Question about Navman F20 GPS Receiver
F20 power port connection broken in unit.
F20 power port was knocked and has come loose in the unit. I need advice in taking unit apart to reconnect if i can ,2 screws at the base have been taken out but the unit seems to be stuck at the top are there other fixings. If you could advise I would be very greatful.
Gary
  • 1 more comment
  • Anonymous Feb 11, 2009
    Dont! The same happend to mine, your F20 has a 2 year warranty and as long as you can prove you purchased it within the last 2 years you can get it repaired for free.
    They will even send you a parcel to send it out in.
    However dont make the mistake I did, I could hear it rattling inside so like you I took the screws out to see what the problem was and the usb/power port fell out (well it was obviously not attached!).
    Now they are trying to charge me £60 which is almost half the price of the unit brand new to repair it because "it was caused by user actions"
    Which is total and utter rubbish. I suggest you contact Navman immediately and let them know that lots of people have had this problem.
    Personally I think its poor design to put a power port directly on the board where it has to support constant unplugging and plugging in (lets face it you dont leave it in the car over night do you!) and soon gives in to wear and tear.
    If I dont get a satisfactory answer to my letter of complaint I will be reporting them to Wathdog and hopefully more users will come out with the same problem and the poor internal design will come to light to the general public and how poorly they treat their customers.
    Likewise you can bypass the problem by bying a traffic module as it has its own power source, I picked one up from ebay for £20 if I remember.
    I however need my f20 updated in order for the module to work and in order to upgrade I need that bloddy usb port :/ Hence my stand off with navman.
    Im glad someone else has posted saying they could not directly open the unit as this proves end user can not access the internal workings easily and they are just trying to con me out of more money.
    And why Iw ould deliberatly break my power port I dont know!
    Scam merchants to be honest. Come on navman do the honest thing.
    John
  • Anonymous Mar 03, 2009
    Same thing happened to my Navman f20. I opened it myself & could see that the power lead connection had broken away off the circuit
    board. I agree -very bad design have all that load placed on a fragile
    connector.
    Dont try & fix it yourself as it looks near impossible to solder it.
    Try to get Navman to fix it.
  • assistmypc Mar 24, 2009
    USB port broken loose and fell INTO the device....
    I work with some VERY VERY talented Maintenace men and they were able to open the case and solder the USB port back into place... HOWEVER ... there are "leads" that need to be soldered as well... this was something they could not do... all of them told me the same thing... a "human" did not solder this.. it had to be done by a machine..
    Navman want's $149.00 for repair ... I can buy a brand new GPS for $160.00 - I will NOT make the same mistake this time.... the workmanship on the Navman was substandard at best ...
    Nina Bilbrey
    Chicago Illinois
I have recently acquired a Navman F20 Satnav with a broken USB port (It was rattling around inside the unit.)
I took apart the case and re-fitted the USB port with no problems at all. Just with a steady hand and a fine tipped soldering iron. I also superglued the port in place to add extra strength.
Put it all back together, and it now charges and connects to the PC exactly as it should.
So, before you throw away a sat nav with this problem, contact me and I can fix it for you, or, alternatively I will offer to buy the broken unit from you.
My Email address is darren.lee27@ntlworld.com.
Thanks
Posted on Aug 20, 2009
  • itam Nov 25, 2010
    i had same problem with my Navman but the newer S series... pulled it all apart and found like everybody else that all the power contacts broken clean off even taking away chucks of pcb with it and realise that it was impossible to solder back on... so having nothin to lose and everythin to gain i decided to bypass the battery by cutting cables that goes from the battery to the circuit board and chopped my power supply cable of the cig lighter charger and soldered on directly. so now theres no battery and is getting power directly and so far it seems to work fine.
    it seems to even retain memory as well despite the fact i thought it would need the battery for memory retention.
Male power port is loose hard to chasrge unit
The port is female with a center pin, the male portion is on the charger.
If you damaged this pin and it is loose you will need to replace the plug on the charger. Since these are very similar to some laptop charging ports, having a broken laptop around with same size charging port would be a bonus, or a friend with one too, but they are relatively cheap, I fix broken ones on laptops several times a year and can find a pair of them shipped for under $10 typically.
Sometimes you need to solder them on, sometimes they connect with a dongle, should be easy enough to take apart and peek inside.
Other wise, if that is beyond your expertise, does the charger have a cigarette lighter, you could likely charge it through that port, or with a trickle charger directly on the battery cables on the unit if need be.
Oct 01, 2015 | 900 Amp Jumpstarter - PKC0AZ/PKC0AZ-0
Where can i get my galaxy s charging port fixed and how would the port become loose?
If it's loose it is probably broken away from the internal circuit board. A common problem. People accidentally knock the plug sideways and they only have fragile connections.
Get a technician to resolver if possible or take to Samsung repair centre.
May 02, 2014 | Accessory Export Samsung Galaxy S i9000...
Port for car charger broken
the following advice pertains to the following magellan gps systems.
Magellan 800, 860, 2000, 2200t, 2500, 3000, 3050, 3100, 3140, 4000, 4040, 4050 and 6000t
i fix these and many other magellan gps daily so when considering my advice , please understand i do not google my solutions.
assuming your car charger is working (the little green light is on) and your magellan still wont start up after holding the power button while its plugged in for up to ten seconds and still does not start..read below
this is actually a very common problem with these magellan power ports...they are poor quality from the factory and always and i mean always fail..the new ports that you find on ebay are 100% better then the factory port.
if your able to replace that power port yourself, you can get one HERE, if not, ask the fellow that sells them for help.
due to some dubious "experts" on fixya, im not permitted to help you directly, but please follow the link above to get further help.
let me know if you need more help or info
bill
Jul 05, 2010 | Magellan Maestro 4040 GPS Receiver
I dropped my unit. It does not turn on. How can I
It depends on what got damaged when you dropped the unit. Open up the enclosure. Look for any wires that came loose. Reconnect any loose wires.
If the wires are broken, none are loose or reconnecting the wires doesn't help, you can get a new enclosure (3.5 ATA (IDE)) and put the drive in that. Alternatively, get a USB/IDE/SATA multiple drive connector (where the drive stays out in the open). Connect the drive in question to the IDE side. Then connect the usb cable for either option to the computer and see if the drive is recognized. If it is recognized then you can transfer the data. If this doesn't work, the drive itself may have been damaged. The way to get the data would involve a data recovery company taking apart the drive and reading the information directly from the platters - slow and expensive.
I hope this helps.
(please note that the power for the USB/IDE/SATA dongle should be connected before attaching the drive to the computer. In some models, it should be powered up before connecting the drive to the device to avoid a power surge during power up.)
Jun 30, 2010 | Maxtor Personal Storage 3200 (U01E200) 200...
Got a knock now it wont work
hopefully the sensor in the mic is not damaged. if it is a new mic will be needed. I would sat that you may have broken a solder connection inside the unit and you will have to take it apart to see where the problem is. hope this helps.
May 08, 2010 | Peavey PVM 22 Microphone
HOW TO REPLACE CORD BROKE INSIDE UNIT CAT TAKE IT
you know the cord is broke? and you wish to remove and replace the broken one? well it has to be opened to remove or reconnect the broken wiring. is there screws attaching the removable parts in order to get to the broken cord? recommend you locate broken wires and reconnect each wire to its color either white and black. and use electrical tape to cover each wire reconnected.
Mar 12, 2010 | Hoover Elite U5061-900 Bagged Upright...
Won't take a charge
i have these power ports and can also help repairing it for anyone thats not able to do it themselves
Mar 11, 2009 | Magellan Maestro 4040 GPS Receiver
Power and lcd
If you are comfortable with opening up your system you could order the LCD from the manu. and install the new one. As far as the power goes. you may have knocked a connector loose (easy fix) or you either cracked the circuit board or broke a solder connection. You can do a visual once you have the unit open to see which it is. Again, if you are comfortable with a solder iron then reflow the broken solder connection or take a small piece of wire and repair the broken circuit board connection. (using the wire and solder to create a new "bridge") If you are not comfortable with this and it is not a loose connection you will probably need to take it to a reputable repair shop. The manu should have a list of authorized repair shops.
Jan 12, 2008 | Nakamichi SoundSpace 5 Shelf System
Navman F20 GPS Receiver Logo
545 people viewed this question
Top Navman GPS Experts
Neil Gossage
Level 1 Expert
Are you a Navman GPS Expert? Answer questions, earn points and help others
