Unable to access restore-point feature
Recently I attempted to access my restore-point feature to reset my system to a recent-past restore point. I clicked on the "System Restore" shortcut icon on my desktop-(which I have used repeatedly in the past w/no problems. This time however after clicking on the icon, nothing occurred. I also attempted to open the feature going thru the Programs menu, also with no success. I then went thru Windows Explorer, found the Restore sub-folder under System32 folder under the main Windows folder, and clicked on the "rstrui.exe" file, also with negative results. Upon rt-clicking on "My Computer", then clicking "properties" for same, it displays the usual tabs; General, Computer name, Hardware, Advanced, Automatic Updates, Remote, but there is no tab shown now for; "System Restore". I'm not sure why this tab isn't shown, but I am unable to access the restore feature thru that tab. My feeling is that the program is still there, but is somehow disabled, and I am at a loss as to how to access it to enable it, if this is indeed the problem. I am running Windows XP-Home edition with SP-2, on a Systemax Ascent A30 AMD-Athlon, purchased in 2004. Any ideas? Thank you!
George
  • gw9095 Jun 23, 2008
    Tried this solution using F8 Key during boot-up to go into Safe Mode, same results, System Properties window still doesn't display the System-Restore tab, nor can I access it thru the Programs-Menu or clicking on the rstrui.exe file direct. In Safe Mode the shortcut icon for "System Restore" isn't even displayed on the desktop when in Safe Mode. Any other suggestions? Thanks!
    George
    President:
  • 1,314 Answers
Try booting into safe mode and accessing it from there.
To get into safe mode, press F8 when you turn on your computer and keep pressing it until the menu appears from which you can select safe mode.
Posted on Jun 22, 2008
  • Kevin Shafer
    Kevin Shafer Jun 23, 2008
    In safe mode, click start, run, rstrui.exe. If that doesn't work, open a command window, change directory to the system32 folder and type rstrui.exe.
I'm getting this message every few minutes on a Vista system. Acrord32.exe-No Disk "there is no disk in the drive\Device\Harddisk4\DR4.
These instructions apply If you have "Adobe Acrobat Reader" installed, not if you have the paid for, full suite "Adobe Acrobat".
1. Completely uninstal "Adobe Acrobat Reader"
more details (troubleshooting):
https://forums.adobe.com/thread/755658
2. Reinstall (if you so choose) "Adobe Acrobat Reader"
http://get.adobe.com/reader/
or use an alternative (less bloated) PDF-reader:
http://www.tracker-software.com/product/pdf-xchange-viewer
Feb 14, 2015 | Microsoft Windows Vista Business Edition...
What do I do when I turn on my Dell latitude xt
There could be a hdd issue or a simple damaged file. Try recovering the system.
Unable to Access the Desktop. 1 Restart the computer.
2 Tap during startup until the Windows Advanced Options menu appears. If the Windows Advanced Options menu does not appear, restart the computer, and try again.
3 Press the until Repair Your Computer is highlighted, and press .
4 In the System Recovery Options window, log in as a user with administrative rights, and click
vista_button_left.bmp OK vista_button_right.bmp . 5 In the Windows Vista Recovery Environment, click to select your language, and click
vista_button_left.bmp Next vista_button_right.bmp . 6 Click System Restore.
7 In the System Restore window, click
vista_button_left.bmp Next vista_button_right.bmp to display the most recent restore points in chronological order. 8 Click the Show restore points older than 5 days check box for a complete listing of restore points.
9 Click to select a restore point. A good starting point is to attempt to restore from the most recent restore point. If this fails to correct the problem, then try the next oldest restore point until the issue is resolved. Any software installed after the selected restore point needs to be reinstalled.
10 Click Next and then
Knowledge Base
Sep 16, 2014 | Computers & Internet
I want to reset my hp mini 1000 i want to reset it like when i first bought it can you please tell me how to do that step by step thank you.
There are a couple ways to do this. When you bought the laptop you should have gotten a system restoration disk with it. To use this simply put it in the CD drive and it should autorun with simple instructions on how to restore your HP notebook to factory settings. The easiest way to do this is with HP recovery. For a full system restoration, press the F11 key during bootup and then select "Recover PC" from the menu. This is the simplest way to recover your computer, however it will not work if your computer is unable to start up. Note that this will not work if your computer is unable to boot, or if some of the files needed for the recovery are corrupted, which is why you may need the disk.
If your computer simply isn't running like it used to be due to something you recently installed, you could just try a system restore instead of a full restore. Go to your search bar in Windows Vista or 7 and type in "rstrui." This should bring you to the system restore file called rstrui.exe. Click on this and choose the earliest date possible. Note that you may have to check the box in the lower left that says "Show me more restore points," and that this will only work if your computer is set to create restore points often.
Jun 30, 2011 | HP Mini 1000 Notebook
I have an acer aspire one. i've had this laptop for 5mos now. however, recently, when i play music-videos-or any content relating to sound, it sends out broken up, static noise. my laptop in general has...
try to restore your system using restore point located in accessories/system tools, if problem still exist no other choice is to reformat your system, maybe your system infected with virus. antivirus cannot protect 100% of the system even it is updated regularly.
Oct 11, 2009 | Computers & Internet
Cant gain access to the management URL for wireless router
you can do all over again...look for the reset button (hole) at the back. You might need a paper clip or a pointed one to push it. Hold it for about ten seconds and it resets to factory default.
Aug 16, 2009 | Computers & Internet
Cant accesss veralink 327w configuration
Try pushing the reset button to restore the factory default IP address for configuration.
Aug 15, 2009 | Computers & Internet
BLUE SCREEN
you may have a new device that is bringing up this blue screen. start your system on safe mode and uninstall any hardware of software you have installed recently or use the system restore to revert your windows to an earlier date prior to the this problem. but remember that system restore works only when you have a major restore point or you have created a restore point in the past. if this fails, you may want to repair your windows installation by reinstalling it and choosing repair option. Cheers!
Jun 01, 2009 | Acer Aspire 5720 Notebook
System restore utility not getting activated by known methods
I'm a certified computer tech and have been doing this for years. system restore often causes more problems than it fixes. I recently ran into this issue on a friends computer. upon investigating his computer was infected with a nasty virus that infected all of his restore points. go to housecall.antiviurs.com or another security website and run a free online virus scan. check that first, if that isn't the problem try manually going into system restore and running it (start > all programs> Accessories > System Tools > system restore). it may be able to be fixed with the system restore. if not you may want to consider either taking it to a technician or backing up your files and reloading the comptuer.
Apr 17, 2009 | Computers & Internet
Want to reset the factory settings
If the issue started happened after installing/uninstalling some driver/software, Then you can use the System Restore option offered by the Windows operating system. This will help you restore your computer's system files to an earlier point in time. It's a way to undo system changes to your computer without affecting your personal files, such as e‑mail, documents, or photos.
System Restore uses a feature called System Protection to regularly create and save restore points on your computer. These restore points contain information about registry settings and other system information that Windows uses.
Feb 01, 2009 | Computers & Internet
Computers & Internet Logo
75 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
