Question about Jabra BT350 Bluetooth Headset Headset
How to hook up a Jabra BT350 bluetooth
I received a Jabra BT350 Bluetooth as an gift it did not come with instrutions so I am wondering how to hook it up to my cell phone
  • Anonymous Apr 14, 2009
    ii dont know how to hook it up to my phone ii need help..
  • marylyoakum Apr 23, 2009
    lost instrutions. can't make it air with my phone. also trouble getting blue lite to stay on , it only flashes
    Scholar:
  • 143 Answers
Make sure your cell phone's bluetooth is activated. Once you do that, you should be able to hold down the main button on the Jabra and once it turns on, it will connect with your phone.
Also, go to this site for Jabra. It links directly to the manual.
Posted on Jun 22, 2008
If it doesnt works the first time try again and again until the light stays blue then it should pop up your phone after 3 sec or so
hope it helpes ^^
Posted on Apr 17, 2009
  • 487 Answers
On your cell phone is a bluetooth section.
You need to pair the set to the jabra
code will be 0000
good luck
SOURCE:
I do not have my manual to sync my bt350 with my new phone how do I do this?
Before you use your Jabra BT350, you need to pair it with your mobile
phone.
1. Put the headset in pairing mode
• Make sure the headset is off.
• Press and hold the answer/end button until a solid blue light comes on.
2. Set your Bluetooth phone to ‘discover’ the Jabra BT350
Follow your phone’s instruction guide. This usually involves going to a
‘setup,’ ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the
option to ‘discover’ or ‘add’ a Bluetooth device.* (See example from a
typical mobile phone in fig. 5)
3. Your phone will find the Jabra BT350
Your phone then asks if you want to pair with it. Accept by pressing ‘Yes’
or ‘OK’ on the phone and confirm with the passkey or PIN = 0000 (4
zeros).
or go here http://www.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT350/Documents/BT350_UM_NA_EN_491.pdf
hope this helps
Jan 30, 2010 | Jabra BT350 Bluetooth Headset Headset
My jabra BT350
trying to pair my jabra to my lg vx8350 phone
Oct 06, 2009 | Jabra BT350 Bluetooth Headset Headset
Initialy i had used my jabra bt350 with sony ericson but now it is not getting paired with my present mobile
dude first of all you have to reset the passcode of your jebra bt350 then connect it from your parents mobile.
how to reset----
Press settings/connections/bluetooth/check both boxes; turn on, and make discoverable/click devices tab/turn the jabra off/then hold the ear button till the blue light is solid (not blinking)/click new partnership on the phone/click 0000 for the passcode. it should hook up.
Mar 06, 2009 | Jabra BT350 Bluetooth Headset Headset
Jabra bluetooth
you need to go to the Bluetooth menu on the phone and select "Add Device" then search for your headset.
Jun 22, 2008 | Jabra BT350 Bluetooth Headset Headset
BT350
try turning bluetooth off . first erase bluetooth connections on phone. turn off phone and take out phone's battery for ten seconds. put battery back in and turn on phone. plug bluetooth into charger for ten seconds and unplug it. try re-pairing bluetooth with phone. This worked for me!
Mar 06, 2008 | Jabra BT350 Wireless Headset
Connection prob
Brand New Jabra -BT350 won't work on my Nokia 6102i, I did everything in term of setting my phone properly to paired with the Bluetooth, My Phone Bluetooth light is on, and the device blue light is flashing as well, but it still doesn't work. the phone would ring, I hit the JABRA button to answer it.....still can't answer my phone... Please send your help to me at [email protected]
thank you all.
Nov 08, 2007 | Jabra BT350 Bluetooth Headset Headset
I couldn't get it to pair this morning
From the manual )link below),,,, 1. Put the headset in pairing mode ? Make sure the headset is off. ? Press and hold the answer/end button until a solid blue light comes on. 2. Set your Bluetooth phone to ?discover? the Jabra BT350 Follow your phone?s instruction guide. This usually involves going to a ?setup,? ?connect? or ?Bluetooth? menu on your phone and selecting the option to ?discover? or ?add? a Bluetooth device.* (See example from a typical mobile phone in fig. 5) 3. Your phone will find the Jabra BT350 Your phone then asks if you want to pair with it. Accept by pressing ?Yes? or ?OK? on the phone and confirm with the passkey or PIN = 0000 (4 zeros). http://www.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT350/Documents/BT350_UM_NA_EN_491.pdf
Jul 28, 2007 | Jabra BT350 Bluetooth Headset Headset
Jabra BT350 Bluetooth Headset Headset Logo
1,530 people viewed this question
Top Jabra Radio Communications Experts
Anthony Ward
Anthony Ward
Bobby G
Bobby G
Damen Wong
Damen Wong
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
