Question about GPS
After instaling the 2008 map update in my Garmin c330 GPS my GPS is not working anymore.
I found the answer in Google. The answer is: shut off the GPS. Then press and hold the right hand corner of the screen. Then press and hold the on and off switch of the GPS, till a white screen appears and follow the instructions on the screen. This will set the GPS back to the factory settings. It worked like a charm.
Posted on Jun 24, 2008
I am looking for free garmin updates for maps... i have the garmin c330
Garmin does not provide free map updates. You may purchase map updates for your Garmin product at www.garmin.com , or by visiting a local GPS retailer.
Nov 28, 2009 | Garmin StreetPilot C330 GPS Receiver
Free map updates for Garmin c330
Garmin has released new maps. Most of their units are entitled to a free update if the unit was purchased recently Just a heads up to anyone who recently purchased a C330. According to Garmin's tech support, the map udate 2008 is not free to those of us that recently purchased a C330. Only to those who purchased a C340 and up. Their excuse is that it is a "low end" unit, and also that the memory cannot hold the full US maps on the DVD. Gee, I can purchase the update for $69.99 and load a subset of the maps if I want, according to the person in tech support, but I cannot receive it as a free update. So, apparently buyer beware if you purchase Garmin's "low end" units. You will apparently not be able to receive a free update of maps, even if the unit you buy is already out of date.
Aug 23, 2009 | Garmin StreetPilot C330 GPS Receiver
Garmin map update
I recieved a notice on my gps saying that i must updated
my citi navigator to north america nt v8
do i have to do it
Aug 05, 2008 | Garmin StreetPilot C330 GPS Receiver
Free map updates
Unfortunately, they don't offer free map updates. You can purchase map updates for around $70, but they won't update them for free.
Also, the base model of the C330 does not have enough memory to store the entire 2008 Map Update. Unless you have more memory than it came with stock, you may have to choose which maps to include. For instance, in North America you have to choose between US and Canada - there's insufficient memory to hold both.
-John
Feb 06, 2008 | Garmin StreetPilot C330 GPS Receiver
Putting maps on sd memory card
(Untried)
For C330 owners that want to have both Canada and US 2008 map update on their GPS this is what you have to do.
Must have:
1 - Street pilot C330
2 - 512mb SD card
3 - SD card reader of some form (some cameras will suffice)
4 - Garmin 2008 Map Update North America
What to DO:
1 - connect the GPS to the computer
2 - Insert the Map update disk
3 - Install the Lower 48 states, United States
(Reason - the C330 has around 1000mb of memory and the "US 48 states" map uses around 900mb" while Canada uses 400mb...which is why you will need that 512mb SD card later)
4 - Once the GPS is updated with the US map. Browse the Map update disk contents. This can be done with going to "My Computer" right click on your CD/DVD drive and click on "Explore"
5 - Open the folder called "img"
6 - Copy the file called "gmappromU.img" file is around 430mb. (This is the map file for Canada)
7 - Insert your SD card into your card reader and connect it to your computer. A window should pop up. If not you should see it on your "My Computer"
8 - Once you have navigated your way into the SD card directory. Create a folder on the SD card named "garmin" (no caps)
9 - Go into your newly created "garmin" folder right click and paste the "gmappromU.img" file. (This may take upto 20 to 30 mins)
10 - Once the process is complete, Rename the "gmappromU.img" file to --> "gmapsupp.img" (watch for spelling, no caps at all)
11 - Remove the SD card, Turn off your GPS, Insert SD card into GPS.
12 - Turn on GPS, let it load, and there you have it, the FULL North America Map.
When you are searching a state or province (depending where you are located) it will give you an option which map to use, Canada/Alaska or the lower 48 US states. Select your map and you are set to Go.
Feb 01, 2008 | Garmin StreetPilot C330 GPS Receiver
Problem with uploading Map Update 2008
"Isn't it supposed to look like the image on the package? "
NO, the image on the package is just for show. The newer Garmin C5XX, Nuvi, will allow you to change to a car icon. To get 3D go to the main menu and select the wrench, then select map, then Map view to change to 3D.
Mapsource 2008 only upgrade the streets and POI (point of interest).
Jan 12, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin c330 no map data available
Did you try to perform a map upgrade to 2008? Turn on the Garmin and from the main menu touch the wrench,
then press Map, then look for Map info.
This will show the the current map version installed
Updated to 2008 maps, now I lost my local roads and town maps
Turn on the Garmin. Look for the little wrench on the screen and select it. Now look for Map, select Map. Now look for Map Detail. Verify that it is set to "Normal" or Higher to get more map details.
Dec 30, 2007 | Garmin StreetPilot c550 GPS Receiver
Did you try zooming either "in" or "out" ??? Did you verify that the new maps are installed? Did you try doing a reset?
Dec 29, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin Map update 2008
you will need to install the usb driver which should be located on the 2008 disk. When you attach the gps to your computer it should ask where the usb driver is located. If your dvd drive is (D) click browse and go the disk and find usb driver folder. I have purchased the new 2008 disk and had problems with it freezing on loader loading. I then browsed the disk and downloaded and then was able to get to the maps. I did not install it due to it asking what map I want to download. I wanted the whole thing so needless to say I am taking it back to walmart. I hope this helps.
Dec 27, 2007 | Garmin StreetPilot C330 GPS Receiver
GPS Logo
53 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
