Whirlpool ED5VHGXM Side by Side Refrigerator Logo
Posted on Nov 24, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Food began thawing in freezer, very warm in freezer
Anonymous
Level 3:
  • Whirlpool Master 43,501 Answers
  • Posted on Nov 24, 2010
Anonymous
Whirlpool Master
Level 3:
Answers
43501
Questions
0
Helped
10838030
Points
101584
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
The upper part of freezer is warm and the lower part is cold. what gives?
sounds like a defrost problem.. but be sure the freezer fan is running.. if the fan is running I would look at it being a defrost issue.... I hope this helped........ ken
2helpful
We have a whirlpool et1rhmxkq03. I have replaced defrost timer and thermostat. Defrost timer seems to stall and freezer thaws and the compressor stops running. I tap the control housing in the refr
The problem is with the "thermostat" right next to the defrost timer. When you tap on the control, you are actually tweaking the thermostat and not the defrost timer. Here is the thermostat to order.
Here is a diagram of the control box. The thermostat is number 13 and the defrost time is number 4.
Fridge is not cold and freezer is thawing all my frozen food , is compressor gone?
Check if fan in freezer is running as well as fan by the compressor and the compressor itself. Check for any frost buildup on evaporator cover in freezer.
1helpful
FREEZER NOT FREEZING AND F RIDGE FEELING WARM
Before you throw out this refrigerator, try a few simple tests.
First, open the freezer while the compressor is running and listen for the fan running. If it is not, this could be your problem. Replacement fans can be ordered from on-line parts stores, a local appliance repair shop, even ebay.
Second, try turning off the refrigerator and letting the coils in the freezer thaw completely. Of course, move your food to a safe place for a few hours while you thaw the freezer. If you really get ambitious, remove the rear panel from the freezer and look to see if the coils are frozen. If they are, thaw them and dry the freezer compartment completely. Reassemble the freezer and restart the refrigerator.
If the problem reoccurs, you may have a problem with your defrosting circuit.
4helpful
4answers
GIBSON DEEP FREEZE IS RUNNING BUT EVERYTHING IS THAWING OUT
Might try unplugging for a few hours and then plug it back in. There is a possibility that it slugged the compressor and there is a restriction in the line. Sometimes when the compressor fails to stop running in cold air the liquid gets back to the compressor. It can cause a bit of gunk to be picked up out of the oil and carried to the expansion line and plug up the line. Maybe turning it off will let the plug fall free and not replug the line. Worth a try anyway.....
Feb 07, 2008 • Freezers
2answers
Admiral - GC2224GEKB
Does freezer cool like the cold food section? Did this suddenly happen, and frozen food began to thaw?  Most freezers control the cooling in the cold food section. The freezer must work fine before the cold food section will work fine. Let us know more, Thanks JT
Top Whirlpool Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
