Question about Kenmore 15129 Built-in Dishwasher
Kenmore Dishwasher, no power
Kenmore built in dishwasher has no power. checked breaker, unplugged it for a few hours. Have control panel open looking for blown fuse.
Which one fuse?
Any other suggestions.
Thank you
  • Rene Matz Nov 03, 2008
    Thermal fuse was replaced. One month later fuse was blown again.
    What parts does the theral fuse protect?
  • edatkeson Feb 02, 2009
    Same problem, first time we replaced the fuse that clips to the edge of the housing, ($17.) worked for a year. It went out again and we replaced the fuse but it only worked for three weeks. What is causing the fuse to blow?
    thanks in advance!
    Ed A, Albany
  • 413 Answers
There will be a thermal fuse located on the electronic control board housing that may have failed.This replaceable part (gray or white) is clipped on to the side of the plastic housing.
Posted on Jun 22, 2008
I have power to it but it wont come on.it makes a clicking nose
Posted on Nov 17, 2012
Kenmore 665 no power
No power at all? First thing to check is that the dishwasher power cord is plugged in under the sink. Make sure the plug didn't become dislodged. Then, check the circuit breaker at the electrical panel to make sure the breaker didn't trip. Open up the door to the electrical panel and look for a switch marked "dishwasher" or "kitchen outlets." Switch it off and then back on to reset it. Those are the easy fixes. Next you'll need a repairman.
Feb 08, 2014 | Kenmore 24 in. 17032 Built-in Dishwasher
Diswasher seems to have no power
Check the wall socket that your dishwasher is plugged into. If that's good, then check the wires in the junction box just behind the toe-kick panel (on the right). If that's good, then you have to take the door apart, and look for the thermal fuse attached to the control board or module with a plastic clip. That is probably bad (open). If you need a new thermal fuse, you can check SearsPartsDirect.com, RepairClinic.com, EasyApplianceParts.com, or AppliancePartsPros.com.
Nov 04, 2011 | Kenmore 24 in. 15932 Built-in Dishwasher
How to install new door spring on portable dishwasher
Things You'll Need:
  • Owner's manual
  • Screwdriver
  • Replacement spring (optional)
  1. Turn off the power to your Kenmore dishwasher before attempting any repairs. If you have a portable Kenmore dishwasher, you can just unplug the power cord from the wall. Built-in dishwashers are hard-wired into the cabinet, so you will have to turn off the breaker switch at the home's circuit breaker box to cut the power.
  2. 2 Remove the screws that hold the kickplate onto the lower front of the Kenmore dishwasher. Take the kickplate off to access the door springs.
  3. Check the door springs to make sure they have not come loose from the door support or the adjustment holes on the dishwasher. Re-attach any ends that have slipped off their connections.
  4. Replace the springs if they are connected at both ends but still do not have enough tension to support the weight of the door. Once a Kenmore dishwasher door spring is stretched out, it cannot be restored to its original condition. Unhook one end of the old spring from the adjustment hole. Unhook the other end from the door support and discard the spring. Insert one end of the replacement spring into the adjustment hole and the other end into the hook on the door support.
  5. Open and close the door a few times to make sure the spring is now working properly. The door should not bounce up and down or sag on the hinges when it is in the open position.
  6. Restore power to your Kenmore dishwasher by plugging it back in or turning on the switch at the home's circuit breaker panel.
Dec 21, 2010 | Maytag Dishwashers
My dishwasher seems to not be getting any power and no lights are lighting up. It is still plugged in and I already tried resetting breaker. Any suggestions?
HI. Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
If everything checks out ok with the above suggestion, the main control sector(timer or control board), will be the culprit.
The control sector must be replaced, in this case.
Dec 11, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
Kenmore dishwasher no power
Check the following areas for faults.
1. No power to the dishwasher
2. Door switch
Replace if defective.
3. Timer or control board
Replace if defective (note: uncommon problem).
4. Selector switch
Jun 14, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
No power at all
Check The following components below to address this issue.
2. Door switch
3. Timer/control
4. Selector switch
Jun 04, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwasher will not do anything
2. Door switch
3. Timer
4. Selector switch
Nov 30, 2008 | Kenmore 15129 Built-in Dishwasher
Kenmore 17052 is not working
Could be the electrical connection to the machine (behind toe panel), a fuse near the electronic control, the door switches, or the electronic control. P.S. is there a switch behind the counter, or under the sink which powers the dishwasher?
Mar 10, 2008 | Kenmore 24 in. 17052 / 17054 / 17059...
Kenmore 15129 Built-in Dishwasher Logo
2,750 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
