Question about Car Audio & Video
Wiring I have a NECVOX.DA-7169.What wire or wires do i have to conect to the hand break.Please help.Thank you.
    Problem Solver:
  • 12 Answers
The plain white wire (next to the purple one) is the hand brake connection or you can connect it direct to earth to allow the dvd player to work without having to apply the hand brake. Cheers Neil H
Posted on Jun 11, 2009
I am getting hold ligth on on my dash board,when i start the engine,the engine fuse break,i have change the alternator n check all the fuses,if i disconnect the wiring from the alternator the engine runs...
There might be a short between the alternater and ground.
Check wiring
Disconnect battery and alternater wiring from the back of the alternater and with a multimeter check for continuity between the BAT stud on the back and the alternater housing.There shouldn't be any.
Apr 18, 2011 | 1990 Mazda 929
Could you please tell me me if an intermatic T101 single ploe single throw can be used to cpntrol a 220 volt pool pump. If so could you indicate me how to conect the wiring thank you
Yes... just wire one leg together and run the other leg through the timer...the one leg will always be hot, but that does not matter as long as you break the other leg...
heatman101
Aug 10, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Need a user manual for mosfet 50 Wx4 pioneer in dash
this wiring has different color of wiringneed. need right colors of power and negative wire to conect stero.
May 19, 2010 | Pioneer DEH-2300 CD Player
Where do i connect da pink wire
connect da pink wire to the ground wire on the stereo units wiring harness. This will tell it you are in park.
May 13, 2010 | Audiovox VM9312 Car DVD Player
06 sonata se 3 doors not working with keyless remote or main swit
eithoe a burned out reley
bad fuses
a bad switch
or broken or bad conections
check fuses then conections then switch for power then releys
likely it is the wiring or the switch
Jan 10, 2010 | 2006 Hyundai Sonata
Were do the two wires on a brake away control conect to wiring harnes on a travel trailer
The battery that powers the break away switch connects to the ground wire or to the frame. Normally the white wire is the ground. The positive will connect to one side of the break away switch and the other side will connect to the brake feed wire... normally the blue wire. This way when the pin is pulled, power will feed to the brake feed wiring. Also try http://www.etrailer.com/faq-wiring.aspx.
Oct 26, 2009 | 1996 Chevrolet K1500
Pull chain
this is the type of switch that attaches to one wire only do you understand?if connects to live wire to break the conection.
thank you for useing fixya
Please turn off main befor fix
RATE ME
Apr 20, 2009 | Solar 2-wire Pull Chain Light Switch For...
Kole kx2-1440 wiring da amp up right
It is correct to connect the amp turn on wire to the amplifier remote. 5V is sufficient to turn most amplifiers on... It should be 12V optimally.
If the amplifier is not turning on with the ant. remote, the problem is with the amplifier.
Dec 30, 2008 | Kole audio QX1-2400D Car Audio Amplifier
Car Audio & Video Logo
212 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
