • 868 Answers
If it is the timer thats not shutting itself off ,than check the following below
First off turn dryer ON and make sure there are no kinks in vent tube thats attached on back of dryer.2nd,find the outside vent opening and feel for strong air flow.If you have any doubt that its not strong enough then,pull dryer away from wall....pull the vent hose off the dryer ,.....now dry 1 load on a 50-60 minute Timed Dry Cycle.If all goes well, you now know your venting has to be cleaned out.(The only 1out of 1,000 other thing to check is your lint screen ,make sure you can see light through it.) 3rd and final , is if after running for 60 minutes with vent un hooked and still it is not drying competly,than you have to replace the Split coils on the burner,I really can doubt that you have a thermostat out.If you need to know the stats of the Split Coil to Thermostat ratio my experience is 250 Split Coils replaced to just 1 thermostat. Please Rate This !!!!
Posted on Jun 22, 2008
My amana dryer model #NED7200TW turns on and the motor runs nicely but the drum wont turn on its own. It will turn easily if i turn it with my hand. only about 3 years old.
if your saying theres a motor running but the drum wont turn . then id say either the idler pulley has come off or drive belt has broken , these do go bad especially on heavy load machines
Sep 14, 2016 | Amana NED7200TW Electric Dryer
Amana dryer model YNED7200TW will not start. there is power, but start button does nothing. Resetting breaker did not work. Any ideas?
Thermal Fuse
Item #2986 (OEM Part)
$10.70
Thermal fuse. If the dryer overheats, this device stops the flow of electricity to the heat source and/or the entire dryer. It is located on the blower housing and cannot be reset. The most common cause for overheating is a vent tube clogged with lint, a birds nest or other debris.
Manufacturer Number 3392519
More
  • Admiral Dryer Thermal Fuse
  • Amana Dryer Thermal Fuse
  • Crosley Dryer Thermal Fuse
  • Estate Dryer Thermal Fuse
  • Kenmore Dryer Thermal Fuse
  • Kenmore Refrigerator Thermal Fuse
  • Kenmore Washer/Dryer Combo Thermal Fuse
  • KitchenAid Dryer Thermal Fuse
  • KitchenAid Washer/Dryer Combo Thermal Fuse
  • Magic Chef Dryer Thermal Fuse
  • Maytag Dryer Thermal Fuse
  • Roper Dryer Thermal Fuse
  • Roper Washer/Dryer Combo Thermal Fuse
  • Whirlpool Dryer Thermal Fuse
  • Whirlpool Washer/Dryer Combo Thermal Fuse
In Stock
Quantity: http://www.repairclinic.com/PartDetail/Thermal-Fuse/3392519/2986#repairHelpVideoTabs
Jun 08, 2011 | Amana Dryers
Amana DLE330RAW Elec Dryer starts then shuts off & wont turn on
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jul 08, 2010 | Amana DLE330RAW Electric Dryer
Timer dial gets stuck on Amana dryer.
The only fix is to replace the timer.
Aug 30, 2009 | Amana Dryers
When the dryer is open the dryer keeps spining and wont stop you have to unplug it
Check the door switch. If the plunger is stuck, the dryer keeps running.
May 14, 2009 | Dryers
Amana dryer wont work
I'LL let you know after the Amana repair man comes out.
Mine is doing the same thing and I can't figure it out
Jan 14, 2009 | Amana NDG2335AW Gas Dryer
Refrigerator
It sounds like you found it. Change the defrost timer.
Jan 16, 2008 | Amana DLE330RAW Electric Dryer
Amana Dryer
sounds like a bad motor or something stuck in blower fan.. see if you can maually turn the drier drum if so motor is bad if not something is binding up drum or blower fan.
Nov 03, 2007 | Amana DLE330RAW Electric Dryer
Amana dryer ple330RAW
look for something stuck in the impeller (blower fan) that would cause the motor to hum and not run. If nothing is stuck your motor may be shot.
Aug 15, 2007 | Amana DLE330RAW Electric Dryer
Amana ALG331RAW Gas Dryer Logo
70 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
