Question about LG enV VX9900 Cellular Phone
EnV2 keyguard How do I increase the time it stays off?
  • 1 more comment
  • Anblick Jul 08, 2008
    I'd like to increase the keyguard timer, but the answer here doesn't help me. Under "Settings & Tools" the only options I have are 1. My Account; 2. Tools; 3. Bluetooth Menu; 4. Sounds Settings; 5. Display Setting; 6. Phone Settings; 7. Call Settings; 8. USB Auto Detection; 9. Memory; and 0. Phone Info. I've looked under all of 'em and can't find anything about the keyguard. 7 seconds is way too quick for me! Any ideas how I can change the timer?
  • Anonymous Dec 05, 2008
    i want a shortcut to lock the phone.
  • cutiegirl13 Dec 13, 2008
    I have the same problem. UGH!
I just called Verizon about the keyguard being too easy to unlock and they were clueless. But here's a solution: As above, using the OUTSIDE keypad, click OK, go down to keyguard settings (number 6), then hit unlock options (number 2). This gives you the option of using a one step unlock process (hitting the OK key) or a two step (hitting the OK then the Clear). I think it is still too easy to accidently answer the phone but at least this will cut down on the dialing.
Posted on Jan 06, 2009
  • captenaj Jan 06, 2009
    To activate the keyguard, hold down the zero on the outside keypad.
Ok on the outside screen clickk ok to unlock or w.e rite then click ok so it shows you the menu then go down to keygaurd settings then keyguard timer and there you can change it also you can do the unlock options if you phone is recently updated to the new software. how to update to new software go to settings and tools down to phone info then software update check new an it should say connecting. what I want to know it from the keypad inside how can you lock the phone like with a password any help?
Posted on Aug 17, 2009
Look under "Settings & Tools", then "Keyguard Timer"? There should be several time options.
Posted on Jun 24, 2008
From the main screen, press ok once. You will see a numbered list of things (1. contacts 2.messaging, etc.) Scroll down to 6. keyguard setting and click ok. set your desired time and you are good to go!
Posted on Mar 17, 2009
Dude.. you seriously go through all those options to Lock the phone everytime you're done with it? That's insane! Isn't there a shortcut to lock the phone?
Posted on Sep 03, 2008
On the front screen press ok and go down to keyguard settings and from there you can change it to always off, 7 seconds, 15 seconds, or 30 seconds
Posted on Aug 28, 2008
Only thing I find to help me, from calling people accidentally or whatever else it decides to do while in my pocket is to lock the phone every time I put it up. A huge pain yes, but less embarrassing than unwanted calls etc.
Settings and Tools #9
Phone Settings #6
Security #6
Enter lock code(whatever you made it)
Lock Phone Now #4
I can answer calls, but to make one I have to enter the code first. Have to do it everytime.
Posted on Aug 26, 2008
They keyguard only helps sometimes. it's really pretty lame cause if you have anything in your pocket it is very easy to accidentally hit "ok" which in turn makes it easy to call or text people in your pocket.
it should be a series of buttons instead of just the one. i call people all the time without knowing it
Posted on Aug 14, 2008
You have to use the menu on the outside of the phone, looking under "Settings & Tools" then "Keyguard Timer"
Posted on Jul 09, 2008
From the manual, the shortcut to locking the phone without going through the menus is to hold the x character for 3 seconds on the inside QWERTY keyboard (doesn't work from the outer keypad); you will notice there is a little picture of a lock above the x.
Posted on Mar 24, 2009
There is no unlock options for my env2
check if your brother's phone and yours run the same firmware - if not update and all should have same settings.
Sep 01, 2009 | Verizon Communications enV2 Cellular Phone
Problems with my lg env2
Unfortunately the OK button and the bottom row of keys are a design flaw. Mine has stopped working from repeatedly being sat on. When you press the OK button in various directions, sometimes it will come back to life. The best thing I can suggest (if repair is not an option) is to mess with the OK button till it springs back to live, and then quick as you can press menu, keyguard settings, and turn that off, this will allow you to still use the front of your phone when the OK button goes out again (like I said, not permanent.)
Now, about that memory card. if you haven't formatted it for Verizon, you may want to do that. to do so go Settings>Memory(9)>Card Memory, hit the soft key for Options and format. Keep in mind if you have files on there that you do not have backed up they will be wiped clean. After its been formated, you need to take it out, put it back in, and restart the phone. You should have access to your card memory then. ^^
Aug 02, 2009 | LG enV2 EnV-2 VX-9100 VX9100 Premium Pink...
My env2 wont charge. whenever i plug it in, the battery stays the same. what do i do?
This seems to be a common problem for the env2. If you hold your charger a certain way in the phone does it charger? Is the charger port broken or damaged?
If so the easiest workaround is to get an external battery charger and extra battery to charge the phone.
Check out the following link for information on the battery charger and other options for the env2 charge issue.
Lg Env2 External Battery Charger Fix
Jul 17, 2009 | Verizon Communications enV2 Cellular Phone
The keyguard on my lg env2 does not work.
With the flip closed, press OK. #6 in the menu that pops up is Keyguard Settings. Select 6 and choose 2. Unlock Options. Then choose a 1 or 2-step unlock (OK versus OK and Clear)
Mar 17, 2009 | LG enV2 EnV-2 VX-9100 VX9100 Premium Pink...
ENV2 Keyguard Lock problem
When your phone is closed, hit OK for the menu, then hit 6 for Keyguard Settings. There, you can not only change the time it takes for the keyguard to automatically go on, but ALSO change the keyguard unlock options from One Step Unlock (just hitting ok) to Two Step Unlock (hitting ok then clr). It's not a 4 digit code, but it's a lot better than just hitting ok, and much more time efficient than locking your phone every time you put it in your pocket.
Oct 21, 2008 | Verizon Communications enV2 Cellular Phone
Keyguard
if you just need to lock the phone temporarily just hold the pound button for about 3 seconds and it will turn on key guard without changing settings.
Sep 19, 2008 | LG enV VX9900 Cellular Phone
LG env2 Key guard
The options for the keyguard can only be accessed from the front screen. If you open up the enV and try to find the option it's not there, so on the front screen go into Settings & Tools, Keyguard.
Jun 25, 2008 | LG enV VX9900 Cellular Phone
How to unlock your keyguard on your phone
Assuming you're trying to get past the keyguard on the outside screen, simply hit the "Ok" button twice
If you want to turn the keyguard off alltogether, go (using the outside screen, this is a must) to: Ok > Settings&Tools > Keyguard Timer > Always Off > Ok
That should do it.
Nov 09, 2007 | LG enV VX9900 Cellular Phone
LG enV VX9900 Cellular Phone Logo
3,445 people viewed this question
Top LG Cell Phones Experts
IT Solution
IT Solution
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
