Question about Freezers
LG ice maker only fills half of the cubes
And not very full. replaced filter etc. help!!! LG die by side
    Problem Solver:
  • 13 Answers
On the ice maker you will see a little screw with a + or - printing check carefully on the side just turn it on the way of + it will increase the water time so you will have bigger icecube. hope i was helpful!
Francois
Posted on Jan 21, 2009
French door / lower freezer. The icemaker makes ice fine until tray is about full and then slowly drips water until about 1/8 of ice is frozen together with a upside down brown ice cycle fused to them....
The most common reason for this is that the fill valve for the ice maker is sticking slightly.
The brown ice comes from the leaking water sitting there on either the kickout bar or the gears and you are getting some residual rust deposit.
You will need to take the fill valve apart and clean it or possible replace it, I also recommend installing a water filter for the ice maker if you don\'t have one or replace the old one.
Calcium deposits in water are real hard on these small valves.
Oct 10, 2013 | Jenn-Air Freezers
Ice maker will not separate ice cubes
Check if your water filter is up to date, if not check if the ice maker has the option to choose the side of the ice cubes, if so, set it up to medium side.
Apr 05, 2013 | Samsung RF217ACPN - 20 cu. ft. French Door...
Slow ice cycle
Are you having any temperature related symptoms, i.e., soft ice cream that appears to have melted slightly and refrozen, soft breads in the freezer, warm or hot outer surfaces anywhere? If cooling is not a problem whatsoever, are any of your ice cubes smaller than normal, or do you have hollow ice cubes; you would be able to crush the cubes in your hand? If either of these pertains to you, you have not enough water coming to the ice maker, due to a faulty water valve not opening completely, or your water source pressure is low. disconnect your water line from the fridge, test pressure of the water line by placing end in a bucket, turning water on. It will be obvious how the pressure is. if pressure is good to really good, you have a bad water valve on the fridge. If pressure is so-so to bad, change source water valve.
If cubes are not small nor hollow, but rather normal full size cubes, just not enough, you probably have an intermittent problem with your icemaker, replace that.
Mar 31, 2010 | Avanti Freezer Compact Ice Maker - 12 lbs....
Slow filter water stream and hollow ice.
You have a mesh screen in the water supply line where it connects to the water inlet valve. It can be stopped up with sediment.
Sep 27, 2009 | Freezers
Ice maker only fills the tray partially.
There is an adjustment, but first check your filters, including the one in the inlet of the control valve. To find the adjustment, take the cover off the front of the ice maker. On the side may be a little hole. Look for any 'increase' arrow or such. If not, use a small screwdriver to turn the adjustment a half turn and let it make a load of ice. If it gets smaller, go the other way, use small adjustments. If you can get the owner's manual, it will help a lot. Google your unit for one, you may be able to get it downloaded free from Whirlpool.
May 05, 2009 | Whirlpool Freezers
Thin Ice on Whirpool Ice Maker
Hi
If  The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Please do rate the solution as "FixYa" if found useful and revert for further assistance.
Thanks
Rylee
Apr 05, 2009 | Whirlpool Freezers
ICE WITHOUT PLUMBING
it really doesnt matter how full you fill the bucket. round cubes will probably dispense just fine if you have access to that shape ice.
One additional thing, be sure to turn the icemaker off to prevent the fill valve from going bad and to keep it from making a loud buzz about every 10 minutes. thx peyton
Jan 25, 2009 | Freezers
Ice cube shape
hoshizakis make ice cubes depending on the amount of water in the sump. if you are starving for water the sump only partially fills in the fill time allowed . then it makes ice until the water is used up and the float switch drops and the cubes are little slices. you can adjust the size of cubes you want by raising or lowering the float assembley in the sump. if its to low the water rises and the float rises and tells the machine you happy with little slices. if you raise it up to max height you can max fill before float satisfies and max ice cubes. But if you are starving for water the time to fill will run out before the sump fills and cubes will be small no matter where you set the floats assembly. water starving can be due to crud in the water line, to small a water line, most hoshizes take a half inch line ,or a clogged water filter. if you suspect a filter take it out . if fill is drastically improved you need a new filter. be aware that starving for water on a hoshizaki will eventually lead to broken evap plates. big time expensive.good luck. i put in a new machine ruined by starving water and the new one made little chips of ice real quick. i finally pulled the filter out and voila! big cubes and great production.
Oct 28, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Icemaker
You might have a frozen line. Also and this seems more important to you its prob to cold, Trust me to cold of a refrig will cause hollow ice cubes first leading to a frozen line. Clean your coils, if you have another refrig empty out into that, unplug it leave doors open a couple days. If you can get to water line use a hair dryer from a distance defrost line, turn down freezer half knotch 1 full one at maximum. should fix issues, especially if filter already changed. If this all check prob a clogged line, not just frozen.
Mar 15, 2008 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Freezers Logo
71 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
