Question about Goldstar MV-1615 Microwave Oven
MV-1610 Runs but doesn't heat
I have a model MV-1610 ST that is close to 2 years old. It stopped heating one day when my wife was heating a cup of coffee. Later in the day my son tried using it again and it did not heat and a burning smell was noted.
I pulled the unit an have taken it apart and have found no evidence of any loose connections or other problems. The only evidence of heat I found was the tag on the capacitor is discolored. We attempted to run the unit and it makes a humming noise from the transformer and we noted that the resistor on the capacitor was starting to smoke and is thus the source of the electrical burning smell.
Could the capacitor be bad? Could the resistor be bad? Where could I find these replacement parts? Is there anywhere I could get a technical repair manual for this unit?
  • Anonymous Jan 15, 2009
    Everything works but it does not heat anything
  • Anonymous Feb 19, 2009
    runs but wont heat
  • Goldstar Master
  • 9,086 Answers
That wouldn't be a resistor on the capacitor, it would be the high voltage rectifier diode.
It should read open on a continuity check. A shorted high voltage diode is a fairly common cause of a no-heat condition.
For testing, see: http://www.gallawa.com/microtech/diode.html
To order the part, and for other Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit http://www.lgservice.com.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 22, 2008
Ge adora over the range microwave, runs but does not heat
Microwaves contain high-voltage parts that can be deadly, even when unplugged, unless handled correctly. Unless you are a qualified expert, don't attempt to get into its inner workings.
First, use this water method to double-check if there is actually an issue with your microwave not heating:
1. Fill a glass measuring cup with water to the 1-cup mark.
2. Set the microwave to heat on full power for 1 minute.
3. Repeat the process with fresh water a handful of times.
4. If the water is not consistently warm, your problem is confirmed.
If your microwave is failing to heat correctly, you may be on a previously programmed setting. Press the STOP/CANCEL button and start the heating process again, but use a higher power setting. This may correct the problem.
If the microwave senses an open door, it will not run. Check to see if a defective or loose door-safety interlock switch is to blame. If tightening it doesn't work, a replacement may be necessary.
Did you know? Neglecting to hit the STOP/CANCEL button on the microwave before you open the door to remove your food damages the safety switch over time.
Microwaves installed above the range may be affected by steam from cooking. Condensation collecting on the circuitry can interrupt heating. Allow the circuitry to dry out by avoiding stovetop cooking for a few days. If you're still having the same problem, it could be a loose connection in the circuitry or a faulty door safety switch.
There may be an issue with the circuit board and its connections, and that work is best left to a qualified professional.
A buzzing or humming microwave that emits a faint burning smell could signal a damaged magnetron, high-voltage capacitor or diode. Replacement magnetrons are expensive, so if a service professional determines that's the problem, you may be better off buying a new microwave. Capacitor and diode parts cost much less, but remember, you'll be paying for the expertise to have them installed correctly and safely. It may still make more sense to buy a new microwave, especially if it's a simple countertop model.
For more troubleshooting steps and simple solutions, read Microwave not heating. I hope this helps!
Sep 28, 2012 | Microwave Ovens
Microwave wont heat up food
If your microwave runs, but doesn'theat your food, verify that you have selected a cooking setting. You mayaccidentally set the timer. Test the magnetron by placing 1 cup of water in themicrowave and heating the water for three minutes. If the water doesn't heat,your magnetron is dead.
Mar 08, 2012 | Sanyo Microwave Ovens
Oven is not making etables heat
Mar 07, 2012 | LG Microwave Ovens
My microwave stopped heating?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
weyu
May 27, 2010 | LG MV-1444Y Microwave Oven
Microwave cuts off after using for about three minutes and then comes back on in five plus minutes. Does this every time. Now it does not heat at all. It is 4 years old and has been doing this for a year...
you what??? you hate to replace it after 4 years??? stone me!
its worn out girl!, done in!, had it!, claped out!, (sounds a bit like me)
well they dont make am like the did,,,if its been over heating and turning off, for a full year, its dead now, and as there are microwaves on the market for less than £50.00p whats the problem get a cheepy use it till it drops dead then get another one,,, ok?
oh, by the way,, my first microwave i got way back in 1978!!!!! lasted till 2005 it was used every day to cook for 6 children, one unhappy wife, and me? (who is all ways happy now wife has gone?) beet that one?
Oct 21, 2009 | GE Microwave Ovens
The fan starts up and runs on its own and we are cooking
That is a normal safety feature.
That's only covered in a very subtle note in the hood fan section of your owner's manual:
NOTE:If the temperature gets too hot around the
microwave oven, the fan in the vent hood will
automatically turn on at the HIGH setting to cool the
oven. It may stay on up to an hour. When this
occurs, the fan can not be turned off.
If for some reason you don't have your owner's manual, you can download it here.
Enter your model number as MV1610ST with no spaces.
You will need the free DJVU viewer to view or print your manual.
Dec 14, 2008 | Goldstar MV-1615 Microwave Oven
My Sharp R-340D microwave works perfectly but Does NOT HEAT FOOD
heatman101
fggfd
Sep 22, 2008 | Sharp R-1610 Microwave Oven
Kenmore Galaxy Microwave Hood Combo Model 72180002400
Since it sounds louder than before, it is probably a bad high voltage diode or magnetron.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/mag_test.html
Sears may send you a magnetron to install yourself since it's under warranty. For that or warranty service, contact Sears at http://www.sears.com.
You can save about $75 by taking it to the shop yourself, as opposed to an in-home service call.
Aug 07, 2008 | LG MV-1444Y Microwave Oven
Goldstar MV-1615 Microwave Oven Logo
210 people viewed this question
Top Goldstar Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
