Question about Amphion Mediaworks S99 DVD Player
Amphion Mediaworks S99 DVD remote does not work
As others have noted, the remote for our Amphion Mediaworks S99 DVD no longer works. The universal remotes I have looked at do not list this company among those with codes. Can you suggest a remote that would work?
  • 3 more comments
  • roddym Aug 02, 2008
    need to switch off subtitles on the V99
  • priselizz Aug 15, 2008
    i lost my remote need code to use for universal remote
  • drvnsharma Dec 23, 2008
    YES
  • imalibra Feb 15, 2009
    Doesn't work anymore
  • Anonymous May 23, 2009
    the s99 remote doesn't work, tray will not open
Same problem
Posted on Nov 29, 2008
Where can I get a replacement remote control for an Amphion MediaWorks DVD player?
Amphion is no longer in business. Look on the web for a universal which will work and then find the codes you need. Both are on the net.
May 07, 2015 | Amphion Mediaworks Televison & Video
DVD won't play
Netflix doesn't know what they're talking about. I looked it up - your DVD player doesn't have an autoplay feature. Can you try the DVD on another DVD player. Computers DVD drives generally read them differently - and decode them differently, than a regular DVD player. Also, if your DVD drive is a writable drive, it will have a stronger laser than your DVD player. I think it's likely the disk is damaged, slightly. If you cleaned your DVD's laser, it might be able to read it well enough to play - or it might not. I started having problems like this with a few of my own DVDs before my DVD player's laser went out. Basically it's a combination of laser quality and disc quality. If it remains just this one disk, I'd suggest leaving it alone. But if you start running into this problem on other disks as well, you'll probably want to have the laser replaced in your DVD player.
Aug 14, 2007 | Amphion Mediaworks S99 DVD Player
I need code to program a GE remote to work with a amw DVD player
If it is a AMW model 99 Sanyo DVD codes will work for it.
Dec 14, 2012 | Amphion Mediaworks S99 DVD Player
Need code for an amphion mediaworks dvd player
I can help you with your URC-3021 Universal Remote Control issues.
I do not see a listing for Amphion Mediaworks DVD players in the One For All URC-3021 Code List.
But don't give up; many manufacturer's re-use others' control codes. Therefore, I recommend using the One For All URC-3021 Code Search feature to find the compatible codes to control your device.
I hope that helps.
_______________________________________________
One For All URC-3021 Manual
One For All URC-3021 Code Entry
One For All URC-3021 Reassign Key
May 20, 2010 | One For All URC-3021 Remote Control
Remote for DVD S99
I have great news for you.  Yes, there is a universal remote and it will operate the S99 and (I suspect) any other product you have.  I have been buying 'universal' remotes for more than 15 years and have NEVER found one to work until this one.  Logitech Hamony Universal Remote.  I had a $50 off coupon for Costco where it was sold for $100 (so I got it for $50).  My wife is so excited she can hardly stand it.  With 4 remotes in each room, she is clueless about how to watch TV again after it has been setup to watch something else.  But, with the new remote (all others have been stored away), she has all she needs.
No, I don't work for Logitech.  I just stumbled upon this and thought, what the heck, for $50 I'll try it and if it doesn't work I'll return it.  But it works!!!
Apr 02, 2008 | Amphion Mediaworks S99 DVD Player
Amphion M280 need tech info and phone numbers.
Hello gogo94804
I have bad news for you, Amphion Mediaworks is no longer in business. The closed their doors a few years ago. In addition there is very little to no service documentation on their products so finding a repair shop willing to repair these units will be a task in and of itself.
Your best bet is to buy a new unit, or attempt to find a shop willing to repair the unit. I have had 4 customers I had to turn away for lack of finding the proper documentation to begin repairs on their systems.
I even had one customer try to sue me because while I repaired his DVD player I had to use what I knew about DVD players, and he wanted copies of the service documentation, but refused to believe that there was no documentation.
So I do wish you well,
Thank you,
Shuttle83
Mar 27, 2008 | Amphion Mediaworks M-280 Portable DVD...
Find replacment remote
go to google then click on shopping it is the best way to get items hope this helps.
Mar 17, 2008 | Amphion Mediaworks V101 DVD Player
DVD schizo color
This could be a symptom of a board error, but before you get too close to the bin, check the cable connections. If you are using scart leads, they can sometimes come adrift at one end or other through thermal expansion and contraction. Make sure they are secured fully. You could also try changing the connection point on the TV if you have a spare, just to prove the input channel is OK.
Sep 28, 2007 | Amphion Mediaworks S99 DVD Player
Wrong region
i used this same procedure^on a different model. The number is entered via remote control pointing to the unit. after entering the right code, there should be a secret menu that will appear when you press setup , mine appeared as preference. On this menu, you can find the region. You can fiddle around, you cannot destroy the unit. The info is here: http://www.videohelp.com/dvdhacks/amw-v99/3349 maybe you can read what the other people have done.
May 14, 2007 | Amphion Mediaworks S99 DVD Player
Amphion Mediaworks S99 DVD Player Logo
713 people viewed this question
Top Amphion Mediaworks Televison & Video Experts
Electro Med Services...
Are you an Amphion Mediaworks Televison and Video Expert? Answer questions, earn points and help others
