Question about Frigidaire Washing Machines
Frigidaire clothes washer model #FWT445GES1. The door wont stay shut, it pops open. The unit wont turn on even when I hold the door shut
I was having this problem. I thought the door catch was damaged but looked it up online and saw that it was intact. I was just about to call the repairman when I took another look and found that the rubber seal around the door was not properly seated. Duh! Almost cost me $100+ and lots of humiliation.
Posted on Jul 14, 2008
  • 413 Answers
Inspect the door catch for breakage. If door catch OK, the door lock assembly may have failed.
Posted on Jun 22, 2008
Why is my washer displaying a "DR" when I push start?
  • 1 Press any button on the display panel.
  • 2 Wait five seconds and then press and hold the "Start/Pause" button and the "Cancel" button at the same time.
  • 3 Open and shut the door. A "DR" error code indicates that there is a problem with the door, most likely that it has not shut properly. Check to make sure there are no clothes or other items caught in the door.
  • 4 Open the door and gently wiggle the door latch if the door does not click shut. Clean it with a damp cloth to remove excess dirt or debris that may prevent the door from latching into position.
  • 5 Close the door and re-select a new wash cycle and "Start."
  • Jul 25, 2014 | Frigidaire Affinity ATF6000F Front Load...
    Why wont my dryer stay running?
    Good Morning Friend,
    I understand that your Frigidaire dryer, model# FEQ1442ES, will not stay running. Please check to make sure the door is staying closed. If the door is opening in mid-cycle, then the dryer will stop running. Also, make sure the plug is in the socket tightly. Your dryer could be shaking the plug loose, which could possibly be causing it to stop running. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
    -Best Regards-
    WP
    Jun 17, 2014 | Frigidaire FEQ1442ES Electric Dryer
    Affinity Dryer code E66
    It could be the door is coming open just enough to trigger the switch to the off position. Even though the door looks closed it could be partially open. Most likely the clips that hold the door shut are not tight enough that when the clothes hit the door it pops open a little bit. These clips are basically springs and over time they loosen up.
    Aug 24, 2012 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
    Frigidaire Front Load Washer Model LTF2140FS1. Put clothes in washer, fill detergent dispenser, close it, shut the door, set my cycle hit start then the door lock clicks, clicks again, panel shuts off....
    Make sure that the switch for the door is closing properly at all times. If not, unit will not start up or will shut down while operating because the switch has opened.
    Sep 12, 2017 | Washing Machines
    I have the frigidare affinity front loader washer and just started it up. It stopped about 5 mins into the cycle and the indicator light says dr. I tried to shut the door but that didn't work. So I...
    You need to replace the door lock mechansim. Fairly easy to do yourself, just pull the spring strap off the rubber door gasket and remove 2 screws holding door lock. Install new door lock and re-install door gasket and spring strap, and WALLA! she works:)
    Nov 28, 2010 | Frigidaire Affinity ATF7000E Front Load...
    My frigidaire affinity wont start
    Yes, the original issue was the control from the beginning. the control is damaged and it cannot register the latch at this point. this is necessary and , it will fix the issue.
    May 29, 2009 | Frigidaire Affinity ATF7000E Front Load...
    FWT445GES1 Washer makes loud banging noises like it's going to explode.
    Washer- you need a complete tub and bearring kit. this is a common problem for people who have well water. (also just happens) the rear yoke has become corroded and broken. its a costly repair.
    dryer - you would need a new front slider seal. very simple to install.
    May 28, 2009 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
    Washer door pops open during wash cycle
    Start the washer in a cycle. When the door locked light comes on, before unit gets to full of water, see if you can pull door open. If so, you probably have a broken latch. The wax motor is activating the switch, but latch is not actually closing. There was a door latch upgrade for some of these models.
    Oct 06, 2007 | Maytag MAH6500 Neptune Front Loading...
    Door clicks and wont open and washer runs but wont do anything
    Potential reasons for it: - Door Lock/Switch Assembly Failure - In this case it should be replaced. - Door Lock unit is broken or removed from the door. - Look for disconnected wires to the door Lock/Switch unit. - Door Lock/Switch unit Failure You should remove machine's top cover and then you will have an access to the door lock unit. Be aware you should discconect machine's power cable first !! Good luck!
    Jun 15, 2007 | GE WBVH6240F Front Load Washer
    Washing Machines Logo
    178 people viewed this question
    Top Frigidaire Washing Machines Experts
    Dan Webster
    Dan Webster
    Gerry Harvey
    Gerry Harvey
    Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
