Question about Alesis M1-Active MkII Main / Stereo Speaker
Fried Woofer I turned on my speakers and there was no signal being sent to the amp. very strong smell of buring. Thought it was a power supply (wall wart). Then saw smoke coming from the speaker cab. Woofer fried. Took both cabs apart and did check on speakers. Dead speaker showed .7ohm. Good speaker was about 7ohm. Tried to test amp by hooking good speaker to it. Bad move - fried the other woofer. Looks like something has failed on main board and sending high voltage to speaker. very pissed off with this as the units are just over 1 year old. Cant believe that Alesis has designed a board that has very little protection for the speakers. have been thinking about repairs and buying new woofers but can anyone tell me if this problem will keep happening. If anyone knows what part of the board needs replacing please tell me. But - even if the amp circuits are repaired what are the chances of this happening again? Anyone got a circuit diagram? Thanks for any help. Mezzy
  • mezzy Nov 29, 2008
    thanks for your help - but ended up throwing them away. did not wish to try repair for same thing to happen again. the spares are 2 expensive. going for a better make instead
  • mezzy Nov 30, 2008
    Hi again,
    The small parts are, as you say, not that expensive and I was going to repair the electrronics. But what put me off was the cost of the speakers. They are a silly price. OK - I would have paid the price if I had faith in the electronics. But my speakes died after just 13 months - just out of warranty.
    I decided that the protection for the speakers was rubbish and that it could easy happen again. If the circuits fail then full power goes to the coils and burns them out. It is a very poor design. I cant believe that there was no safe guard to stop this happening.
    For a few pence more a fuse or some other device could have been added to the speaker supply making certain that if excess power somehow got past the other stages then it would not ruin the speakers.
    When I do get new units I shall be looking for non powered ones.
    Thanks for your help. Hope that other owners of these speakers do not have the same problems.
    Problem Solver:
  • 13 Answers
The problem are worsen that before. It is wisely to replace both left and right amplifier
IC, but make ensure that the power supply feed a good amount of voltage to amplifier,
Also a strong good signal. Be sure to measure it.
r_ic7
Posted on Nov 29, 2008
  • Rick Foster
    Rick Foster Nov 29, 2008
    Im so sorry ! the common problem in your area like that parts are true expensive
    Example : 2pcs of TDA 7294 IC for the left and right power amplifier ?
    But doing the job is so easy ?and the thermal protection is the fuse and heat sink.
    Base on my experience its better to replace them both rather than to made it cheaper
    by replacing one by one to get rid of happening again.
    I foresight the the future and the warranty period of the job.if well done
    Thank's thats all.
    r_ic7
Mackie SRM 450, the main speaker has stopped working but the tweeter is OK, there is nothing coming from the speaker at all, no hiss, or clicks.
It could be 2 things:
*Blown Speaker or,
*Fried power amp output stage of woofer, since this speaker operates as a bi-amplified system it has separate amps for woofer/tweeter...
Aug 17, 2011 | Mackie SRM-450 System
No I cant get my sub woffer to work woofer.There is power to the unit .I am trying to connest it to a sound bar which has a sub out.
If there is power to the woofer then a signal input must power the woofer to work. So feed a test signal or a audio siignal from a DVD and if there is no output then the AMPLIFIER section had faults.
Unless the sealed unit is opened it cannot be tested to confirm if the output , the input to the AMP or the power supply has failed.
Check if there is power to the output section to confirm.
Jul 29, 2011 | Proficient S12 Subwoofer
My subwoofer sometimes turns on and sometimes it don't. I've noticed that when i disconnect the power cord from the wall and connect it back the light/volume doesn't turn on. Also when i turn the amp too...
Subwoofers produce very high levels of vibration due to the intensity of their job. But the problem you are facing is a problem with the power pack. The power pack on the woofer is not supplying properly therefore the light/volume not coming on when the unit is unplugged and replugged. This also affects the woofer when you turn the amp to high because as a result of the power coming from the amp not being properly distributed instead of the power which flows into the woofer from the amp is not distributed accordingly it could blow the woofer so before it gets to that stage the unit shuts down.
All you have to do is get an expert to help you get and replace the power pack.
Hope this solution has been helpful?
Jan 01, 2011 | Infinity Modulus System
To all experts: Hi! I have a Cerwin VegaLW15 Subwoofer for some years, now when I play music the sound rattle, first I thought the some wrong with the driver put a new 15" woofer in it does the same...
Is the rattle random or related to the source signal?
It could be excessive low frequency content or resonance. Since it's intermittent you might want to determine what conditions lead to the problem and see what changes affect it. Proximity to a turntable will almost certainly cause feedback, for example. Cables should be routed away from strong sources of magnetism or power supplies.
Dec 09, 2010 | Cerwin Vega LW15 Subwoofer
It will not power on
henrylshelt,
Your sub should turn on into standby mode when plugged into AC power without being attached to the receiver. If it does not follow the list below. If it does, the sub needs a signal from your receiver via either by line-level (RCA) or the speaker wires to turn on out of standby. Ensure that the cable or wires going to your sub is in fact sending a signal while the receiver is on. To Test, (speaker wires) hook up a different known working speaker; (line-level) Some receivers have a menu option to turn the LFE output on and off, ensure that it is on and producing a signal.
Diagnose the problem:
1) Remove all wiring to/from the unit except for the AC plug (use a different known working AC outlet), will it turn on? If so the other outlet is not working.
2) Remove the woofer, does the amp have a fuse that need to be changed? Change the fuse. If it blows again after replacing and turning back on, the speaker is blown; go to #4.
3) Unplug the woofer from the amp, does it turn on? If so, go to #4.
4) The sub need to be serviced. http://www.jbl.com/EN-US/Support/Pages/SupportOverView.aspx
-Hope this helps, Chris.
Aug 29, 2010 | JBL PSW-D112 Speaker
Connect stereo amplifier to powered sub
You can y out from the main out to the sub.This output is post volume control. set level on sub to desired balance of lows feq to highs
Nov 20, 2009 | Yamaha YST-SW015 Subwoofer
Boston Acoustics VR960 Crackle
I just finished repairing one of my VR960 units with a similar problem. My problem was that the sub would crackle no matter what input level. After changing a few of the active components, I finally discovered it to be a capacitor which was faulty. Anyway, I replaced the three 100uf 25V capacitors on the main board and all was well.
Good Luck.
Jul 07, 2009 | Boston Acoustics VR950 Main / Stereo...
Fried electronics in KLH ASW10-120B subwoofer
It is a 4 ohm nominal impedance woofer. If you put a new woofer in, it will last maybe half an hour and then fry/melt. The problem is the amp, not the woofer. Throw the amp out and use the box as a passive sub. Get a 100 hz sub crossover.
Dec 03, 2008 | KLH ASW10-120 Subwoofer
Sub-woofer Malfunction
sub can be detecting signal from your amp. maybe your amp has some small output when in standby mode. some amps throughput signal from satellite boxes when they are supposed to be off.
try shutting off that signal source as well.
good luck
mark
Dec 28, 2007 | Sony SA-FT1H TV Speakers
Wsp150 transmitter failure
The following alternative may solve your problem:
Check to make sure the volume on the audio source is set to a normal volume. If the volume is too low, the transmitter will not turn on.
Apr 01, 2007 | RCA WSP150 Main / Stereo Speaker
Alesis M1-Active MkII Main / Stereo Speaker Logo
366 people viewed this question
Top Alesis Audio Players & Recorders Experts
 Grubhead
Grubhead
shaqsatin
Level 1 Expert
Ben Armstrong
Are you an Alesis Audio Player and Recorder Expert? Answer questions, earn points and help others
