Overheating problems I have a toshiba A30-203 laptop and the cooling fans are on all the time. I have to have a desktop fan blowing on the area where the cooling fans are so the unit doesn't overheat and shut down comletely Any help would be appreciated. Thanks
    Sergeant:
  • 458 Answers
This is common with laptops if you use programs that use power. The notebook gets hot when the processor and hard drive are working hard. You are doing the right thing with the fan. They make coolers that go underneath the laptop that have fans for this reason. Check out this link.The link will explain everything. Never use your laptop on a flat surface. If you can find a cooler that is curved you are better off. Walmart has a good one. Also take everything apart that you can and blow it OUT. (Use a vacuum with a plastic hose if possible.)
Please rate this as a Fixya since I explained everything. This will keep my name near the top of the page. Thanks and enjoy your laptop.
Posted on Jun 26, 2008
  • T&N Family Electronics Dean and Sherrie Terrell
    Do you still need help? My ratings and
    questions keep getting tampered with, so I do
    not know who still needs help. The site
    people that run the site do not care. I am
    sorry for not getting back with you sooner
    than this. We had a death in our family and I
    have been out of town.
    Please rate this as a fixya if I have helped
    you. I need all of the fixya's that I can
    get. A thanks for trying score will hurt me though. Please lock the vote. If I could not help, it does not classify as a bad answer or solution. We are working for free here. Points matter a lot to enable us to answer paid questions.
    This used to be my score.
    85.09%, 160 Votes
    ? Solutions: 407
    ? Questions: 5
    ? FixYa!: 47
    ? Helpful: 35
    ? Thanks for Trying: 42
    ? Inappropriate: 1
    ? Not Rated: 275
    This is with tampering.
    83.11%, 111 Votes
    ? Solutions: 454
    ? Questions: 6
    ? FixYa!: 24
    ? Helpful: 23
    ? Thanks for Trying: 33
    ? Inappropriate: 0
    ? Not Rated: 360
    As you can see I have had someone tampering
    with my score. I need all of the help that I
    can get from the people that I have helped.
    If I have helped you, return the favor and
    please help me.
    You can click on my name in the future for
    help. If you still need help, please ask me a
    more detailed question.
    Thank you and have a nice day.
Lap top gets too hot and shuts downundefined
Almost every laptop will accumulate a big wad of fuzzballs and lintballs that get packed in front of the internal cooling fins for the processor and chipset. This results in overheating and random shutdowns, as is your problem.
Ease of cleaning this out, without disassembly, depends on the design of the laptop's cooling fans and air ducts. I have kept an 8 yr old Toshiba laptop clean inside and running good by using a shop vac wo work 2 ways. I use the vac's exhaust to blow air INTO the slots where the air typically exit's from the laptop.... and use the suction end of the shop vac on the fan openings of the laptop.
You don't want to blow into the fan openings, as this only forces the debris and fuzzball deeper into the cooling fins.
You want to force air the *opposite* way of the laptop's normal airflow, to dislodge the fuzzball.
After vacuum & blowing, the lintball should end up visible by the fan intake openings. You may have to pop the fan screens out if the lintball is too large to come out any other way.
Oct 28, 2014 | E-Machines Computers & Internet
Message keeps popping up saying Turn off computer, problem in cooling system
you need to get pressurized air and blow the vents to remove dust particles causing over heat. Or if possible remove keyboard to expose cooling fan and chip and use pressurized air to blow off dust
Nov 25, 2013 | Toshiba Satellite 1715XCDS Cooling Fan...
Toshiba laptop tripped for heat
Check to see if fan area has does in it. You can either take apart and blow dust out or try blowing without taking apart. I would take it apart. Also, check for firmware update which may address overheating problems.
Jan 11, 2013 | Toshiba Satellite A100-S8111TD Notebook
It is been 1 year that I bought my laptop.I have Toshiba A665-s6065.when I use it for some hours in normal cases(internet,movie,...),Toshiba health monitor shows me that my CPU temperature is going up and...
Hi RGH.
1. Fix Internal Cooling. The first and most important thing you need to do when your laptop is overheatingis to clean the fan(s) that provide(s) cooling to the CPU and graphics card. Over time, they build up layers of dust and dirt that slow them down and block airflow.
How to Fix an Overheating Laptop - MakeUseOf.
What can happen to a laptop if it overheats?
A laptop that severely overheats causes damage to the internal components. Before this happens, the laptop should attempt to shut itself down. ... If you smell smoke, a burning odor, the fans never run or the fan runs all the time, be careful to avoid ruining your laptop.
Negative Effects of an Overheated Laptop ' Chron.com.
How can I stop my laptop from overheating while playing games?
Maintain a cool environment.Try keeping your laptop in an air-conditioned or cool area to allow your system to cool down and prevent it from overheating. Consider using a heat sink. Use a steel flat bar as an external heat sink. It works because your computer has to heat up more mass before it overheats.
3 Ways to Keep Your Laptop from Overheating - wikiHow
HOPE THIS HELPS YOU OUT.
Nov 04, 2017 | Toshiba Satellite A665S6065 Notebook
Model: Toshiba Satellite Pro U400-S1001V. The Problem: The touch pad seems to be getting overheated after 30 to 40 minutes of use. Sooner if I play a movie. Please advise.
Most laptops have the hard drive under that area and it could be your hard drive overheating i would get a usb laptop cooler or replace the drive with a 5400 rpm drive so it runs cooler.
Mar 18, 2011 | Toshiba Satellite Pro U400-S1001V Notebook...
My acer aspire 5315 shuts off suddenly and won't restart till it wants to. I replaced the battery, no difference....what's wrong?
This could be a sign that your laptop is overheating. If you touch the laptop while it is running & you find it too hot, make sure that the fan is running properly & that the air ways are not blocked.
You can blow compressed air into the cooling vents of the fan. If you notice clouds of dust coming out, then it might be a good idea to disassemble the laptop, clean the fan & air ways, & reassemble it back. If the fan has failed & is no longer running, it might need to be replaced
Oct 22, 2010 | Acer Computers & Internet
Overheating and shutting down within several
The A-70 and A75 series both suffer from a very tight cooling system. If you are running a P4 its pretty marginal. Basically what you need to do is blow out and or clean the cooling system. On my A70 I had to do it every 4-6 months. Basically as soon as it started getting past warm on the bottom of the laptop it was time to blow it out.
Basically what happens is dust and oils (cooking oils, perfume oils etc) and hair collect on the cooler and reduce how effective it can cool.
So what you do to clean it is get a can of compressed air (keyboard blow off stuff) and two toothpick. Take the battery out and unplug it.Turn the laptop upside down. Insert the toothpick in the cooling fans. This is important as the air can turn the fans faster then they are meant to spin and could damage the fan bearings (new fan annoying and expensive -lots of labour). Take the compressed air and blow in from the exits and then blow in over the fans. What will surprise you is just how little dust will come out. It may just be one good puff of dust and thats it. When you do this a couple of times or don't see any more dust you are done. Take out the toothpicks and put the battery back in and turn it on. It should run much cooler.
May 17, 2010 | Toshiba Satellite A75-S231 Notebook
My Toshiba Satellite Laptop M105-s3004 Crash and fan not running
Because the fan doesn't work, your laptop is overheating and going into thermal shutdown. have the fan replaced and the area where it is screwed to cleaned as it harbours dust over time preventing adequate cooling.
Jan 25, 2010 | Toshiba Satellite M105-S3004 Notebook
Most of the time my toshiba laptop will not start
Open the notebook and get the system clean by blowing it with an Air blower mainly near Processor area and cooling fan.
It will solve your problem.
Happy New year to you too.
Dec 30, 2009 | Toshiba Satellite M55-S135 Notebook
My toshiba satellite a215-s7422 is overheating i think. it's been shutting off suddenly with no warning and the fan doesn't seem to be blowing like usual...
turn it off turn it over and clean the fan on the bottom. I use a Satellite a25. I have used air to blow out the cooling coils a nunber of times. Toshiba has picuten in the owners manual on how to remove the fan for cleaning. it picks up dust from the work area and does not blow it clear. this cause it to over heat most likely
Dec 20, 2008 | Toshiba Satellite A215-S7422 Notebook
Computers & Internet Logo
113 people viewed this question
David Payne
David Payne
