Question about Samsung SCX-4216F All-In-One Laser Printer
Cru fuser error
How can i reset the cru fuser error?
I already solved the cru fuser error by replacing the fuse of the toner cartridge.Thanks anyway for this information.
Posted on Oct 07, 2008
Take out toner cartridge, remove fuse on back lower left side of cartridge, put cartridge back in printer - should work. you can then remove cartridge again and replace fuse - should still work. believe fuse is supposed to blow when toner empty to indicate time for new cartridge - sometimes this does not happen - removing fuse looks like blown and re-installing looks like new cartridge installed.
Display messge cru fuse error
Normally that means the fuser module has failed.
You can order and replace it yourself, I believe they are about $100.
That's what I paid for the last one I replaced.
You can call 1-800-835-6100 and order one.
All you have to do is remove the 4 screws that hold the back cover on, then remove 2 or 4 screws that hold the fuser in. Unplug a couple of plugs and slide in the new fuser. It is really an easy replacement.
Mar 31, 2010 | Xerox WorkCentre PE16 All-In-One Laser...
CRU FUSE ERROR
The "fuser" is the unit that melts the ink-dots into the paper,
to _permanently_ bond the ink to the paper.
That's why the paper always feels warm when being fed out of the printer.
If the fuser is not heating, you have a "fuser error".
Take the printer to a qualified Samsung technician, for trouble-shooting.
Oct 22, 2009 | Samsung SF 5100P Laser Printer
CRU fuse error , the machine is not working.
I'm guessing that it''s remanufactured?
There is a small fuse on the front of the cartridge that may have not been replaced (or not installed at all). This is required to reset the toner unit - it basically blows at installation.
You can try this -it applies to another similar model, but may work for your as well to reset manually:
Press "Menu"....1934 (you may have to press "#" before the number??)
display will read something like "Tech mode"
Keep pressing "Menu" until displays "new cartridge"
Then press "yes", or "ok" or whatever applies to reset.
Please rate me
Mar 30, 2009 | Samsung SCX 4521F All-In-One Laser Printer
I am having CRU fuse error in my SCX 4216f. i changed cartridge but same error is there. please help
This is a "Fuser Error" -not cartridge. Unplug machine and then plug back in...if error returns, you have a problem with the Fuser (warm up error), and you need service.
Mar 08, 2009 | Ricoh AC104 All-In-One Laser Printer
My samsung
I need fuser error solution as soon as possible please.
Apr 01, 2008 | Samsung SF 5100 Laser Printer
Have a cru fuse error
Rick and Felix are discussing the fuser, not the fuse error you are getting with the your printer. The error relates to a small fuse that is on the toner cartridge which goes into the printer. I am having a similar error message after getting a replacement from Cartridge World (although this is not the first Cartridge World replacement for this printer).
After much research, one suggestion was to remove the cartridge fuse and reinsert the toner cartridge. That worked for me and the CFU Fuse Error message disappeared for me, but I am trying to find out the PURPOSE of having a fuse on the toner cartridge itself. To protect the toner cartridge? Protect the printer? Other?
Mar 10, 2008 | Samsung SCX-4216F All-In-One Laser Printer
Double page copies and CRU Error
CRU Fuse error equates to a problem the machine has reading the print cartridge installed in the machine. It has nothing to do with the fuser.
Suggest that you change the print cartridge.
Oct 01, 2007 | Samsung SF 5100 Laser Printer
Samsung SCX-4216F All-In-One Laser Printer Logo
2,384 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
