Question about Sharp Computers & Internet
Sharp y520 organizer wont switch on or off - Sharp Computers & Internet
  • 2 more comments
  • j89b2y Jun 22, 2008
    all new batteries and with full charge ! . when new batteries are installed , organizer switches on automatically and remains on until I remove the batteries .
  • j89b2y Jun 23, 2008
    try a hard rest ???
    could you recommend a contact cleaning solution ?
    have been advised that the contacts on my sharp yo-520 organizer may need cleaning . can you recommend a contact cleaner ? .
    oistin
  • 983 Answers
Due to some virus attack when you connect to pc (if you have the pc connectivity) or due to some mis operations like removing the battery suddenly when the organizer is switched on the firmware might have got damaged ... due to this some of the files which are needed for the operation are missing or corrupted ...
due to this you are facing this type of problem ...
just try giving the reset option ...
this may solve the problem ...
if you have pc connectivity then just connect to the pc & check for the virus in this memory device ....
if the virus is there remove it ... ( might be the virus is trojan as it attacks all the memory devices when connected to the pc if the pc is affected)
Posted on Jun 23, 2008
  • Dileep Keshavanarayana
    Dileep Keshavanarayana Jun 23, 2008
    try removing both the batteries if it is 2 battery one means for some 5 mins ...
    then try replacing the batteries ....
    check the terminals + & - ......
    this might have also happened if you leave the battery in the compartment for a years due to leakage the terminal might have got damaged due to this there is no correct supply of power i think ,....
    if the terminals are rusted or something like that means then you must replace them,
    Sergeant:
    Champion:
  • 230 Answers
This may be due to the fault in the on/off switch so check that and change , if it has fault
  • 4,472 Answers
You can always use an eraser to clean contacts.
thanks,
Lee
  • Lee A.
    Lee A. Jun 23, 2008
    You can just use a pencil eraser that hasn't erased pencil. The other option is the electronic wipes you buy at any retail outlet that sells electronics. If you found this helpful I hope you will accept and/or rate as such.
    Thanks,
    Lee
    Master:
  • 638 Answers
Try hard reset normally it clears such problems.
feel free 4 further assistance .rate the particular experts solution as fixya that helps u understand n solve ur problem
    Genius:
  • 1,447 Answers
Hi-
try to do a reset and check on the power button as well if it seemed stuck. seems that theres some issue on the power button or switch, but try resetting it first.
  • Sharp Master
  • 19,396 Answers
The on switch is probably faulty, this may be due to oxyde or a broken contact, the device should be taken apart. If it oxide a spray of contact cleaning solution can do the job, if it is a broken contact, or if you need to change the switch a precision soldering job is required, in this case is better to take it to a repair point.
If you want to try an hard rest try resting on a nail carpet. Just kidding, probably he meant hard reset (taking off batteries), but I do not think this will work in this case.
Regards
    Genius:
  • 1,665 Answers
Make sure also "on/off" switch is not faulty.
  • 6,487 Answers
Replacing the operating batteries
The Organizer detects two low battery levels which are warning and fatal.
When the batteries is in warning level, the BATT symbol appears at the
display. In fatal level, the organizer will turn off automatically without
indication.
If the BATT symbol still appears or nothing is shown, replace both of the
operating batteries immediately.
1. Press OFF to turn off the Organizer.
2. Set the battery replacement switch on the bottom of the Organizer .
3. Slide off the operating batteries cover.
4. Remove the old batteries by pulling the ribbon tab.
5. Insert the two new batteries on top of the ribbon tab, taking care to
position them correctly according to the plus (+) and minus (–)
terminals, as shown below.
6. Replace the cover.
7. Set the battery replacement switch to NORMAL OPERATION.
8. Press the RESET switch with a ball-point pen or similar object.
If nothing appears on the display, repeat the above battery replacement
procedure step by step.
9. Set the clock to the correct time.
Hope this helps...........
Posted on Jun 22, 2008
  • Mark Gil
    Mark Gil Jun 22, 2008
    Try this one since you have new battery...
    Genius:
  • 3,422 Answers
Once your switches on try a hard rest.
  • Sharp Master
  • 13,433 Answers
Try removeing the battery for a moment, are you sure the battery has power on it?
Where do I get a manual for my sharp el 6920 pocket organizer.
You can get it from the manufacturer's website
http://files.sharpusa.com/Downloads/ForBusiness/SmallElectronics/Organizers/Manuals/Archive/org_man_EL6920.pdf
May 20, 2012 | Sharp Office Equipment & Supplies
THE 7THTHRU 12 COLUMNS ARE UNREADBLE VERTICLE CAN THIS BE FIXED OR DO I NEED A NEW ORGANIZER???? IT IS THE YO-190 256KB ORGANIZER.
The screen has lines on it? This can be fixed by replacing the screen, I don't know if parts are available, I think your best shot is to find another organizer with the same screen and replace the screen or use the other one.
seem a new one costs around 100usd
http://cgi.ebay.com/BRAND-NEW-SHARP-YO-190-256KB-MEMO-MASTER-ORGANIZER-SET!_W0QQitemZ160282250449QQcmdZViewItemQQimsxZ20080912?IMSfp=TL080912112005r33862
I think you should contact sharp for the replacement il look up the contact details.
Sep 29, 2008 | Sharp Computers & Internet
Sharp organizer
you organizer should have cam with a cradle to set it on. that will connect to your computer either serial2 or usb. did yours not come with one of these?
Aug 15, 2008 | Sharp ZQ-590
I would like to be able to get English instuctions for the Sharp electronic organizer 34kb zq-1250 online, Thank you.
I always recommended to use two methods: use the dictionary included into Google Bar (the cheapest way) or buy Babylon -http://www.babylon.com/- the most reliable and effective way.
Dec 22, 2010 | Sharp Personal Organizer & Spanish/English...
Looking for software for OZ-730. Found that www.mywizard.com is no longer an accessible site.
CALL thewizardshop.net 803-736-4382 they have software and sharp organizers.The wizardshop can help you with ALL your Sharp Organizer needs.
Cords,software for Windows XP and 7. They have Sharp OZ-730,OZ-770 and YO-520. They also repair ALL Sharp organizers with a keyboard.
www.thewizardshop.net
803-736-4382
Nov 29, 2010 | Sharp Wizard OZ-730
Transfer OZ-750 Data to Computer
Hi Pat,
and with the indulgence of otacon and Ekse...
You would need the Docking Module and the attached COM1 cable/plug.
You might find this page/document very informative if not interesting. Should you need the software (Day-Timer Organizer), it is available here. Additionally, a Q & A about OZ750 is here.
Hope this be of additional help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 04, 2008 | Sharp Wizard OZ-730
NEED A SHARP ZR-5700 MANUAL FOR ORGANIZER
You can down load the manual on the link below.
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Good Luck and please rate 4 thumbs for the free answer
Mar 16, 2010 | Sharp Personal Organizer & Spanish/English...
How do I back up my Sharp OZ 570
i change new Batteries and then not appear anythint on Screen. pls help.
Sep 24, 2009 | Sharp Wizard OZ-730
Sharp Electronic Organizer ZQ-6000
I couldn't find any support for this on Sharps USA website. You should contact them directly at:
1-800-BE-SHARP
Jun 30, 2008 | Sharp Personal Organizer & Spanish/English...
Computers & Internet Logo
105 people viewed this question
Top Sharp Computers & Internet Experts
Tony
Jason Harris
Jason Harris
Ricky Ostrom
Ricky Ostrom
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
