Panasonic NN-H275 1100 Watts Microwave Oven
Problem for Panasonic NN-H275 1100 Watts Microwave Oven
Door
By jim_den863 on Jun 22, 2008
New at this. My door doesn't open. When I push in it doesn't release. The only response I get is how to earn money not yo fix the situation.Am I doing something wrong?
Comments:
Jun 24, 2008
- How do I remove the control panel on Panasonic microwave Model NN-H275.
Same Problem
Jan 07, 2009
-   Panasonic NNA773. I think I have the same sort of problem with my model, only my door open button doesn't appear to press on anything. So the door open levers are in the open position, and the door latches therefore not engaging in anything. How do I 'get into' the back of the button?
Joy-   tapsalteerie
Best Solution
posted on Jun 22, 2008
Helpful)
MicrowaveSvc
Rank: Guru  Panasonic Kitchen Appliances  Expert
Rating: 89%, 5360 votes
What usually breaks is the door open lever.
On a counter top model, the outer cover will need to be removed to diagnose and repair this. On an over-the-range model, only the control panel needs to be removed.
Please unplug the oven first.
If you or someone you know wants to look into this, we have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Once it is apart, you'll be able to see how the door open button would press against the door open lever, which would then lift up against the door latch heads (hook-like projections on the door) and the door should open.
If you reply back to this with your brand and model number, we can steer you toward a part source, and possibly toward exploded view diagrams, etc.
We're happy to help and we appreciate your thoughtful rating of our answer.
Comments:
Jun 24, 2008
- These generic files should help:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
Was this helpful?
Yes
No
Popular Solutions for Panasonic NN-H275 1100 Watts
Questions and Unsolved Problems for Panasonic NN-H275 1100 Watts
Do you recommend Panasonic NN-H275 1100 Watts Microwave Oven?
Answer
Answer
keypad stops working after few minutes. after waiting for while it starts to work again.
Answer
can you not invert blower motors to fume upward and not through the back
Answer
I have a Panasonic NN-SD986S microwave oven. Shortly after a power outage, I noticed the following:... (More)
Answer
The Microswave is running in demo mode. It appears as it is running with the light on and turn tabel... (More)
Describe your Microwave Ovens problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Microwave Oven Experts
Top Small Appliance Repairmen
in Newport, KY
(316) 283-4211
(316) 283-8664
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
