Question about Rival 8401-M 4 Quart Ice Cream Maker
Motor and gear box are bad, need to purchase a new one. Is one ava?
Gear box is bad and motor has burned up. I need a replacement motor.
I have one you can buy woodstockhouse@comcast.net
Posted on Jul 06, 2008
Will not turn at all just makes humming noise
I had one do that and I opened the gear box and found that the last time we made ice cream & it started getting hard the motor caused the gear to pop a tooth off (plastic). so now you hear the motor running but no transmission. Take it apart and check or turn the ice cream tub connection socket 1/4 turn and see if that makes a difference.
Nov 18, 2015 | Cuisinart Ice Cream Makers
Where can I get a gear wheel that takes the paddle shaft. Teeth have broken off mine.
Alan, there unfortunately are not any canister ice cream makers that the manufacture sells the replacement gear wheel.
Unfortunately when you have gear issues or motor issues there are not any replacement parts and they have just become a throw away item.
Mar 29, 2015 | Ice Cream Makers
White Mountain 69204 ice cream motor gear slips
Sometimes the gears in the unit become worn and have to be replaced. This might help.
White Mountain Ice Cream Freezer Motor Repair
Sep 04, 2013 | White Mountain F69206X 6 Quart Ice Cream...
I have an ice cream maker ice 45u but the mixer blade is not turning. The power is there because i can hear it and when i pull the leaver down the cogs turn on the sprinkler system are turning i have...
Check that all gears are in good working order. The paddlewill not turn properly and the motor will not run if the gears are worn ordamaged gears. Inspect the paddle for damage and replace if necessary. You alsomay need to replace worn or damaged gears in the motor. Lubricate the motor,drive shaft and motor bearings. Hope this will help you. Good Luck.
Sep 03, 2011 | Cuisinart ICE-45 1.5 Quart Ice Cream Maker
New motor makes loud noise when operating
Use a food grade grease to lubricate the gears. The newer White Mountain freezers have Chinese made motor drives and are a piece of junk. Don't confuse the newer models with your old American built machines. If it's still under warranty contact the manufacturer for warranty repair. Read the most recent customer reviews for the 4 & 6 quart electric freezers on Amazon and other websites. You will see a rash of motor failures!
Jul 20, 2010 | White Mountain F69206X 6 Quart Ice Cream...
Taylor Y754-27 Soft Serve Ice cream machine
Gearboxes definitely go bad. The first sign is usually noise, I would describe it as a rumbling. The best way to determine if it's the gear box is:
1. empty and disconnect machine from power.
2. remove the freezer door and beater assembly
2. remove the rear panel - 4 screws
3. Remove the belts on the noisy side
4. Spin the big pulley and listen for the noise, you may want to remove the belts on the quiet side to compare the two.
I have a video that was shot to help change the hex coupler, but you would follow all of the same steps to replace the gear box.
Dec 12, 2009 | Taylor 632-27 Ice Cream Maker
My motor assembly has a stripped gear. I tried ordering a new motor assembly but can't get one. I took the assembly apart and found that there are 2 gears that look the same. One is damaged. I could...
you seem to very short on required data , like make , model year , type of equipment
until you post again with all of that detail plus the statement , it is unlikely that anyone can help you
Nov 03, 2017 | DeLonghi ICK8500 IceCreamery 1.5 Quart Ice...
Musso gelato maker where can i buy parts
go to Http://www.catering-machines.com they have full list of spares or parts for Musso stella.
All parts for the musso ice cream machine including lid, motors, gear wheels, gearbox, musso paddle Musso serial numbers start L1 = Musso piccolo L2 = Musso stella L3 = Musso Club L4 = MUSSO CONSUL.
Oct 31, 2007 | Musso Stainless Steel Pola Ice Cream Maker
Rival 8401-M 4 Quart Ice Cream Maker Logo
403 people viewed this question
Top Rival Ice Cream Makers Experts
Dan Webster
Dan Webster
Stan Skaggs
Stan Skaggs
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Rival Ice Cream Maker Expert? Answer questions, earn points and help others
