Question about Planar XP17W (White) Monitor
Planar XP-17WSA-01 not staying on
My monitor will not stay on...I do know that it is receiving constant power though.
What can I do to resolve this?
  • 82 Answers
Sounds like an inverter problem
Posted on Aug 27, 2010
Planar monitor works but doesnt.
Try Another Monitor---If OK--Problem Is With Your Monitor---If Does The Same Thing--Problem With Computer Video.
Mar 18, 2015 | Planar Computers & Internet
The touch screen does not work
here is the user's guide for your touch-screen monitor :
(from Planar's website)
http://www.planar.com/media/87916/mn-planar-pt1700-01-m-mu.pdf
Feb 26, 2014 | Planar PT1700M 17 in. Flat Panel LCD...
On Planar PL1700 monitor, screen stays black after power failure
this is a common problem with the capacitor, try opening your monitor and see if there is a capacitor swalow like gonna blow... the capacitor has a form like a AA battery... if changing the capacitor the problem persist maybe is a problem with the board and you need to search if the board have continous power....
Jul 30, 2010 | Planar PL1700 17" Flat Panel LCD Monitor
I have a PE171 Planar monitor. goes black when turned on
Your monitor has 3 years warranty, I would find out if you can get the replacement before opening up the case.
http://www.planaronline.com/product/?id=997-2723-00
Feb 24, 2010 | Planar PE171 (Black) 17 in. Flat Panel LCD...
Won't stay on. When the power is turned on, an
Make sure you video cable from the computer is seated in correctly.
Dec 29, 2009 | Planar PE191M 19" Flat Panel LCD Monitor
Planar Monitor Wont stay on
Okay.... If you can. install your drive. It may work. If not then your Hardware in your monitor is screwed. Or maybe something else but not to my knowledge.
good luck!
Jul 14, 2009 | Planar PE191M 19" Flat Panel LCD Monitor
Planar PE191M monitor display will not stay on
iv come across this before sometimes people can see that the monitor is actually working but the light has gone out id say bad capacitors that are breaking down. if you want to DIY it take it apart and find the light pcb usually built on the power supply pcb and look for bulging or swolen capacitors this happens alot in my opinion. if you can DIY it get the same caps or same value but better ones. I might be wrong but worth a look
Apr 01, 2009 | Planar PE191M 19" Flat Panel LCD Monitor
Planar 2010M auto adjust
This may be related to a power supply problem that these monitor have. I think you need to fix the power supply board inside the display itself. It's giving the logic board and backlights fluctuating power and they have weird / intermittant problems.
There is a supplier of power boards online, you can google them with numbers from the board but I don't suggest using them. Look for information on the company before you buy from them. I've seen a lot of complaints for this "international" company.
First check that you are getting a strong 12V from the external power adapter. If so, the problems may be as simple as changing out a few capacitors. (about $8 in new capacitors, plus shipping)
On the PL2010M monitors you need the following parts. I've added digikey part numbers to make life easier:
P10271-ND 220UF 25V Capacitor (3 or 4 depending on PS)
P10275-ND 470UF 25V Capacitor (1)
P10221-ND 470UF 10V Capacitor (4)
If you're not comfortable with soldering and de-soldering electronics, take it to a local technician for the work and give them the parts list above. That should work to fix your issues. I've fixed several of these monitors so far. All the problems were related to the power supplies having bad capacitors. Same with the Planar PL1700 LCD monitors.
There is also a single capacitor on the display logic board, but I haven't seen this one go bad yet.
-Chip
Nov 22, 2008 | Planar PL2010M 20" Flat Panel LCD Monitor
PLANAR Flat screen goes blank and then wil not come back on, blinks a second then dies.
Hi...there
Sure, you can fixed by replaced the backlight inverter or repaired it.
Oct 31, 2008 | Planar PL1910M (Black) 19 in. Flat Panel...
Monitor will not stay on.
It could likely be the flyback transformer, usually found in the right or left rear corner of the monitor. Be careful though, it packs enough stored power to kill ya. ZT3000 "Beta tester of "0"s and "1's"
Aug 19, 2007 | Planar XP17W (White) Monitor
Planar XP17W (White) Monitor Logo
59 people viewed this question
Top Planar Computers & Internet Experts
William Miller
William Miller
Jay Plesset
syspro
Are you a Planar Computer and Internet Expert? Answer questions, earn points and help others
