Question about Mitsubishi VS-50609 50" Rear Projection Television
Mitsubishi VS-50609 screen looks doubled when i hit reset to default sometime works abut most the time it doesnt even when it works after a while it goes back to double vision and warped look. when i try to adjust the colors it gets bettere but not perfect when the tv is perfect the graph bar is perfect but when the tv is not perfect the graph bar is bow looking with green lines and i cant adjust them please tell me how to fix it or what to have fixed thank you
  • r_starnes May 11, 2010
    Are these amps in the big heat sinks and with part#STK393-110 or close to that?
  • Anonymous Mar 22, 2014
    Bar tells me about the functions that are on the tv
    Genius:
  • 1,139 Answers
Hello billy218,
What is happening is that your convergence amplifier modules are beginning to go bad. These amplifiers are what amplify the signals used for convergence (how the RGB lights line up on each other) when they go bad the RGB lights tend to bow towards the center of the TV and the colors begin to mis-align. There are many sites devoted to doing the changing of the amplifiers yourself,however although these sites are accurate in give the instructions on how to change the amplifiers they do very little for actual troubleshooting and finding the underlying cause of the problem. In most cases its just that the amp modules have gone bad, but sometimes there is an overheating problem that triggers the damage. I would suggest having a TV repair person come to your place to check the problem and to fix it. The repair should cost about $250.00
Posted on Jul 13, 2008
Reset passcode for vs60609 Mitsubishi tv
check the english service manual
http://www.manualsdir.com/manuals/118985/mitsubishi-electronics-vs-60609-vs-70709-vs-60719-vs-45609-vs-55609-vs-50609.html?hl=ru
Mar 16, 2015 | Mitsubishi Televison & Video
Mitsubishi vs-50609 green timer light comes on no
Unplug the tv and leave it unplugged for a couple hours. Plug tv back in press reset button. TV led may flash for a day but should come on. I did this last night to mine and it came on at 11am today.
Mar 29, 2010 | Mitsubishi VS-50609 50" Rear Projection...
Mitsubishi VS-50609 won't turn on
What a great tv this is Mitsubishi did a fine job making this one, but......only an authorized mitsubishi servicer should repair it. This set records diagnostic led codes that the technician receives to help determine where the problem might be, not the problem, but in which circuit it might be. The one thing to try is, unplug the tv , let it set for a minute, plug it back in , turn it on and hope it reset the micro. Next , call for mits. service.
Jun 11, 2009 | Mitsubishi VS-50609 50" Rear Projection...
Have sound but no picture
Sounds like what happened to my hitachi. Power voltage regulator on the main pwr board.
Jan 24, 2009 | Mitsubishi VS-50609 50" Rear Projection...
My VS-50609 Big Screen tv is showing only black and white
Maybe your colour setting is wrong or worse your color tube is no good. You will have to change the screen settings (color). If it wont work probably color tube is gone.
Good Luck
Dec 12, 2008 | Mitsubishi VS-50609 50" Rear Projection...
Mitsubishi vs-50609 wont stay powered on
Hello nicolastran,
I gave this advice to someone with this same problem so here it is again:
It sounds like your shutdown circuit is being activated. This is due to excess current being drawn. This usually happens in the High Voltage section of the TV or one of the deflection stages. Due to the nature of this problem I would suggest that you take it to a local TV repair shop or have a TV repair person come out and take a look at the issue. The HV section is dangerous and should be dealt with by a qualified TV repair technician.
Thank you,
I hope this helps
Shuttle83
Jun 24, 2008 | Mitsubishi VS-50609 50" Rear Projection...
Mitsubishi Model # VS-50609
try to resolder the convergence amp ICs that may help if not the ICs may need to be replaced. Let me know if you need further assistance.
Jun 22, 2008 | Mitsubishi VS-50609 50" Rear Projection...
Trouble with my Mitsubishi VS 50609
Make sure you have no colent leking on the bord these set many I worked on had colent leaks that cused it to shut down. does the set come back on when it's cool? could be a bad soder joint. allso there could be bad caps. deos it come back on if you unpluge the set for 5 sec and plug back in that resets the set.
May 21, 2007 | Mitsubishi VS-50609 50" Rear Projection...
Mitsubishi VS-50609 50" Rear Projection Television Logo
241 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
