Question about Bosch Classixx WFL 2462 Front Load Washer
Bosch WFK 2401 problem, please help
My washer is stopping with 3 minutes left and starts beeping. It doesn't appear to be finishing the spin. The problem is random, somedays it finishes and somedays it doesn't
  • ansquest Jun 25, 2008
    we just encountered the exact same problem. the machine won't drain either. how do we get the machine to empty out so we can open the door and remove our clothes?
  • Anonymous Mar 24, 2014
    No spin available
  • 66 Answers
This could be a block in the pump or motor brushes would go for the pump
Posted on Jun 22, 2008
Bosch WFK 2401 impeller blockage
The pump uses an impeller to move the water into the drain pipe. Take the lower front off and you will see the impeller cover, behind the filter.
Jun 22, 2017 | Bosch WFK 2401
Hi, the spin cycle on our bosch wfk 2401 suddenly stopped working. The wash and rinse cycle works but when it's time for the spin cycle to begin, the machine hums as though the motor is straining...
If there is motor humming while the spin cycle is ON , please confirm if the motor also heats up-- take caution not to touch live points. Also if you manually push the motor with care so see if the spin starts up then the capacitor (this assists with the starting) can be weak or faulty.
Remove and check with a mains tests and see if the charge retains, if not change. Other wise check if there is friction on the motor or drive.
Jun 14, 2011 | Bosch WFK 2401
Bosch WFK 2401 - Washer fails to spin.
Check the carbon brushes on the motor.
Apr 20, 2010 | Bosch WFK 2401
Installing carbon brushes on Bosch WFK 2401
Remove rear panel of washer.
Remove drive belt.
Unscrew the 2 bolts that hold motor to tub back.
Remove motor plug
Lever notor back with a screwdriver or similar, keeping a firm hold on motor.and remove motor
At the rear end of motor away from pulley you will see the brushes and the armature.
Remove brushes, and if there is less than 4 or 5mm of carbon left, then replace them.
Lightly clean the armature with emery cloth.
Refit in reverse order. Test.
Plz rate my solution.
Thanks.
Jan 12, 2009 | Bosch WFK 2401
Bosch WFK 2401 Full of Cold Water!
put machine near an outside door let the empty hose lie outside that will drain the water out........then check the pump for a blockage ........
cheers
Jul 24, 2017 | Bosch WFK 2401
Beeping
Thanks for posting this solution! I'll try it with mine.
Oct 24, 2007 | Bosch WFK 2401
Washer doesn't complete cycles
Sounds like an electronics problem. Get a Bosch repair person to look at it. Hopefully, they can reset the computer inside. Otherwise, it's a part that costs more than $200, as I recall, plus too much to do the work. Bosch's 1-800 person once advised me to unplug my washer - a model 2401 - for a half-hour as a way to reset the electronics. You might try that. Pray to the appliance gods. Maybe your machine is still under warranty. Trouble is, you'll probably have to wait for days until an authorized, over-priced repair person comes to visit. Bosch is way behind in service levels here in the U.S. They know it, but it's not worth their time or money to fix, it seems. A long story ....
Sep 19, 2007 | Bosch WFK 2401
Bosch Classixx WFL 2462 Front Load Washer Logo
244 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
