Have you been able to successfully do this in the past? What software are you using to try to record with? Does it seem to recognize the guitar in the software, just will not react, or does it not appear to see it at all?
Win 7 is probably incompatible with the Firepod. Others find the same thing and unless the Firepod manufacturer writes new drivers, it will not work with Win 7.
Probably the best course of action is to go back to XP or the previous OS you have used with it.
NEVER switch operating systems without checking that hardware and software is compatible with the new OS.
Microsoft is notorious for incompatibility of new OS versions such as Vista and now Win 7.
Check the settings of the ASIO drivers, to low on milliseconds can cause problems, also check if there are no tasks running in the background like antivirus that can cause problems. Disable also the screen savers.
If your using windows try also to make the page file on an other harddrive, this reduces harddrive activity on the drive where cubase is on, go for this to Configuration Panel\System. Click on the tab Advanced, click on the button performance and click in the new window on advanced, click on the button of virtual memory.
Note that when your having alot of extended memory installed in your computer the less it needs to write to the page file, meaning less harddisk activity and more performance for audio and video aplications.
Also make shure the system is free of ad- and spyware and other unwanted software.
Hi Melimiti, You are not the only one with this problem. Cubase is quite a complicate software. If reinstalling does not help we need to have a CLEAN Install on a new OS. If the problem still persist contact the vendor for the product exchange.
https://www.steinberg.net/1069+M52087573ab0.html, If u have purchased the software,just go to this this link,register ur product. U will get the steinberg cubase customer care, just try contacting them and rectifying the problem, because this is too specific and technical.BEST OF LUCK!!!! THANK U!!!!
Could be a bad cable, bad firewire card in computer, or the unit is damaged. Might want to connect the unit to someone else's computer with a new Firewire cable. If this doesn't work, chances are that the unit is defective. I have the same problem right now and I'm having to send the unit back to Presonus. They charge $85 for parts labor and the return shipping. The replace the entire board, so it's like getting a new unit. Hope that helps.
