Question about Praktica Cameras
Unable to read user manual from cd
Unaable to read user manual just what appears to be machine code and no matter what i attempt to select how i want the document to be read(i.e windows(default) or selecting which language it still reads a list of numbers and letters
Deleted Adobe reader and installed Adobe reader from cd this proved that it was previously corrupted and was the reason for the inability to read manual.
Posted on Jun 23, 2008
Clean unable 46, See Trouble shooting and routine maintenance chapter in User's Guide.
Hi there. . . okay . . . Follow this step
1.) Unplug your printer.
2.) Plug your printer again while holding the menu button 15 sec.
3.) select 8 by using the arrow buttons ,push OK and select 0 and push OK
4.) then numbers appear looks like this ###:### ###:###.
5.) now push the MONO button until the purge:#### appears on the LCD
6.) Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok
7.) - switch off the printer ,switch it on
- ready to print
- CHEERS!
 email me if I help you. . ryuuzaki182@gmail.com
Mar 20, 2010 | Brother DCP 165C Compact Color Inkjet...
Unaable to set time I need a manual please telememo 30
Go to casio.com, click on "support", then "manuals",watches.
Accept terms and then select "watch manual archive".
Fill in the required details off your watch and click on "search".
Jan 31, 2010 | Casio DB360G-9A 30 Pages Telememo Watch
Am unable to prime water pump
Water is not being drawn from reservoir into boiler. The valve at the base of the boiler seems to function properly. After repeated attempts, I am unable to prime pump and fill boiler with water.
Dec 24, 2009 | Saeco Vienna SuperAutomatica Coffee...
Unable to restore computers original factory settings with Dells suggestion of control f11 when computer starts up
If you have already used the cd's to install the os, this will not work. there is another option which you can try.
Manual Reinstallation
Manual reinstallation can be the most time consuming and difficult method of those available. You will reinstall the operating system directly from the CD or DVD, install the drivers, configure the OS, install critical and recommended updates, install your applications and, if available, restore backed up data files. Time to Complete: 120+ Minutes.
1. Remove non-essential peripherals
like:
  • Scanner
  • Printer
  • Modem or Network cables
  • Personal Digital Assistant (PDA)
  • USB flash drive or other external Hard Drive
  • Any other external devices (e.g., USB-attached devices)
  • Remove the computer from the docking station, if you are using one.
  • Check to ensure that all your installation media is available. You will need the following:
  • The Dell™ Reinstallation CD for Microsoft® Windows® XP, or
  • The Dell™ Reinstallation DVD for Windows® Vista,
    • The Dell Resource CD/DVD,
    Reinstall the operating system from the OS Setup Disk.
    Insert the Windows XP CD into the CD drive, and then restart your computer.
    and watch for the Dell logo to appear.
    When the Dell logo appears, press the <F12> key to load the Boot Menu. If the menu does not appear, restart the system and tap <F12> several times at the Dell logo screen.
    When the Boot Menu appears, highlight the CD/DVD drive (listed as "CDROM", "CD/DVD" or "CD/DVD/CD-RW") entry from the list and press <Enter>.
    If the message Press any key to boot from the CD... appears, press a key to continue booting to the CD.
    In the Windows XP Setup screen press <Enter> to set up Windows XP.
    In the Windows XP Licensing Agreement, read the license agreement, and then press <Page Down> to scroll through the agreement.
    Press <F8> to accept the terms and conditions specified in the license agreement
    Highlight the largest partition and press <Enter>.
    If you are prompted to format the partition, use the up or down arrow keys to highlight Format the partition using the NTFS file system (Quick). Press <Enter> or <F>, if applicable, to format the partition. In cases where the drive must be checked for errors, select the Format the partition using the NTFS file system option.
    Setup will format the drive, if necessary, then copy the files needed for installation. This process can take several minutes. Once done, Windows will restart the computer to continue Setup from the hard drive.
    Note:
    Do not press any keys if the message Press any key to boot from the CD appears. The amount of time it takes to complete the above process varies,
    depending on the speed and size of the computer. (it may happen if the computer restarts during the process, just wait and watch)
    After the computer restarts, Setup continues with a graphical user interface (GUI) in the classic Windows theme. In this stage, you are asked to input information to personalize your installation. Your screen may blink several times during this process, which is normal. The information to input, and the order it is provided, is shown below:
    Click Next on the Regional and Language Options window.
    In the Personalize Your Software screen, type your name in the Name: field and your organization's name in the Organization: field, if applicable, and click Next.
    In the Computer Name screen, type the computer name in the Computer Name: field if you want to change it from the name provided. For Windows XP Professional Edition users, type a password in the Administrator Password: field and then type the same password in the Confirm Password: field.
    Click Next.
    Note:
    If the Modem Dialing Information screen appears follow the instructions below, otherwise continue on:
    In the Modem Dialing Information screen, click to select the correct country/region for the What Country/Region are you in now? box.
    Type your area code in the What area code (or city code) are you in now? box and the number in the If you dial a number to reach an outside line, what is it? box, if applicable.
    Click to select one of the items below for The phone system at this location uses: box:
    Tone dialing if your phone service uses tone dialing.
    Pulse dialing if your phone service uses pulse dialing.
    Click Next.
    In the Date and Time Settings screen, verify that the correct Date, Time, and Time Zone appear, and click Next.
    In the Networking Settings screen, click to select Typical, and click Next. If available, click Skip to skip the networking setup section. For Windows XP Professional users, click to select No, this computer is not on a network..., and click Next.
    Setup will finalize the installation and should complete within 30 minutes of this point. Once complete, the computer will restart.
    Note:
    If you see the message Press any key to boot from the CD when the computer restarts, do not press any keys on the keyboard.
    After the computer reboots, the newly installed operating system will attempt to configure itself for your detected devices, however many of your device drivers are not yet installed. Use the following to finish the configuration and prepare the computer for driver installation:
    If the Display Settings message appears, click OK.
    If a Monitor Settings message appears, click OK.
    In the Welcome to Microsoft Windows window, click Next.
    In the registration screen, click to select No, not at this time and click Next. You will be prompted to register your computer again later.
    In the Do you want to set up Internet access now? window, click to select No, not at this time and click Next.
    In the Who will use this computer? window, type the user name of your choice in the Your name: text box. Type the name of any additional Users that will be using the computer in the additional text boxes provided.
    Click Next to continue.
    Click Finish.
    Windows XP now starts for the first time and is ready for driver installation.
    Oct 13, 2009 | Computers & Internet
    Error-91-1D5
    a CD came with your unit .. on that CD is the service manual .. (dont need user manual) ... the service manual lists all the error codes ... if you no longer have that CD then you can purchase the service manual here
    http://www.manuals-in-pdf.com/search-dsr1800+service+manual.html?&forward=plist
    its about $15 at this site as a downloadable PDF
    thats a very nice machine .. hope you get it going ..
    Oct 07, 2009 | Sony DSR-1800 DV/Mini DV VCR
    Print unable 32 comes up after a successful print job
    The message "Print Unable 32" or "Machine Error 32" will appear on the LCD display if paper or labels are stuck inside the printer or drum unit.
    Follow the manufacturers recommendations on how to clean the rollers, etc.
    Read the users manual.
    Aug 14, 2009 | Brother MFC 240C All-In-One InkJet Printer
    Error
    The manual states
    1. " An (ERR_) message will appear, then change to a flashing (DISC), then the CD will be ejected."
    You will have 5 uninterrupted attempts to insert the correct CD.
    2. After the 5th incorrect attempt, the display reads (HELP)
    3. If (HELP) appears on the display, press button (6), then the (FUNC) button, and hold them for 5 seconds.
    4. Press the (FUNC) button. You will have 5 more attempts to insert the correct disc.
    IF AFTER 10 TRIES, AND IF THE CORRECT KEY CD HAS NOT BEEN INSERTED, THE DISPLAY READS (CALL 800); THE UNIT MUST THEN BE RETURNED TO ECLIPSE TO BE RESET. CONTACT ECLIPSE DEALER OR CALL (800) 233-2216.
    Jul 19, 2008 | Eclipse CD3422 CD Player
    F & P GW712 - bowl spins, but won't fill.
    Read your user manual - but I would suggest that you may not have setup the balance properly. Check the level of the machine and adjust to be as square as possible by adjusting the feet at the bottom. If the water isnt coming in on both hot and cold sounds like a common problem - perhaps the water level sensor is playing up or something else has been knocked during transportation of the machine when you moved house. Check your user manual for troubleshooting. Sounds dumb, but check that 'delay start' isnt selected also. check both hoses filters are not blocked.
    Sep 21, 2007 | Fisher and Paykel GWL11 Top Load Washer
    KENMORE ELITE HE5
    possible low watewr pressure or slow fill. Regards Engineer
    Jul 22, 2007 | Kenmore Elite 45986 Front Load Washer
    Cameras Logo
    Top Praktica Cameras Experts
    Are you a Praktica Camera Expert? Answer questions, earn points and help others
