Air conditioning Does the thermostats wiring have a color coding scheme
  • 550 Answers
No,
most thermostat wiring is 4 core, because installers use phone cable -its cheap- but there is no accepted color code, and some systems use 2, or 3, or 4 of the wires.
there should be a standard.
terminals on thermostats and furnace, aircons are labelled, but the labelling is often contradictory. some thermostats have function to control the fan separately, some for the same aircon dont.
the manufacturers web site for your aircon,
should give a detailed explanation in install instructions which terminals are open on rise close on rise, heat/cool and how they are connected
the new thermostat should detail which of its terminals match those of the aircon.
test the cable before installing anything at the aircon or thermostat, a lightning strike can have shorted things normally impossible, and the lowV thermostat line could be at lineV and trash anything or anyone connected to it,
  • Lightning strikes are very unforgiving, please be careful, even if the lightning touched down yards away the voltage at large distances from the strike can be 10KV
  • paranoia impels me to recommend an electrician with test equipment for the lines, outside unit, cables and inside units, its better to check and be wrong, than not check and be wrong.
Posted on Jun 23, 2008
Can't figure out how to wire RobertShaw 4220 thermostat for heat pump and electric air handler
Do you have the wiring Diagram If not you can look online for them or go to the place you purchased it I would like to tell you the Color code But not all installers use a color code Properly.
Sep 18, 2013 | Fahrenheat Built-In Baseboard Thermostat...
Panduit mini-com tx6 cjs688tgy how can punch cable and what is the color coding
The colours refer to the (usually) colored pairs of wire in a Cat5, 6 or 7 cable. There are two schemes called 568A and 568B, where some wire are different. Since these jacks are used for permanent wiring, you can choose one of the schemes and use it at both sides of the cable. Watch out if someone has already installed network-cables in the same building and use the same scheme!
You dont need to "punch" the wires. This old method (LSA+) is not good enough, if you have very high bitrates, like we use today. Go to the panduit-website and download a data-sheet of your jack - it should include wiring directions.
hth, Karl
Oct 18, 2011 | Panduit Mini-Com TX-6 Plus (cj688tpor)
I have 7 wires, how do I wire it Red Green White Black Yellow Orange Blue
Conventional heating, air conditioning and heat pump thermostat wiring labels, wire color codes and the corresponding function description: Terminal
Designation
Wire
Color
Function
Description
Rh Red 24 Volt Hot for Heating Rc Red 24 Volt Hot for Cooling Y1 Yellow First Stage Cooling Y2 Blue Second Stage Cooling G Green
Grey * Energizes Indoor Fan W1 White Energizes First Stage Heat W2 Black Energizes Second Stage Heat O Orange Heat Pump
Reversing Valve
Energized In Cooling B Brown Heat Pump
Reversing Valve
Energized In Heating C Brown** 24 Volt Neutral
(Common) leg
Hope this helps
Tom Miller
Broadcast Eng
Sep 07, 2011 | Hunter Fan Company 5/1/1 Programmable...
My honeywell heater thermostat is only blowing cold air, there is no heat blowing regardless of setting. how can i fix it? it won't even turn off.
the wiring for thermostats are color coded. R(red)power, Y(yellow)cooling, G(green)common, W(white)heating. O(orange), E(emergency)heat. Make sure that you have the right thermostat because there is an air condition thermostat and there is a heatpump thermostat and they wire up differently.
Nov 27, 2010 | Honeywell Programmable Thermostat Heater
I am repairing my home ac thermostat and need one with a color scheme for 7 wire colors
if you go to the air handler that you have and follow the thermostat wires to the control board they should match up to your thermostat
Jun 24, 2010 | Heating & Cooling
Old thermostat wires same color.
Gary, you have not told us if this is just for heat or both heat and air conditioning. I will walk you through a heat only thermostat installation. The two wires you have should connect to R (or RH) and W terminals on the new thermostat. Varify that there are only two wires hooked to the gas valve on the furnace. It is a good idea to hook the red wire to the R terminal.
Jan 08, 2010 | Heating & Cooling
Need color code 2003 f250 for radio
Hi and welcome to FixYa,
On 2003 Ford F250 trucks we have worked on, the below wire color scheme is used. Of course it would be to your advantage to perform a voltage check on the wires on OFF and ACC condition of the ignition switch. Further, continuity of the speaker through the speaker wires would also help.
Good luck and thank you for asking FixYa.
Dec 28, 2009 | Car Audio & Video
I want to change to a programmable thermostat my old one is 8846 and i need to have a wire diagram in order to change wire or its a lr1620 might be the model
  • Red to the thermostat RH or thermostat RC terminal with a jumper wire between thermostat RH and thermostat RC. Or Red to the thermostat R terminal which is shared with both the heating and cooling. It has an internal jumper built in to the sub-base. The red wire is the source hot wire from the transformer. All other wires, except the common wire, controls a specific relay or contactor that energizes the fan, heating, or cooling depending on the selection. The following is the common wiring colors but your system may not be common and different colors could have been used.
  • Green to the thermostat G terminal. This is the color that controls the fan or the relay that control of the blower.
  • Yellow to the thermostat Y terminal. This is for control of the air conditioning.
  • White to the thermostat W terminal. This is for control of the heating.
Here is the link you can copy and paste in your browser: They also have every other model here to:
http://highperformancehvac.com/thermostats_2.html#new_thermostat_installation
Jul 08, 2009 | Honeywell Electronic Programmable...
Air Conditioner malfunction
Hi, Sounds like you have a short in the control circuit to me. Turn off all power going to the unit. Write down or otherwise mark the wires leaving the control board going to the thermostat. Remove them from the control board. Replace the fuse. Turn power back on and see if the fan still runs. If it does, check and or replace the heat limit switch that brings the fan on during the heat cycle. It may just need adjusted. If the fuse blows, I would think that the control board is probably bad. If it doesn't blow, Remove the thermostat. Leaving all thermostat wires open check them with an Ohm meter. There should be no continuity between them. Twist all the wires together at one end and ohm them again at the other end. You should have complete continuity on all wires. If the wiring checks out, down power the unit. Double check your wire colors and rewire the control board. With all wires open at the thermostat, turn the power back on. Touch the RED wire to the YELLOW wire. The Condensing unit should come on. Touch the RED wire to the GREEN wire. The fan should come on. Touch the RED wire to the WHITE wire. The heat should come on. Down power the unit. Replace the thermostat. Test unit. If the fuse has lasted ok but blows now it is either wired wrong at the Thermostat or the thermostat is bad. I hope I have helped. NOTE: If you can not understand these instructions. Call a licensed Heating / Air conditioning company. kstfas
Sep 23, 2007 | Heating & Cooling
Heating & Cooling Logo
193 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
