Question about Fisher Paykel EcoSmart GWL15
Ecosmart washer will not stop filling
My washer will not stop filling with water. Even when the power is turned off the water flow continues, the only way to stop it is to turn off the water supply in the wall behind the machine. What can I do?
  • Anonymous Jul 01, 2008
    My Fisher and Paykel EcoSmart GWL10 continues to drip water into the tub even after completion of all cycles and with power turned off. What could be wrong?
    Novelist:
  • 161 Answers
It needs a new fill valve. These are not expensive and you can easily do this yourself.
Posted on Jun 30, 2008
F&P GW512 Will not stop filling
If the water continues to flow into the washer with power removed from the washer, ie; unplugging it, then the water valve is faulty.
Jun 25, 2016 | Washing Machines
Fisher paykel ecosmart washer won't fill or complete cycle
It can't get enough water so it flashers these lights
to tell you to turn your water on,
Your water valves are not fully opening to let enough water in.
You will need new water valves.
Oct 16, 2012 | Fisher Paykel EcoSmart GWL15
I put in a load. The machine filled up but did not stop filling. The dial did not proceede to next step, it stayed at the 10. Overflowing EVERYWHERE. When we moved the dial manually to spin, it drained...
your fill switch is either bad or "gllitched" and the timer cannot move until this switch senses the right amount of water for the load unless its an electronically sensed water/load capacity filled machine,when it starts,the water fills the unit and the pressure switch shuts the water fill off when at selected water level and powers the timer to continue the wash cycle,it works off a "bellows" on air pressure to change a switch by air pressure to operate the machine when full of water
Dec 27, 2010 | Kenmore 22622 Top Load Washer
My washer goes through the cycle but the cold
This sounds like your water fill valve is bad and will need to be replaced.
Feb 01, 2010 | Maytag LAT2300 Top Load Washer
Machine fills too slowly and continues to fill in whole cycle
Remove the water filler hoses at the machine and test the flow of each one. If very slow, check the inlet screens on the faucet ends for plugging and make sure the faucets furnish full flow. The hoses themselves can sometimes become restricting of flow--replace them if so. Next, check the inlet solenoids on the machine for proper flow and shutoff when the power to them is stopped. They may or may not be cleanable--replace them if they are trouble. Hope this helps!
Jan 10, 2010 | Admiral AW22 Top Load Washer
Water does not stop and will overflow
Hi, Can you get the water to stop by turning the washer off? If the water continues to fill when the power is off, you eill need to checnge the inlet valve. If the water does stop filling when the power is off to the waser, the water level switch needs to be tested.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 26, 2009 | Washing Machines
Water dose ot stop when washer is full. It continues to run.
If you disconnected power and water still flowed, replace the water valve. If water stopped flowing when power was disconnected, clean out tube from tub to water level switch.
Jun 07, 2009 | GE WDSR2080D Top Load Washer
Washer won't stop filling
if you can turn the washer off while it is still filling. and the water continues to enter the machine you have a bad inlet valve.
Do me a favor turn the washer to fill, with the washer still running unplug from the wall. If the water is still entering the unit you have a bad inlet valve
Jan 05, 2009 | Roper RAS8445KQ Top Load Washer
Fisher Paykel EcoSmart GWL15 Logo
152 people viewed this question
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
