We have a Bosch Exxcel Washer Dryer and it seems that at the end of any programme, the washer does not drain and spin (but does drain and spin in independent programmes) - it just continues at 0.01 mins left rinsing with lots of water in the drum
  • 66 Answers
Would try cleaning your pump and sump as when its draining without the force of the spin the pump is idle but with the force when you put on other programs ie the spin this will push the water through the pump hope this helps
Posted on Jun 22, 2008
Bosch exxcel washing machine/dryer
Is it waiting to heat up? Try it on a spin cycle and see if it stops. If not, it may be a thermostat fault or heater element not working. Worst case may be timer faulty
May 21, 2012 | Bosch Exxcel WFO 2264 Front Load Washer
I have got a Bosch Exxcel WAE 244 64GB?03 FD Washer. I have noticed, that duricng the cicle, it can be on a cotton wash 42 min before the end or 12 min before the end, that while not rotating the maccchine...
Hi ritarorschac,
I believe you have something obstructing the Drain Pump Impeller.
Please follow my Tip below, for detailed directions on how to access, drain & clean your Drain Pump Filter:
DRAIN PUMP FILTER
Hope this helps :-)
JEDEMEYER1
* If you found this solution helpful, please rate it
Jul 13, 2011 | Bosch Exxcel WFO 2865 Front Load Washer
My little boy put my bosch exxcel washer/dryer on to dry for 2hours and then switched it to drain and then turned it off, now its stuck halfway through drain and the door wont open.
i have never worked on this type of washer dryer combo, but just from experience if a washer will not unlock and it keeps trying to drain it is either there is enough water in the unit to trip the pressure switch and the pump keeps trying to drain, means there is a blockage normally in the pump, blocking the pump, or blocking the pressure switch tube. clean these out and unit should work fine. if you arnt tech savvy , call a professional and be prepared to pay.
Nov 24, 2010 | Bosch Washing Machines
Bosch exxcel 1200 express fault code f04 what is it
i had this problem,no drain or spin,opened the flap at bottom right hand corner and pulled out small hose to drain machine opened circular filter cover (some water may come out) and found a 5p and 1p blocking filter after removing ,machine worked fine.
hope this helps
Apr 02, 2010 | Bosch Exxcel WFX 2467 Front Load Washer
How can I turn off the beep sound on my exxcel
I've just found my instruction manual and managed to turn the volume off on mine after 6 months of annoying beeping.
You turn the programme selector to off then turn it one programme to the right, press the rpm button and keep it pressed while turning one more programme to the right, release them both and a number should be displayed on screen I think volume 2 is the default one. You then click the "ready in" button until desired volume is reached. You have a chioce of zero through to four. After volume is set turn programme selector to off position. The annoying beep should be no more!! Hope this helps others.
Feb 15, 2010 | Bosch Washing Machines
I have a Zanussi WDA1055W washer/dryer. I never
the water should only be filling up to approc 2in above the drum bottom...........look inside when its filling..........if its filling to nearly the bottom of the door you either have a faulty pressure switch or grit/dirt in the internal filter.......as a result the machine will not spin if there is too much weight in the drum
Feb 23, 2009 | Zanussi F1045W Front Load Washer
DRUM NOT SPINNING
Disconnect your washer's plug for 5 minutes or more from the wall socket. Plug in. Press "end of cycle" button for over 5 seconds, the child lock comes off.
Press it again and the child lock comes on................ If this does not work, try the pre-wash button likewise.
Nov 22, 2007 | Bosch Exxcel WFO 2264 Front Load Washer
Washing Machines Logo
180 people viewed this question
Top Washing Machines Experts
