LED Light display panel doesn't stay on?
When I push the select button to see voltages,etc. after a minute or so the LED light turns off? Is there anyway to have the LED panel display to stay on all the time, or is this normal operation?---Model GS-1285U
aborcass
  • 2651 Answers
SOURCE: Always dispenses CRUSHED ice
try removing the ice bucket, and on the back wall is a hole approx 1.5 inches square that the brass bar attached to the rear of ice container inserts into,(you may have to put hte container back in partilaly to look under and watch where it slides into) inside thatcut-out is a plunger that slides up and down activating the crushed/cubed option.you can sick you finger in the hole you should seee a plastic hoop that would catch the brasss bar.Try pushing and pulling hte hoop up and down if it does not move freely, youll need to replace the solenoid assy. if it does, then pull allthe way to the lowest positon and make sure when replacing the ice container that the bar falls with in the hoop itself
Posted on Mar 22, 2008
dsacco86
  • 1077 Answers
SOURCE: will not turn on
This might help you. Try starting on page 27 of this:
http://www.scribd.com/doc/6528782/Philips-42pf7320
Posted on Apr 05, 2009
SOURCE: the kitchenaid dishwasher (model KUDC25CHSS1)
On my unit, I had the same problem (child lock LED on, or flashing.The cancel process of pushing anything was not possible, as a bad/stuck switch prevented any input from the control panel buttons.
The underlying cause of the problem turned out to be a faulty switch associated with the "Light China" button. I determined this by removing the control panel from the door and using a digital multimeter with OHMS and DIODE settings, was able to check each individual push-button switch using the following table to check the 12 switches (applies to the KUDC25CHSS1 model).
There are 2 ribbon cables, it is the larger of the two cables you need to check. Pin 1 is noted on the ribbon. You can use 2 normal sized paper clips to insert into the ribbon cable and make your connections. (My Ohm meter has aligator clips on its leads which helps a lot...maybe another set of hands would help if you don't have these kind of leads).
-Using OHMS: the reading should be infinite (open circuit, so no reading/no connection inside the switch) when not pushing the button, otherwise you will receive a reading when you push the switch.
-Using DIODE/beep: Ensure polarity is followed in the table below. When connected, pushing the associated button will cause a beep to occur, otherwise there will be no beep and no reading.
+Positive Lead -Negative lead
Antibacterial Sw 13 3
Rinse Only Sw 13 2
Light China Sw 11 2
Normal Switch 13 4
Delay Switch 11 4
Energy Save Dry 13 5
Cancel 12 5
Start 11 5
Soak & Scrub 12 6
Super Scrub 11 6
Short Wash 12 4
Sani Rinse 11 3
All my switches checked out OK, except for the "Light China" switch. On the OHMS settings I was never able to measure an open circuit for that switch, which means the switch was always closed. or connected.
I noticed that "Light China" was pin 2 and "Rinse only" also used pin 2, which happen to be cycles I never use. With power turned off, I carefully removed some of the plastic surround of the matching connector on the Control Board right next to it's associated Pin 2 all the way to the bottom. Then I carefully bent over pin 2 as close to the connector base as possible. Making sure all the remaining pins were straight, I plugged on the control panel ribbon cables and all is well again.
Prior to trying this I was resolved that I needed to buy a new dishwasher because I wasn't going to pay over $350 for a new control panel. Instead, I eliminated 2 unused cycles at no cost, and maybe I can get some more use out of this dishwasher.
Posted on Aug 02, 2010
  • 212 Answers
SOURCE: my samsumg as18fb does not work
its an electrical error.when u serviced your air conditioner for the last time?
Posted on Aug 15, 2010
Macmarkus
  • 2605 Answers
SOURCE: Re: Model # 665-17039401. Clean light
Hello, Welcome to FixYa.
Based on your description, "clean light stays on" this is actually an error code as you may or may not know associated with the heating process. What typically happens is poor water circulation preventing the water from heating properly.
To resolve this, I'd start with the following...the wash pump area. You`ll need to follow these steps to clean it.
1 ) Remove the turbo wash tube if applicable to your model, it pulls off, i.e.
2 ) Spray arm removal. hold the center nut and spin the arm.
3 ) Now you can remove the upper spray arm supply tub or referred to sometimes as "rear feed cap".
a ) lift to depress the rear tab, i.e.
b ) Then twist the feeder to the right ( clockwise ), i.e.
4 ) Now you can remove the center nut...
Then remove the four # 20 torx head screws holding the filter in place, and lift the filter out.
Below the filter you`ll find food debris, undissolved detergent etc, but also a cover with a single #10 torx head screw to remove and the cover will pull straight up and out. the arrows from left to right in the image indicate...
1) screw location
2) tab to pull up on
3) the latch you may need to twist to the left to remove the cover
i.e.
Now you should see the chopper and screen assembly, it too can be clogged up pretty bad, clean it best you can...you don`t really want to remove this part.
If my explanation is not clear enough, here`s a link which provides a pretty good video of how to do this, these guys aren`t pro`s but the "how to" video is pretty thorough nonetheless.
http://www.youtube.com/watch?v=iRCCrEwrst8&NR=1
Once these actions have been performed you'll need to clear the error code. to do so is as follows.
Press the following buttons in this sequence...
HEATED DRY - NORMAL, HEATED DRY - NORMAL, HEATED DRY - NORMAL
This diagnostic cycle may take approx. 15-20 minutes to complete. Let it proceed through to completion and you should be good to go...unless the heater itself is at fault or a wire has vibrated loose from the heater...those are steps to follow if OR when necessary.
Let me know how you make out, please keep me informed if you need further assistance or anything is unclear. Please take a moment to rate me assistance and a short testimony is appreciated as well.
Thank you for choosing FixYa and good luck.
Regards,
Macmarkus :)
Posted on May 10, 2011
I got a Netgear WNCE2001 today. My router is a Verizon router. (The one with the WPS button on the front.) The security password is in WEP. When I try to connect it with WPS, the light on the WNCE2001 just...
which light is blinking ?
may be this help you ?
2. Select a radio button.
• Push and Connect (recommended). Either click the button or press the WPS
button on the rear panel of the Internet adapter.
• PIN Number. Select the radio button and a PIN displays.
The Internet adapter tries to join the wireless network for 2 minutes if you are using Push
'N' Connect, or 4 minutes if you are using a PIN.
3. Go to the router.
• If you are using Push 'N' Connect, press the router's WPS button.
• If you are using a PIN, log in to the router and type the PIN from your Internet adapter
in its WPS screen.
4. Go back to the computer that is connected to the Internet adapter, and make sure that you
are connected to the wireless network.
• When WPS is running, the WLAN LED blinks, alternating between green and amber.
• If the computer does not to connect with WPS, the WLAN LED is solid red for 5
seconds.
• If the computer does connect using WPS, the WLAN LED is solid green for 5 seconds
Then the WLAN LED returns to indicating a wireless signal.
Feb 12, 2014 | NetGear Computers & Internet
46L5200U LED back light shuts down after about two minutes. You can see picture using a light source sound is also fine.
There should be some fault with its back-light inverter board. Either it do fail to work after some time, or it losses supply voltage after some time. You should check both these possibilities. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Oct 23, 2013 | Toshiba 46L5200U - 46in Class 45.63...
Where is the reset button on a mitsubishi dlp 73' tv?
  • Open the front panel by pushing on it. Pressing on the panel releases the lock and allows the front panel to pop open slightly. Pull the corner gently to open the panel completely.
  • 2
    Use a pointed object, such as the sharpened end of a pencil or the tip of a paper clip, to push the "System Reset" button.
  • 3
    Wait about one minute, or until the green LED light on the front panel display stops flashing.
  • 4
    Turn your television back on once the green LED light turns off.
    this is procedure for most mitsubishi dlp.
Oct 15, 2013 | Televison & Video
What do you do to get the error codes?
try to reset the
  • 1
  • 2
  • 3
  • 4
God bless you
Jul 27, 2013 | Mitsubishi WS-55859 55" Rear Projection...
Display light of HP9250C control panel is not working, how do I troubleshoot it.
Building a simple light-emitting diode (LED) light display can be a great project for both children and adults. A simple LED Display Light can be built using
several LED lights, a resistor and a battery. Once the LED lights are soldered together, they can be mounted in virtually any container or mounted to a board
in a pattern of your choosing.
1.Solder the positive (red) lead of the battery holder to one end of the 1K ohm resistor.
2.Attach the free end of the resistor to the positive lead of the LED. The positive lead of the LED is the longer of the two leads. Solder the negative lead
to the positive lead of the next LED. Continue to wire the LEDs, negative to positive
3.Attach the negative (black) lead of the battery holder to one lead of the push-button switch. Solder the other push-button lead to the negative side of the
last LED.
4.Connect the battery to the battery holder. Activate the push-button switch; the LEDs should light up.
5.Disconnect the battery, if needed, to mount the LEDs to your chosen container.
Sep 08, 2011 | HP 9250c Printer
I my projector is new one used for 4 hrs, when i try to turn it on it just has a blinking green light. Please help Solve It! .
The blinking green light means the unit is either Powering On (Warming Up) or Powering Off (Cooling Down).
Powering On the Projector
1. Remove the lens cap.
2. Securely connect the power cord and signal cable. When connected, the ON/STANDBY LED will turn Amber.
3. Turn on the lamp by pressing " " button either on the top of the projector or on the remote. The ON/STANDBY LED will now turn Green. The startup screen will display in approximately 10 seconds. The first time you use the projector, you can select your preferred language from quick menu after the startup screen displays.
4. Turn on and connect the source that you want to display on the screen (computer, notebook, video player, etc). The projector will detect the source automatically. If not, push menu button and go to "SETUP". Make sure that the "Source Lock" has been set to "Off". If you connect multiple sources at the same time, press the "SOURCE" button on the control panel or direct source keys on the remote control to switch between inputs.
If you are still unable to get the unit to turn on, try unplugging it for 10 minutes and plugging it back in. If it still ceases to work, contact Optoma here: http://www.optomausa.com/rma_policy.asp
Their Technical Support line is 1-888-887-5001
Feb 25, 2011 | Optoma HD20 DLP Projector
The display works (clock, mode, etc) I can push
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Apr 27, 2010 | Whirlpool GH9176XM Microwave Oven
The problem is that when turn on the television
The red led lightsbut doesn’t turn to yellow after power on and black display
power on,checkXP801 4 pin standbyis low≦0.5Vvoltage
IF YES...(if no goto *)
checkXP801 pin 11,D6V
XP801 pin 9,VDD
IF yes
check I2Cbus
IF normal
1、check VPC3230、PW1235power circuit
2、check VPC3230、PW1235reset voltage
3、check VPC3230、PW1235peripherally circuit
IF abnormality
check buscircuit and PCBwire
*if no
check N803、N804output voltage
no
1、check PW113power impedance
2、checkN803、N804
yes
check X3 14.318Mcrystal
no
change Y2crystal
yes
check PW113RESET pin voltage
no
checkresetcircuit
yes
check AM29LV800BT toPW113 address、data、control
changeAM29LV800BT orPW113 and wirebetween them
D6V:steady voltage to 5V supply for VPV3230、AD9883 analog power;5V-ST:standby power,to PW113、AM29LV800BT(ROM)、24LC32、MAX202E;VDD(3.3V):VPC3230、MST9885、DS90CF383 power;+32V:RF tuner tuning power;A6V:steady voltage to Av board 5V etc. ;A12V:steady voltage to AV board 8V etc.;12VAMP:sound amplifier TA2024 power
Apr 18, 2009 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Computers & Internet Logo
122 people viewed this question
David Payne
David Payne
