Question about Whirlpool 3.2 cu. ft. Plus Washer
Appliance Hook Up
Hello.
I ordered a washer/dryer to be delivered by Best Buy next week. My question is, will they disconnect the old units, remove them from my home, and hook up the newly purchased units?
Thank you in advance for assisting me with this question.
Brandon
    Novelist:
    Champion:
  • 216 Answers
Greetings BHutton,
There are a couple of contributing factors in the answer to this question.
Is your dryer electric or gas? If it is gas, then that would require an installation by a licensed installer which is an additional fee at your local store.
If the unit is electric they should hook it up. If your unit was electric the delivery should include disconnect, reconnect and haul away of the old units, one item for one item.
For more information I would encourage you to contact your place of purchase.
I hope this helps!
Dorothy
Go Ahead. Use Us.
Posted on Jun 23, 2008
I have a Fridgedare front loading washer with dryer stack. There seems to be coin or other metal object behind the drum. The tech tells me he has to remove the dryer and access the washer from the top. ...
Hello Edie, thank you for your inquiry!
Generally speaking, since your washer and dryer are two separate units the dryer would need to be remove in order to access the washer. This will also help prevent any personal injuries. I do hope this information proves to be helpful.
Best regards.
Oct 05, 2013 | Frigidaire ATF6000ES Front Load Washer
What is the best way to accsess the motor on a roper dryer;model number--rex6634pqo ?the starter windings are bad. thanks steve Williams
u need to take the cover off the unit and then remove the drum when u get the cover off the machine lay down you will see a pulley down the bottom that hooks the belt around the drum pull the pulley towards your left if your looking at the machine and remove the belt then remove the tub next part you need to remove the rear panel and the blower fan off the motor next go to the motor and there is a front and rear clip that secures the motor to the frame next remove the harness motor removed u can buy this part at marcone appliance parts and they will deliver it directly to your door hoep this helps
Jul 08, 2010 | Dryers
Brand New Whirlpool Duet 9450 Error Code PF
This is a problem I've seen before, or something similar. I think you've got a bad connection on the neutral wire. Either in the plug or at the panel. Have electrician check the neutral wire back to the panel from the plug.
Jul 25, 2009 | Dryers
Separating a washer dryer combo
This is a one piece unit. It does not come apart. Use and appliance hand truck with straps to secure. You will need at least 2 people to get unit out, heavy. I used to deliver appliances.
Jul 03, 2009 | Frigidaire FEX831CS Top Load Stacked...
Hook up a 9 inch halient for model no. JBP78W0B2WW
Dear Friend,
ngfam1 at your service
I am happy to assist you!!!
Discount Parts
Major Appliance & Consumer Electronic Parts. TOLL FREE 1-(888)-338-3790 8:00AM - 12:00 MIDNIGHT 7- DAYS A WEEK NEXT DAY DELIVERY IF IN STOCK!
Here is the service company I refer my appliance customers too!
A&E Factory Service
A Nation Wide Company. / Available 24 / 7 for arranging appointments! In the USA.
1(800) 905-9505
If this dryer is 10 years old or more do not spend any money on it!
The new ones are much more efficient! If you have to replace it buy a Speed Queen , it will do 8 loads a week for 25 years!
It's the last washer and dryer I will ever buy!!!! And less expensive than a top of the line unit!
You will be fine now!
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Aug 28, 2008 | GE Kitchen Ranges
Cooling fan
Dear Friend,
Discount Parts
A&E Factory Service
1(800) 905-9505
Bless you,ngfam1
Aug 28, 2008 | Smeg SUK61MFX Gas Kitchen Range
Baumatic in wall oven fan working but not heating and light has blown in powercut
Dear Friend,
Discount Parts
A&E Factory Service
1(800) 905-9505
Bless you,ngfam1
Aug 28, 2008 | Kitchen Ranges
Heating element
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
Roper is owned by Electrolux. Call them and get the wiring chart!
or Frigidaire.com too!
OR
A&E Factory Service
1(800) 905-9505
Thank You
Bless you,ngfam1
Aug 09, 2008 | Roper REX4634KQ Electric Dryer
Whirlpool Cabrio Dryer
This problem could be that the shipping parts/bolts were not removed or may not have had all of them removed.
Also it is very important to balance the machine by using a level on the sides and or top of the machine and adjust the legs.
Feb 05, 2008 | Dryers
No Heat
Make sure that there are no kinks in the export for heat (usually a tubular plastic device that exports the evaporated water out of the machine) and that it is properly attached. If this does not work, check to make sure that you did not break a belt in the dryer. If it is old a new belt may need to be replaced. See replacement instructions if necessary.
Jan 13, 2008 | Kenmore 95087 Gas Dryer
Whirlpool 3.2 cu. ft. Plus Washer Logo
44 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
