Question about Sony DSC-T7 Digital Camera
Front slider When i turn the camera on either from the front slider or manually it says "lens cover closed". No picture will come out.Any solutions?
  • Stephanie_as Mar 10, 2009
    I'm also having the same problem with my camera!! I followed bittyan's instructions carefully but still no luck!! I'm not sure if somthing got bent the wrong way along the way but I need this camera fixed as soon as possible!!!!!! Help Please contact me at stephanie_college@yahoo.com if you have any helpful suggestions!!!
  • 3 Answers
Hey guys. I came looking for a solution to my problem as my camera was doing the same thing after being dropped. Unfortunately, I could not find a service guide with any pictures of the inside components, so I had no idea what the insides should look like. I decided to tinker with it since it was doing me no good without photo capability. If I didn't fix it, I was going to have to replace it anyways, so really nothing to lose for me.
This is what I did and maybe it will help you as well. Grab some slim tipped tweezers and a good desk lamp. I took out the screws from the case(you might try an eyeglass repair kit screwdriver or check Dollar Tree--I found and excellent little set of teeny screwdrivers that worked perfectly on these ***** screws. Be warned--mine were in there tighly and I had to put the screwdriver in pliers to put enough pressure to loosen them up. Just be careful you don't strip them.). Ok, once you remove those and set aside someplace safe, remove the battery. Now, very carefully work the front cover (lenscover side) off the body. Work over a table and be very gentle in case you have any loose parts inside. You will NOT want to lose any if possible! In the middle of the circuit board there is a tiny box that may or may not have a little black plastic *switch* inside. When I opened my camera I found: a tiny black switch, a tiny coil of copper wire (spring) and a silver metal bracket looking thing all rolling around. If you have these, then you need to put them back in place in the small box looking thing (it will line up with the back of the lenscover where you see a copper tab). To do that, you need to get the switch and coil together. I found you can do it two ways--one may be easier for you than the other. You can
A: Grab the copper coil by one of the ends sticking out with the tweezers and setting it into the underside of the switch. Use the lamp to examine the black plastic switch and you will notice on one side it has a little groove where the coiled side sits inside. As far as I could tell it doesn't matter which way you put the coil in or where the ends stick out. Then pick up the assembly with the tweezers (by the switch's little tab) and set it gently into the notches at the back of the box. If you examine the box under the light you will see (faintly) the notches where the little nubs sit. Once you get it in the box, the switch should easily be pushed in the down position (not all the way, though, or you will cause the spring to pop the whole thing out!).
B. You can grab the spring with tweezers and set it into the box at the back. Then grab the switch with the tweezers and position it over the spring and into the notches.
Either way, it DOES take some time so be patient. I was dropping the thing all over before I finally got them to work!
Now, with that back in the box, you need to attach the silver metal cover. Examine the cover and see if it is bent in the middle or if the little bent sides are flattened. You can use the tweezers to bend them back into a [ shape. This will fit over the switch and clip onto the box to hold it all in place. Now, once you get the metal bent as it should be, notice the **** opening and align that with the switch. The switch that springs up (not the end the spring is IN) needs to fit right inside that slot. Don't worry--it takes a bit to get it in there. Once it is lined up you will need to work the switch into it and push down. You may need two tweezers to hold both ends down so one doesn't spring up and out..or use a tiny flathead screwdriver to hold one end down. Keep working it until it clips back into place. Once it is fastened you will see only a tiny portion of the switch jutting through. You can test it by running a fingernail (or tweezers) over the switch to push it down and make sure it springs back up.
This part is needed because the lenscover, when opened, pushes the copper plate (found on the back of the lens case you removed) out which makes contact with the switch pushing it down, which in turn causes the camera to come on. All you need to do now is replace the front cover--carefully, lining it up and clicking back into place. Hold it together, add in the battery and try opening the lenscover to see if it works. Hopefully, it does! If not, something else may be wrong. If all is good, screw back in the screws and viola! I wish I could have taken pictures of the process as I know it would have helped me, but this is my only digital so I couldn't. If anyone needs help I can try to draw the parts if needed.
I hope each of you find a solution. These things are pricey and I was near tears when mine wouldn't work. Best wishes!!
Posted on Oct 03, 2008
  • 3 Answers
I just did this. open the camera up by unscrewing all the screws on the side. then on the front side of the camera where the lens cover would be, there is a small spring and black plastic thing. when you open and close the lens when the camera is working properly, it applies pressure to this black plastic and spring.
my solution:
i took this spring and black plastic thing off, then took a small screw driver and touched the small thin pieces of metal behind the black plastic and spring, which caused the camera to turn on and think the lens was open. i then go a conductive ink pen from radio shack, and filled up this area so the metal is always connected to the other metal through the conductive ink. now the camera thinks the lens is always on, but at least it works. i can still turn the camera on and off with the side power button.
Posted on Aug 08, 2008
  • 752 Answers
The switch that detects the sliders position is broke or misalligned. It's unlikely that you could fix it yourself. I suggest taking it to a service shop.
Posted on Aug 04, 2008
N86 camera issue
Here are the steps.
  • go to the camera application while the main camera lens is closed. (front camera will automatically be used)
  • Once camera application is up,open the camera lens. (application will switch to main camera)
  • go to video mode (you cant access image mode settings at it will crash the application)
  • go to the settings of the video mode and choose to reset the camera settings.
  • That should fix it
Feb 24, 2010 | Nokia N86 8MP Unlocked Dual-Slider 3G...
The lens cover will not open and close all the way.
to open them completely simply push them with your finger. try doing so also when closing them. i have the same issue sometimes.
Jul 13, 2009 | Panasonic Lumix DMC-LZ7 Digital Camera
Camera drains battery while off
Assuming you're fully closing the front slider cover, the power switch is activated by the front slider cover so it may not be activating the switch or sensing that the cover fully closed. Sounds like it needs a professional service.
Apr 12, 2009 | Pentax Optio Z10 Digital Camera
Opening and closing 3 times and then saying turn off and then back on
So 2 weeks ago my Sony DSC-W80 stopped working. Our friends dog ran into the camera (in my girlfriends hand) full speed. It started opening and closing a few times, and then giving the "turn the camera off and back on" message. I read about tapping around the lens, etc. None of this worked.
I took off the camera body and carefully examined the interior of the camera. Turning in on and watching closely, I discovered the problem. Looking at the camera from the front, I saw a slider on the top right side of the lens that appeared to be jammed. I then saw a spring that was attached to the slider and free on the other end. Apparently when the dog rammed the camera, the other mount for the spring broke off (they are very fragile). The purpose of the slider is to adjust the viewfinder based on the zoom range of the lens. I simply removed the slider which had jammed when the spring came loose. Camera works flawlessly now. The only issue is that the viewfinder doesn't zoom, but who uses the viewfinder anymore anyway? Oh, and I have a screw leftover. What project isn't complete without having extra parts when you are done?
Hope this can help someone else!
Sep 29, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
Lens cover does not operate correctly
I fixed this problem on my Fuji FinePix A303 (though it took some hard work).
The problem:
Camera Lens Cover stuck open or stuck closed.
Power on, and get !LENS COVER error.
Lens fails to extend.
The solution:
Short answer: The motor driving the lens cover is weak and eventually breaks down. I manually open the cover now. This took a manual modification to the camera (and some work).
1. Take the camera apart. See here for details, and be careful around the flash, as you'll get a nasty shock otherwise! http://www.mathematik.uni-marburg.de/~haim/focuserr.htm
2. Once you can see this, you're just about there:
3. Take off the battery cover (in the picture above).
4. Wrap a wire around the sliding pin for the lens cover, and drill 2 small holes through the black structure underneath the battery case, and then to the outside. The wire goes from the pin to the outside via the two holes. You should be able to manually open and close the camera cover COMPLETELY now with the wire.
5. Reassemble the camera (actually, you can test that it's working when it's all apart, if you're careful).
6. To operate the camera now, close the shutter first while off. Power on the camera, and very soon after open the shutter all the way by pulling on the wire (from step 4). This basically mimics the action of the little lens cover motor. If you timed it right (you have about a second margin), the lens should extend and everything functions perfectly.
It would have been nice to have been able to simply buy a new motor, but that would probably be a pain and cost some money.
Hope this helps!
Matt Van Dyken.
http://mattvd.googlepages.com
Aug 16, 2008 | Cameras
Lens cover error
TIPS:
1.)NEVER PUSH THE LENS IN AFTER CAMERA DIES, BUY A NEW BATTERY IMMEDIATLY AND TURN IT BACK ON, CLOSING THE LENS!
2.)NEVER USE AN AC ADAPTER, USE A RECHARGEABLE BATTERY OR A REGULAR BATTERY!
..to fix this...
Do as i say..
1.) Remove battery
2.) Remove front plate (screw driver may be needed)
3.) Check all gears, make sure they are correctly fitted in place)
4.) Move the gear manually to make the lens come out.
5.) keep it out, put the front plate back together.
6.) reinsert the battery, turn it on.
or...
1.) Remove the battery.
2.) Wait about 6-8 hours.
3.) Reinsert the battery.
or...
2.) Try hooking it up through AC adapter, put correct voltage.
3.) Try turning it on.
4.) Remove AC adapter, reinsert battery.
5.) Turn it on.
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE
Jun 17, 2008 | Nikon Coolpix S1 Digital Camera
Coolpix s6 lens cover error
I have a solution posted in doc "nikon s5 s6 lens cover error repair.doc"  uploaded on site http://www.esnips.com/web/papputatiyasStuff    It will be helpfull for you. Its is a step by step solution with images.
Regards Mukesh
Aug 30, 2007 | Nikon COOLPIX S6 Digital Camera
Lens cover closed
I'm just shooting in the dark, but have you tried taking the batteries out then putting them back in again. Also, you might want to look through the Sony website for an e-mail address that you could wite a question and/or ask for help/advice.
Jun 18, 2007 | Sony Cyber-Shot DSC-T1 Digital Camera
Camera doesn't recognize lens cover...
I rednecked the crap out of mine. I pulled off the slide cover and placed a small piece of paper clip in the area of the copper to make a permanent contact. Then duct taped it secure and then cover the whole slide mechanism. I would not recommend this method but it worked.
Apr 28, 2007 | Sony Cyber-Shot DSC-T5 Digital Camera
Slider Prob
Dang, what a weird design. The lens needs to go threw a cycle before it can reach the idle position where it waits for a comand from the user. If its in the closed position and you turn it on it extends to its full range then stops at the idle position. It sounds like it is stuck in some spot between close and idle. Since it cant reach the closed position or idle its shutting down. The only way to get it to work is to try and free the lens so it can cycle threw. There must be a lip on the slider and the lens is stuck on this lip so you cant slide it. Remove the batteries then try and slide the door open try and slide somthing between the lens and the door to free it up. This is the only way to get it threw the cycle. It may need to be serviced It sounds like the switch for the slider door is warn or has broken. It may work again if you can free the lens.
Aug 31, 2005 | Canon PowerShot S30 Digital Camera
Sony DSC-T7 Digital Camera Logo
209 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
