Question about Seville Classics MSC10166 Tower Fan
Taking apart the fan
How do I take the fan apart and get to the inner fan? The fan was pushed over and a disc at the top of the fan is loose and I'm trying to take the fan apart in order to see what happend/and repair it.
Best, Austin
  • 1 more comment
  • Anonymous Dec 23, 2008
    I want to clean my fan, it seems to collect so much dust - but it is impossible!
    The manual doesn't have any diagram. It says do not take apart, but i took apart my smaller one and it had tons of dust - really gross. Cleaned it up and it works great now. I just want to clean the larger one.
  • Anonymous May 24, 2009
    I had the same problem and was able to use eknickerson's excellent instructions to take my tower fan apart and clean the turbine blades. My problem came when I tried to put the fan back together. I think I sprung the metal screen too much getting it off and then couldn't get it to conform back to the fan so the screws would fit.
Whew!! Finally figured this one out!
How to Clean Seville Classics Tower Fan
Approx Time: 1.5 hrs
Long Phillips head screw driver
Metal Skewer or very thin/sturdy screw driver
Empty egg carton (to keep track to the hundreds of screws)
Leatherman or small pliers
Make sure the fan is unplugged!
1.Filp fan over and remove the 2 larger screws that hold the pedestal together (keep screws organized)
2.Remove the 4 inner screws that connect to the base
3.Remove base
4.Unscrew the 6 screws that hold the lower rear cover
5.Remove lower rear cover
6.Unscrew the 4 screws around the underside of the fan case (in a half circle)
---Very Important in cleaning---
7.Replace pedestal! Yes all 6 screws (4) smaller inner screws and (2) larger screws
8.Stand fan upright (lower rear base cover removed)
9.At top of control panel (buttons) locate a small circular hole (top of fan) towards the rear handle
10.Take the skewer or thin/sturdy screw driver and stick it in the whole
11.Gently but firmly pop up the control panel. (it took some patience, working around the panel but it popped up.
12.Remove (4) screws and remove the secondary plate
13.Remove (3) larger screws toward the front of the fan and (4) smaller screws around the edge
---Leave the screws in the metal plate in place---
14.Remove the 3rd cover
---Now the fun part!!---
15.To remove the metal screen push the plastic front in slightly at the edge with the open plastic vents (this side doesn't have tabs). There is a bent edge that is held in place by the plastic screen on this side.
16.Continue to pry the screen backwards and push edge with tabs (side of plastic front with no vents) towards the front of the fan. There are 3 metal tabs that slide in the plastic front at that edge.
---The front plastic vent face should be left in place, all of the control wires run through it---
17.With metal screen off, you can use your vacuum (highly recommended) while you scrape the "turbine" with the toothbrush. There are a lot little turbine edges and they get quite dirty. Vacuum is a must!! In fact, I had mine running the entire time.
---The plastic turbine does not come off and must be cleaned in place---
18.Putting it back together!!! The metal screen tabs might have bent a little when you pried it off, I used a leatherman (pliers) to bend them straight. With patience you slide the tabs back into the plastic slots (working from the bottom up is best), slowly start to place the screen back around the fan. When you get to the side with the bent edge, you must push the plastic vent face inward (bottom up is easiest) in order to snap the screen around the edge.
19.Now, while not letting the plastic front slip from the metal screen, grab the plastic plate and slide it on top (make sure to get the metal rod back into the rubber gasket) and push down. This will hold the metal screen in place.
20.Put all the screws back in place and snap the control panel back on.
21.Remove the bottom pedestal in order to put the rear plate back on.
22.Replace the pedestal.
This is definately a fan made by engineers with disposable income that can afford to buy a new fan every year instead of cleaning it on a regular basis! I have had my fan for the past 4 years and always leave my windows open. After sometime, the performance when down, barely eeked out a breeze and shot dust bunnies on to my carpet. Often it would overheat and shut off automatically.
After all this time, I finally figured out how to clean it and boy, was I suprised how much dirt and junk this fan collects.
Hope this helps all the frustrated tower fan owners!!
Posted on Dec 23, 2008
  • gkekesi Jun 07, 2011
    Thanks for the detailed step-by-step instructions. I had a good deal of it figured out except for the part of removing the control panel on the top. I am always afraid to force plastic pieces at the risk of breaking them. Your suggestion and directions worked flawlessly. My fan is working like new again.
    New Friend:
The instructions provided by eknickerson are perfect. I had already gone half way through the process (figuring it out on my own) before I decided to find instructions online just to see how sturdy it was.
Two important points for reassembly though:
1. when putting back the electrical component on top be sure to situate the wires neatly or else the wire are crushed or turned and the buttons don't do what they are supposed to.
2. the "turbine" can shift a bit during reassembly and once turned on knocks against either the bottom or the side. I found giving it a couple good whacks fixed the problem, just make sure to identify where the turbine is knocking against the unit (in mine it was on the left)
Posted on Jun 20, 2013
These instructions are nice and clear. Make sure you WD40 the base gear that handles the oscillation and the both bottom and top gear for the fan blade. The panel cover is easy to get off if you pry it out with two pointed tools - one to pull it out and hold it while the other slips in to get a new bite. Also, rather than mess with the screen, I simply rinsed the fan blades with water while tilting the whole unit so the water pours out the top. Of course, you need to remove the top covers and make sure the water avoid electrical components. And of course, don't do this while plugged in.
Posted on Apr 14, 2012
The complete disassembly is obviously the preferred solution, but pretty complicated for most people. I tried something infinitely simpler and it worked perfectly: blow the unit out through the front plastic grille and the back perforated assembly with an air compressor and a blower nozzle. (Keep your head out of the way to avoid the super-dusty blowback.) The corkscrew blade inside will rotate at high speed while you're blowing. Keep blowing slowly up and down to clean out the slots on the corkscrew blade unit. I took a chopstick wrapped in a damp rag to wipe the grille slots and that worked well. We use the fan year 'round in Palm Springs and it's one of the best products I've ever bought.
Posted on Sep 08, 2011
Seville classic fan
Hi, I do not have a problem I just want to disconnect the beeper so I do not wake up my wife when using it at night. Thanks
Posted on Apr 20, 2011
Taking apart
Question about Brookstone Desk Fans: Slim Personal Desk Fan
Taking apart I took mine apart by removing the small screws that hold it together. my top fan cage was broken and loose. I glued it back together and the next day I just reassembled it and it works fine.. just look at what you are doing and dont FORCE anything common sense should allow you to do this... I am a retired auto mechanic 80+ years old and it did not give me any trouble until the e-clip jumped off, but I found it and all is well.. the screws are shiny and the case is black, so take them all out and lay in a pattern so you can reverse the pieces for reassembly..
Feb 19, 2013 | Brookstone Desk Fans: Slim Personal Desk...
PRESTO Tater Twister Instuctions
  • 1
    Take the inner piece of the Tater Twister, the large white circular piece, and place upside down on the table. The two handles should be on the bottom and not the top.
  • 2
    Choose your cutting disc and insert it into the inner piece of the Tater Twister. Insert the disc with the bladed side facing downward. There are two tabs on the side that should snap into place on the inner piece of the Tater Twister.
    • Free Daily News on your Cell Phone. All news on potatoes & products
  • Plug in the main Tater Twister unit, the glass blender-like piece. Insert a potato or other vegetable into the Tater Twister. There are several small studs sticking up in the bottom. Push the vegetable down onto those studs to hold it in place.
  • 4
    Push the switch on the front of the Tater Twister to turn it on. Take the inner piece and turn it right side up so you can hold the two handles.
  • 5
    Lower the inner piece into the Tater Twister. Position it so the handles line up with the two large slits in the Tater Twister. As you push down, pieces of the vegetable are pushed through the cutting blade.
  • 6
    Continue pushing until the inner piece has reached the bottom. Turn off the Tater Twister by pushing the switch on the front into the off position. Take out the inner piece and dump out the cut vegetable pieces onto a plate.
  • Parts For Porsche Panamera
    Jun 15, 2012 | Cell Phones
    Hi there, My sony rdr hx510 will not open and is making a grinding rotating sound. Baby girl either put 1 one or 2 discs in incorrectly. Can you advise on how I can get it opened and renove the discs.
    Must used a philip screw driver take out all the screws to the dvd player.Must take the DVD player aparts.Take aparts out the dvd player guard shield to the dvd drive to take out the dvd dic or dics out.Don't push the open button any more,the disc or discs is jamming ur dvd door tray.Will burn out ur disc tray motor,if u keep trying push the open button,trying opening it that way.
    Sep 24, 2010 | Sony RDR-HX520 DVD Recorder
    The little fan disc came off the top spleened motor shaft. Does it make a difference which side is facing down when I put it back on?
    As long as the blades of the fan are flat (not curved) it doesn't matter. I'd be more concerned that the fan will probably come off again. Unless it's one that's held on by a screw it's just a push-fit and, having come loose once, it will never be a tight fit again. Good luck anyway!
    Jan 23, 2010 | Vacuums
    I have a GE Select Top loading wash machine that is making alot of noise during the spin cycle. 99/2000 model
    If it sounds like a jet plane taking off, a grinding noise, it is the bearing. This is pretty difficult to replace. If you do attempt it, you MUST replace the inner tub seal. This is leaking onto the bearing, causing it to go bad.
    Jan 18, 2010 | GE WBSR3140DW Top Load Washer
    Xbox Disc Tray Loose
    If you are comfortable with taking apart your system, I would advise taking the case off and then finding the dvd-drive, removing the case on that and simply tightening the screws on the tray. Don't tighten them too much, but make sure they are snug. Then test to see if it still wobbles and it should be fixed. If you are not comfortable with taking apart your system you will need to find a repair shop that can do it for you.
    Please rate, thanks!
    Mar 31, 2009 | Microsoft Xbox 360 Halo 3 Special Edition...
    360 elite top fan not working
    take the xbox apart as much as you can then open up the xbox this will void your warrenty if you still have one then then undo the screws that allow to take the top case off and check the wire hasnt come loose or been burn in anyway if so replace it with another fan unit thyen put the consloe back together
    Jan 22, 2009 | Microsoft Xbox 360 Console
    Kitchenaid top load washer
    could be either take out the two screws at the base of the control panel and raise it up after you back the screws out pull the panel forward then lift it up its on hinges check all the connectors next you will see a black plastic piece in the center of the timer pry it loose with a small screw driver till it extends but is not all the way off this will release the control knob make sure the inner ring is on the shaft properly then posh the knob on tight and push the plastic tab back in if that doesn't fix it replace the timer
    Feb 13, 2008 | KitchenAid KAWS850LE Top Load Washer
    Rainbow d4c
    Take off water tank, remove the screws to separate the top from the bottom, take out the screws inside the top and take out the plastic shell and the switch will be there.
    Jan 17, 2008 | Rainbow 75th Anniversary Canister Vacuum
    Disc tray rattles
    the screws on top of the disk tray may be loose u can take it in or fix it yourself if u dont mind takin your ps2 apart or have already just make sure screws on top of disk tray are tightend down all the way its an easy fix but be doing this it voids warranty and i i think that if seal on back is broken u cant take it in to have it fixed.
    Jan 02, 2008 | Sony PlayStation 2 (PS2) Console
    Seville Classics MSC10166 Tower Fan Logo
    6,951 people viewed this question
    Top Seville Classics Dryers Experts
    Are you a Seville Classics Dryer Expert? Answer questions, earn points and help others
