Question about Radio Shack 433575 Cordless Phone
Dial tone There is a sound on headset, but it is not a regular dial tone. I put in new battery
  • raneep Jul 29, 2008
    I HAVE A R.SHACK PHONE 900MHZ
    MODEL#43-3906
    I CAN HEAR DIAL TONE AND SPEAK ONLY IF I USE THE HEAD SET.
    HOW CAN I USE THE PHONE WITHOUT HEAD SET
    PL. ADVISE
    THANKS
  • Anonymous Mar 24, 2014
    I disconnected the headset and how do I clear this setting? I don't have a dial tone.
I disconnected the RadioShack phone/answering machine and plugged in an old phone. At first I didn't get a dial tone, but in a minute or so, I did get one. I doublechecked the connection with the incoming phone jack. (I had checked this before, but didn't see anything wrong.) Again, I didn't see anything wrong, but maybe that did it. Also, when I disconnected the RadioShack from the incoming phone jack, I disconnected from my computer (I used to have dial-up connection).
Don't know which of my actions worked, but now I have dial tone on Radio Shack.
Hoooooooray!!!!
Posted on Jun 23, 2008
When I speak there is a crackling echo coming from my headset and the person on the other end of the line has reported that its difficult to understand due to the same noise?
If this suddenly just happened, take the battery cap off from the head piece. Detach the battery and wait 5 seconds, re-attached the battery and you should be good to go.
If this is your first time setting up, there's a round dial on the left side that you have to adjust. Keep the phone on with the dial tone and try different settings on the round dial. There should be a setting that'll give you a clear tone.
Mar 01, 2011 | Plantronics CS60 Professional Headset
I have used corded earphone while I was on travel. After unpluging the earphone, The phone does not work even with blue tooth. ( no dialing tone, no sound at all) I can used it only with corded...
hi sfkimura you need to take the battery out of the phone. Next plug the headset and into the port. Take the headset out and now put the battery back into the phone. the phone got set in headset mode. You can try doing a reset of the default settings. Don 't do a factory reset it will erase your phone back to nothing on the phone. Ok hope this help
Jan 19, 2011 | LG Dare VX9700 Cell Phone
When dialing with my logitech skype phone I can't hear any sound until the other person answers the phone. It only happens with skype to skype calls. It works perfectly calling regular phones.
This is probably because dial tones and ringing tones are part of an archaic system. Your cell phone still makes these noises as a courtesy, and you hear the dial tones/ringing tones when you make regular calls because your phone is communicating with the standard phone system.
Jul 12, 2010 | Logitech Cordless Internet HandsetĀ for...
No tone unless speaker is used.
Have you changed the fasica? if so you may have disposed of the speaker as it sits in the old fasica
where the grill is
May 22, 2009 | Nokia Consumer Headset
Cant get one of the phone to get dial tone says unavalibel
All you have to do is put the phone that does not get a dial tone on the MAIN CHARGING BASE for 20 seconds! it will then sync up!
Jul 17, 2008 | GE 25931 Trio Cordless Phone
No dial tone on one of the headsets
you have to put the second phone 20 sec on the base unit. and that its!
Jun 22, 2008 | GE 27831FE2 Phone
Cannot hear anything out of the earpiece of my GN netcom 9120 wireless headset
I was also experiencing the same problem (also after a power failure / storm) -- apparently good battery charge, connections ok, etc. I then tried removing the battery from the headset itself, waited 30 seconds, and then reinstalled the battery. This seems to have resolved the problem.
It is fairly easy to open the clamshell, but you will need a very fine Phillips screwdriver to remove the battery hold-in (it's really not a hold-down, it just keeps the battery in place. Reassemble the same way -- be sure to keep positive to positive and negative to negative.
Sep 01, 2007 | GN Netcom (9120-48) Wireless Headset
Radio Shack 433575 Cordless Phone Logo
169 people viewed this question
Top Radio Shack Lands Phones Experts
Greg Cann
Greg Cann
Are you a Radio Shack Lands Phone Expert? Answer questions, earn points and help others
