Question about Konica Minolta magicolor 2400 Laser Printer
Paper jam at fuser unit section
Please can i get more details on how to check fusion unit as it just says paper jam and crumples up my paper.
  • 214 Answers
Answered here :
also, if the paper stuck in FU is straight not crumpled and will come out easily then make sure that the 2 knobs located at top of the FU are in right position.
Posted on Jul 01, 2008
Canon photocopier ir3570 paper is jamming in the fuser unit what could be a problem please help ray
Hi! There is a lot of things that can happen near the fusion stage.
1- the paper is curled due to damp and hits the fusion block.
2- the fusing unit is lacking traction due to damaged gears at the rear end
3- the paper hits a broken scraper (in a set of 3,4,5, or 6), being this the most comun cause
4- The pressure betwin the pressure roller and the fuser roller is weak
5- the paper sensor is broken or damaged, being this one a comun cause too
Now, if the paper goes trough, must be the sensor failure
If the paper gets curled or crumpled BEFORE fusion, then a scraper (or more) is broken
I could be here forever giving other tips, but this are the main ones
I hope it was helpful.
Sorry my english...
Apr 09, 2014 | Office Equipment & Supplies
Open and pull out crumpled paper to clear it.
Sep 26, 2013 | Canon Gpr19 Ir7105/7095 Black Copier Toner
Paper mismatch officejet 6500 crumples
There could be a foreign object or torn piece of paper that's stuck further inside the printer mechanism path. Try using a flashlight and inspecting any access or clean out hatches. Sometimes something will be caught inside and cause the paper you feed in to crumple and create a jam. I watched a video on youtube giving different ideas on how to fix this problem. Fixing Paper Pick-Up Issues
May 27, 2013 | HP Officejet 6500 Wireless All-in-One...
Brother 2270 laser printer started jamming every time, after I installed a new toner. It was a Brother toner, at that. Anyone experience this?
Silly question first - is the drum unit DR2225 installed?
Check the toner cartridge sits firmly in the drum and that the drum is pushed all the way forward in the internal cavity. If the paper is jamming at the paper pick up roller ie in the paper tray, clean the paper pick up roller with a drop of meths and a drop of detergent on a damp cloth. If the paper jams in the drum unit, check the clear plastic guide flaps are straight and do not catch the paper. Also check that there is not a piece of paper caught in the drum unit. If the paper gets part way through the drum and then jams, check the fuser at the back for a piece of paper crumpled up inside the fuser. If the printer is trying to take ALL the paper at once, check and clean the paper separation shoe in the paper tray.
Jan 03, 2018 | Brother MFC-7820N Laser Printer
Error code H5-01 how to fix on a sharp arm350u
That is a repeated uncleared jam in the paper transport. You may have a piece of paper wrapted in the fuser that you cant see, or one of the sensors on the transport between the paper feed and fuser are dirty.
You can try entering doagnostics, you press P * C * or # * C*, that will put the machine in diagnostics. Then press 14, then enter 1 then press enter. That will reset the machine, If the 14 routene doesnt work look for an uncleared jam or clean sensors.
Here is what it says.
H5 01 Content 5-time continuous POD1 not-reaching
jam detection
Detail 5-time continuous POD1 not-reaching
jam detection
Cause A fusing section jam is not properly
removed. (Jam paper remains.)
POD1 sensor trouble, or harness
Improper installation of fusing unit
Check and
Check jam paper in the fusing section.
(winding, etc.)
Check POD1 sensor harness, and
check the fusing unit installation.
Use SIM14 to cancel the trouble
Aug 09, 2010 | Sharp AR-M350U Copier
Display reads paper jam 2 check inside
Open the Top Half of the Copier. The Scanner Section pops open by pushing up.
Underneath the Scanner Section is the Fuser Unit. Check in the Fuser Section, you will find paper Jam in the Fuser Section.
Apr 27, 2010 | Samsung CLX-6210FX Laser Printer
Paper jam in exit area. How do you remove?
The paper jammed on fixing unit area. Probably the pressure roller is worn-out causing the paper to stick on it rather than sliding the paper out. Remove the fixing unit so that you can remove the paper. Removing the fixing unit needs a lot of skills, I recommend you call the nearest service center for assistance.
Feb 17, 2010 | Canon ImageRUNNER 1670F Copier
Canon IP1880-Paper jam
after you get all the crumples out
wipe down the rollers with alcohol to clean them and wait about 5 to 10 minutes before trying to print
Jul 21, 2009 | Office Equipment & Supplies
Paper getting stuck in the rear of Brother 2820 fax machine...
Hi, There are many reasons for jams in the exit of machines and I will list the most common for you damp paper will curl as soon as it hits the fuser rollers... the fix - change paper the fuser rollers are worn (teflon coating is no longer able to deflect toner) and jams are occurring.... the fix - replace the fuser unit
Jun 09, 2009 | Brother IntelliFax-2820 Laser Fax
Paper will not go through output rollers - jams at crumples
ok, in this case you need do:
1) check the roller before the fuser and after it some roller old not enough firction and pressure balance
2) check the fuser press roller it could not has good tough to fuser surface, it should be no gap at all and good pressure balance on the fuser surface
3) check the fuser cleaner which maybe too dirty, or change new one if you have the parts.
4) fuser unit maybe too old if printing pagers over its life cycle
hope this help you and please ask me any time.
May 15, 2009 | HP LaserJet 1300 Printer
Konica Minolta magicolor 2400 Laser Printer Logo
208 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
