Question about Canon ES50 8mm Camcorder
A tape won't eject, how can i get it out? I have a Canon ES10VA, it's pretty old. It won't power up at all, it's completely dead and won't eject the tape. I need to get the tape out though and I've taken off the tape door but don't know what to do now to get everything out manually. I need some guidance, a picture, something! I am tempted to just rip everything out, but if there is a correct and easy way to do this that's what I would prefer. I couldn't find my model on the product menu so I put anything, but it's an ES10VA analog camcorder that takes 8mm tapes.
  • 2 more comments
  • kim747 Jun 22, 2008
    No, as I mentioned it's completely dead, it won't power up by any means. I've tried a cord and a new battery. I've since purchased a new camera but forgot there was still a tape in this one from a couple years ago. I am archiving all my 8mm tapes on DVD, and this one is the only one I was missing. It's all footage of my son so it is very important to me to get the tape out, I care nothing about the camera.
    As I stated in my original post, I CANNOT power the camcorder up to eject the tape. I am asking for help to MANUALLY remove the tape because it will not power up to eject the tape. I have already taken the door off, I need help from here.
    Ok, I have no idea where the "lock" is so if someone has a picture I can look at that would be great.
  • kim747 Jun 23, 2008
    Someone has already given me a better solution.
    Thanks,
    Kim
  • Canon Master
  • 2,794 Answers
Can you plug the camera into an electrical outlet and eject the tape that way?
Posted on Jun 22, 2008
  • 4 more comments
  • Tim Babcock
    Tim Babcock Jun 22, 2008
    My 8mm was acting on my too. I ended up replacing it with a DV.
    If you don't care about the camera, can you get the thing to eject?
  • Tim Babcock
    See if can take a knife or a thing object around the edges of the tape door and see if you can release the lock.
  • Tim Babcock
    Tim Babcock Jun 23, 2008
    You might not be able to release it. Are there any screws on the outside of the area where the tape is inserted? If you have a Timmy screw driver (like a jewelers size) you can unscrew them. That should get you access to the tape. You may lose some of the tape that is outside of the cassette when you take it out. As long as you don't touch it it should be salvageable. Then manually rewind the tape back into the cassette with the door still open on it.
  • Tim Babcock
    If there aren't any screws holding it in there, do you have a way of cutting it out of there?
  • Tim Babcock
    Its going to be tough to get a service manual for two reasons:
    1) Canon doesn't make service manuals available for any other products over the internet. I'm a copier tech I know how tough it is to get stuff from them.
    2) This is a very old camera.
    I'm only going to tell you in theory how to get this out. I'm a television producer and know how most of these products work so we can get it out after all you got it in.
  • Tim Babcock
    Sound good.
Camcorder is dead, need to get the tape out!
I would not recommend trying to remove a tape that is stuck Because the eject and load mechanism is controlled by a motor and you have to supply voltage to in the correct polarity to get the camcorder to take the tape in or eject it, that means that you would have to disassemble it.
That is the case with all camcorders - analog, digital, new or old. If you need the tape I suggest sending it in to a shop If you can do the repairs yourself
Dismental the camera. Try to locate the power board. have a look at the components near the battery connector or the power connector. there you will be able to locate 3 to 4 safety fuses. check the continuty. if found open replace it or jump them and and try to eject it.
you can also try to locate the motor for tape deck loading mechanism. Remove the flex ribbion connector of the motor from the pcb, then try giving 3 volt supply from an external device to the motor in both the direction. in one direction it will move the deck outward, but be carefull when the cassette is being ejected a little portion of the tape may get damaged.
Jun 22, 2008 | Canon ES10V Camcorder
Canon zr700 won't play tape
That is the pinch roller. If it does not press the tape against the capstan, then the tape will not pass the read/write heads. Replace it.
Jun 25, 2017 | Canon ZR700 Mini DV Digital Camcorder
I have a NV-DX110B about 11 years old. I'm getting
Your camera appears slightly older than mine so I will do my best for you. Have you tried ejecting the tape with the power off? If I have problems I slide the eject button when the camera is off but plugged in and the tape can be ejected. I suspect the tape mechanism is in trouble. When a tape stuck in mine I had to literally force the cover open. But this is a last resort.
Give my suggestion a try and apologies if you have already tried that...
Sep 11, 2011 | Panasonic Video Cameras
Tape won't eject on Canon Optura 20 MiniDV. About
This can be caused by several problems including a defective eject switch in the cameras internal circuitry or a bad motor and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Jul 30, 2011 | Canon Optura 20 Mini DV Digital Camcorder
Canon mv940 camrecorder won't power up even with charged battery
My friend went back to England and got it sorted there
Thanks
a
Sep 06, 2008 | Canon Video Cameras
Canon Elura 100 won't eject tape
I have been having the similar problem. Try switching the power to off and then eject the tape in the off position. My finally ejected.
Apr 04, 2008 | Canon Elura 100 Mini DV Digital Camcorder
Tape deck won't eject tape
The tape might be wrapped around the head or the capstan. The mechanism is delicate so you risk more damage by trying yourself - check with some of the repair shops on the Fixya home page for prices to remove the tape.
Dec 17, 2006 | Canon ZR10 Mini DV Digital Camcorder
Canon ES50 8mm Camcorder Logo
377 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
