Question about Euro-Pro Shark 80 - 7133
Machine running slow then just stopped
My machine has been going slow. The past couple times I used it, it would start out slow then go to normal speed, like it had to warm up or something. I haven't used in it a month or so, and this time it started out really slow and I only sewed about 6 inches when the machine stopped working altogether. The light is on but the pedal does nothing. During my sewing I also started to smell something burning... not sure if it's a wire, the motor, or what. It's a distinct smell, not quite like rubber but maybe a little? I unscrewed the plate on the bottom and looked inside but didn't see anything not that I know what I was looking at. I can't take apart the foot pedal--there are no screws to unscrew it--but the smell wasn't coming from there anyway. The smell is coming from the machine. Is it time to take the machine in to service it or is there something I can do? I hope I don't need a new motor. Do those pretty expensive?
  • zarkle Jun 23, 2008
    Where abouts is the motor in a sewing machine anyway? The smell is definitely coming from inside the housing and I can't see in there so I don't know what it is that is smelling.
  • varsram May 11, 2009
    it is running slow,burning smell comes,it is a x display machine,recently bought that,used twice, it was running normal,after a month ,its slows down a lot and burning smell from the machine and u can see that foggy ......how to solve this?do i need to change anything?any experts pls help?
Grand Lake Sew and Vac does not repair sewing machines. They send them to a repair place in Alameda. Someone comes to pick up the broken machines every Tuesday. Repairs are not timely and can be pricey,
Posted on Jul 19, 2009
My sewing machine started to sew slow and seem like it is working hard. Won't sew normal. Hasn't been that long since it was last serviced/oiled. Any suggestions?
Slow is due to friction in the shuttle drive and key moving bars and joint. Apply few drops of petrol/kerosene and run for few minutes. Then apply normal lubricating oils meant for machines.
Dec 15, 2014 | Sewing Machines
After setting up the embroidery module and preparing the thread, plate, and needle and then choosing design and hoop it wont sew. Yes, it is on. Foot pedal connected. The reverse button will not sta
Can you describe your problem a bit better.
From what you describing it sounds like the machine does start to embroider, it starts slow then it stops.
It is normal when you first start to embroider that the machine runs very slowley, does just a few stitches and stops. This is normal and all Berninas do this. The machine stops after these first few embroidery stitches so you can cut off the extra piece of thread. Cut off the extra thread then push the reversing button again and the machine should start to embroider. It will stop again if a color change is needed. This information is provided in your owners manual.
Make sure you have lowered the feed dogs for embroidery and there is no need to have the foot control attached for embroidery though it won't affect anything if it is attached to the machine...
Sep 16, 2014 | Bernina Artista 180
My mom's old singer will start sewing then slows down to a stop.
It may need a REALLY thorough cleaning & oiling, Cindy, including the motor bearings. The motor's windings may be getting weak, too, or the new belt may be slipping.
Aug 11, 2014 | Singer Sewing Machines
How can I fix a jammed, squeaky hand wheel?
This sounds like a bushing in your serger or the upper looper shaft heats up with use. This the swells the metal and seizes the machine. This is always hard to fix right because there are many points on the serger that need regular lube and can heat up. it is an eliminate 1 joint at a time and try agein
May 28, 2014 | Husqvarna Huskylock Computerized 910
Bernina 1030 starts by itself and runs very slowly some time after parking the needle at the top
This is most likely a fault in the foot control. Normally supplied with this machine is a Type 10 and this can be fixed quite easily but probably not by the machine's owner unless you have some electrical and mechanical experience.
If you have knowledge of and access to a multimeter, you can test it. What working properly, you will find the following:
Pedal released: resistance is infinite (anything around 4k Ohms or less and the machine will run).
Heel pressed: resistance is about 10k Ohms.
Toe steadily pressed from nothing to all the way down: resistance is infinite then after a small depression, jumps to about 4k Ohms steadily decreasing to zero as the pedal reaches all the way down.
Your problem, being at the point where the pedal isn't pressed suggests that there's some contamination in the pedal. It's also possible that you have a type 365 pedal (as used on the 930) and this is more likely to give this kind of trouble due to the use of carbon brushes in this foot pedal.
Feb 07, 2014 | Bernina Sewing Machines
Sewing machine slows to a stop.
When was the last time you oiled it?
Sewing machines need regular oiling as you use them - it sounds like you have or are close to seizing the bearings.
In future, when you smell burning and a machine that should operate at full speed slows down - stop, don't persist in using it.
It clearly has something wrong with it.
Your users manual should cover oiling the machine - there are predetermined points at which you drop the sewing machine or 3-in-1 oil into. Only a few drops are necessary, but you should oil it every few hours of use.
Jan 11, 2014 | Omega 6147 Sewing Machine
Bl4-736d serger foot control very hot and speed of machine slow to stop
sounds like the foot control needs to be replaced.
Jan 24, 2013 | Sewing Machines
Sewing machine stops sews a minute slows down or stops then starts up
I suggest having the machine checked at a sewing machine shop
to see if there is something wrong with the motor, or the foot pedal
but first check to make sure the power cord & foot pedal are
connected correctly
Aug 20, 2012 | Singer Sewing Machines
Sewing slows after use
The manual: http://www.singerco.com/uploads/download/446_5040_5050.pdf
Jan 08, 2012 | Singer 5050 Mechanical Sewing Machine
Euro-Pro Shark 80 - 7133 Logo
571 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Derek Massey
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
