Question about 2wire 2700HG-B Router (2700HGB)
Says i'm not connected, says I am
2wire 2701hg-b Keep informing me i'm not connected, when I try to connect it, it tells me i'm connected, can't get the little message box to stop popping up, also being told it isn't connected due to inactivity,. I use it every day. Plus just added Norton.
Not sure how I did it as I contacted att and gateway. Then everything solved itself.
Posted on Jun 23, 2008
Cant turn on upnp
Your 2wire 2701HG-B does not have uPnP.
Feb 10, 2013 | 2wire (2701HG-B) Wireless Router
What steps do I take to configure my 2wire 2701 hg-b to connect directly by ethernet cable to my Directv HD DVR and pick up the dsl signal being transmitted by my primary westell router? Both are wireless...
Connect the cable at both ends and do a red button (inside card door) reset of the DVR. To test the connection, do thus: Menu -> .....setup -> system setup -> network setup -> test connection. If it shows not connected then "reset defaults" and run "connect now"
As a basic security feature the ATT DSL 2Wire 2701HG-B router/gateway requires you to enter its pre-assigned WEP key to connect beyond the unit itself and then to the internet. Since the Direct TV DVR HD24D only does a basic connection without having a place to enter the 2701HG-B WEP key it never actually reaches the internet.
The 2Wire 2701HG-B has the ability for one attached unit to "pass through" its firewall and internal security settings using a so called "DMZplus" mode. I set the HR24D DVR to such a mode within the 2Wire unit and the DVR connected with the internet flawlessly.
Dec 30, 2010 | 2wire (2701HG-B) Wireless Router
When attempting to connecting to xbox live..it informs me that it cant obtain ip address from my att 2wire 2701hg-b wireless gateway..cant figure this one out
Shut off your securtiy setting on the wireless router. Some x-box's had trouble connecting with encription on the wireless.
Nov 14, 2009 | 2wire Computers & Internet
2wire 2701HG-B gateway can't connect locally
Have you got MS CLient loaded in the network settings. If not run network wizward on each machine and then try again. hope this helps Mark
Aug 18, 2009 | Computers & Internet
2701HG-S blocking Ivy Tech email
well my friend i think u r trying to connect to an intranet mail system of ur college from internet. its not possible without the proper information & authorities from system admin of ur college.
i suggest u contact ur college system admin they will provide u with the settings
Jul 04, 2009 | 2wire 2700HG-B Router (2700HGB)
2wire 2701HG-S Embarq to AT&T
that is typically a bad username in the modem, you will have to put there temp user name in for registration for the DSL. and after that you can put the username into the modem that you created during the registration process. Should be taken care of.
May 15, 2009 | 2wire Computers & Internet
Can I use AT&T 2WIRE 2701HG-B DSL to ant ISP?
look if u wish to go for verizon service,,they will provide u with a wireless modem as well,,but if u tell them that u hav a modem then they might configure this modem only,,both ATT and verizon are DSL service providers with PPPoE connections.the only thing u need is the username and passwrd from verizon which u have to setup on the first page of the 2wire setup page,,both the connections are dhcp based.so no other connection settings change required.But when u talk with verizon make sure u tell them of the 2wire modem
Moreover verizon has wireless broadband service which is actually a express card tat u have to put into your computer and u can go online anywhere u go within ur country{it works like a mobile phone}
best of luck,,keep me posted
May 14, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
2Wire 2701hg-b dsl modem
Have you verified the unit is secured. It sounds like someone is hijacking the unit and resetting the configuration.
Please post the configuration here and I will tell you what is going on. DO NOT SEND ME YOU USERNAME OR PASSWORD, as well as any DMZ information you may have setup.
Oct 08, 2008 | 2wire 2700HG-B Router (2700HGB)
Can't connect 2wire to internet
Before router put usual low cost switch....
May 21, 2008 | Computers & Internet
2wire 2700HG-B Router (2700HGB) Logo
65 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
