Question about Epson Stylus C60 InkJet Printer
Epsom printer dx7450
Replaced ink cartridges prints ok but no red ink
  • powerrangers Mar 09, 2009
    i have the same problem and done print head clean even bought a new cartridge even though the old on is still full checked for in contaminations printed off lots of tests pages instead of printing a block of red it comes out green? or sometimes green and yellow stripes???
    Genius:
  • 1,019 Answers
you could have one of several problems here.
i,d suggest printing several test pages, and observe whether the red comes through after this.
if this does,nt work remove the cartridge, and replace ensuring the cartridge goes in with a firm click.
finally if you have the original software installed for the printer, try a head cleaning operation.
Mike @ Compurepair.
Posted on Jun 22, 2008
Epsom print EX-200 wont print after l changed the ink cartridge
Did you pull the tape off the top of the ink cartridge?
Oct 17, 2015 | Office Equipment & Supplies
How do i change a cartridge for epson printer DX7450
Click on yhe following limk to see the online manual
Click to open the manual. Click on the Printing. Under this title you will see about ink cartridges.
Hope this will work for you.
If it is helpful. give a rating.
luciana44
http://www.epson.co.uk/Printers-and-All-In-Ones/Inkjet/Epson-Stylus-DX7450/Drivers-Support
Jan 09, 2010 | Epson Office Equipment & Supplies
Not printing
do these steps..
  • Shut down printer and restart it.
  • Check printer cartridge
  • If all else fails, reload printer driver from CD that came with printer.
Feb 02, 2009 | Epson Stylus C60 InkJet Printer
Don't know how to move the cartridges to replace the ink.
Please follow the instructions below to ensure correct installation:
  1. Lower the printer's output tray and open the top cover.
  2. Connect the power cable to the printer.
And switch on the printer.
The print heads will now move to the replacement position. If they do not move to a change position press the Red ink button on the printer.
  • Lift up the ink cartridge clamps.
    Before you open the new ink cartridge package, shake it four or five times. Then remove it from the package.
    Do not touch the green chip
    on the side of the cartridge. This can damage the ink cartridge.
    Remove the yellow tape from the bottom of the ink cartridge.
    You must remove the yellow tape from the cartridge before installing it; otherwise, print quality may decline or you may not be able to print.
    If you have installed an ink cartridge without removing the yellow tape, take the cartridge out of the product remove the yellow tape, and then reinstall it.
    Do not remove the transparent seal from the bottom of the cartridge or the label on the cartridge; otherwise the cartridge may become unusable or ink will leak.
    Place the ink cartridge into the cartridge holder with the bottom down. Then push down the ink cartridge until it clicks into place.
    Repeat steps 4 to 6 for each ink cartridge.
  • Close the ink cartridge cover and press it until it clicks into place
      If you find it difficult to close the cartridge cover, make sure all the cartridges are firmly seated. Press down on each cartridge until you hear it click into place. Do not attempt to force the cover closed.
    1. Close the printer cover and press the ink or start button to begin charging the system. Charging can take up to three minutes and is complete when the power light stops flashing.
    While the ink system is charging do not switch off the printer.
    Sep 16, 2008 | Epson Stylus 880 InkJet Color Printer
    EPSON PRINTERS how to replace inks in epson DX 7450
    You must surely have sorted this one out by now Doris! However, if you haven't, how to change print cartridges on a DX7450 is very clearly explained in the user handbook (on the CD that came with your printer). Insert the CD and select "Custom Install" then "Users Guide". Once its installed, double click the new Epson Icon on your screen and selct "Printing" then "Replacing Ink Cartridges". If you don't have a CD, download the User's Guide from the Epson website at http://www.epson.com - just choose your locale, then select Get Drivers and Support - Printers.
    Jun 13, 2008 | Epson Stylus Pro 4800 Color Photo Printer...
    Epsom stylus all in one dx7450
    press 'Control' + 'P' on a page (as tho you want to print)
    click 'Maintenance'
    there you'll find various options to clean heads etc, that should do it. tho it does deplete your inks considerably each attempt. & you'll probably find it needs more than one clean.Good luck!
    Jun 08, 2008 | Epson Stylus Multifunction Inkjet Printer/...
    Red ink not printing
    i think your head is bad..
    change the head itself..
    it will fix you..
    thank you.
    Feb 15, 2008 | Office Equipment & Supplies
    Epsom R200 COPY INK DOESNT WORK
    There is no solution, I have tried this myself, there are compatible inks for this product, you just got the wrong ones, However it may only be down to one of the inks, check the ink levels before removing, if all empty, then they are not compatible.
    swampduck
    Jan 07, 2008 | Epson Stylus Photo R200 InkJet Printer
    "Change cartridge" light stay's on after replacement
    What exactly does the status monitor say? Your printer may have a problem with the counter or if the machine simply does not see the cart there could be an issue with the print head or the main board.
    Sep 29, 2007 | Epson Stylus 680 InkJet Color Printer
    Epson Stylus C60 InkJet Printer Logo
    392 people viewed this question
    Top Epson Office Equipment & Supplies Experts
    Michel Smith
    Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
