Question about Sebo X4 Bagged Upright Vacuum
Sebo x5 vacuum cleaner
My sebo x5 bag full light on and keeps cutting out.
cleaned out all pipes and cleaned out vacuum cleaner and filters.
still cuts out.
  • Anonymous Mar 30, 2014
    It was working fine and suddenly no power
    President:
  • 1,673 Answers
The full bag light comes on when it is getting full or a blockage in the hose or the dirt inlet by the brush roll. Other then that, there is a circuit board called the computer controller, part #5740ER and is giving you a false reading and causing a shut down.
Posted on Jun 22, 2008
What is the right bag for sebo x4
  1. First, pull out the hose, turn the unit on, check for an obstruction in the hose. (unclog and obstruction)
  2. Separate the body from power nozzle. Check for obstruction in the air hole passage.
  3. Pull and clean both filters in the unit. The inside white long carriage and the exhaust filter located above indicator panel. (nozzle body)
  4. If this is not working. think about where and how dirt is carried or passes from the front floor nozzle or through the hose.Somewhere in the unit the it is clogged. The red light censers a full bag (we know that's not the issue) or an obstruction to the normal air flow.
  5. Last Resort contact http://www.sebo.us/contact_us.aspx
  6. In closing: I've been selling and repairing vacuums for over 30 years. Of all the 5 major brands that I sell. Sebo is by far the, best product on the market.
Aug 23, 2014 | Sebo X4 Bagged Upright Vacuum
Sebo squealing
Just spend all afternoon working this one out. Take the upright section away from the bottom by pressing the release button at the bottom of the upright section. You will see two pipes. One pipe has a grill on the top. That is the problem. Mine was slightly loose which may have caused the whistling or it may not have been making a good seal with the upright section. Anyway, I took it off altogether and the noise has gone
Feb 22, 2013 | Sebo X5 Extra Bagged Upright Vacuum
Sebo Vacuum runs intermittently and keeps cutting out and restarting
There could be numerous reasons for this. What I would try in this order to help troubleshoot is this:
1. If you wiggle the power cord near where it inserts into the vacuum cleaner itself, does the vacuum turn on and off constantly? If so, you have a damaged cord or loose connections that need to be fixed.
2. Has the bag been emptied, and if the vacuum has a filter element, has this been cleaned? Vacuums may cutout if they get too hot. A vacuum can overheat if either the bag is full, the filter is blocked, or there are other obstructions to airflow, which cause the motor to work harder and draw more voltage, resulting in more heat. It may have a thermal cutoff which is tripping constantly. Solution is to ensure bag is not full, or less than 3/4 full, any air filters are cleaned and check for any other obstructions in the air flow paths.
3. Ensure the power supply is adequate for the vacuum. Try running it without long extension cords if you have been using those.
4. Check and clean the switch. Sticky or dust contacts on switches can cause variable cycling (cutting out and restarting).
Hope that helps!
Mar 11, 2011 | Sebo Automatic X1 Bagged Upright Vacuum
It just keeps saying that my bag is full and cutting out, bag not full and have tried changing it anyway, but still cutting out
I would check the air filter. It sounds like it's over heating and shutting off because it doesn't have good airflow.
Jim
Oct 05, 2010 | Sebo X4 Bagged Upright Vacuum
Bag full or clog light comes on but new bag and no blockage... Sebo x4 upright cleaner
Have you checked the filters to see if they are blocked and need cleaning/replacing. Failing that it could be the sensor at fault.
Jul 25, 2010 | Sebo X4 Bagged Upright Vacuum
Sebo upright vacuum cleaner - Bag full or clog light on constantly when using as an upright but not when using detachment pipe. Bag changed and no sign of blockage. Is this a common fault or does it need...
I have actually written an in depth trouble shooting guide on how to find the clog in your Sebo. Since this light is coming on only when you have the wand inserted into the vacuum and are vacuuming the floor, this indicates that your clog is in the bottom of the machine. The link below will explain exactly what you need to do to locate, and clear this clog.
This should be the exact fix your vacuum needs:
http://www.fixya.com/support/t4645950-bag_showing_as_full_when_new_bag_in_all
Jun 17, 2010 | Vacuums
The red light on the cleaner keeps coming on. I
It could be clogged or there is a sensor adjustment for this machine and it takes a very small screw driver to adjust it. Take it to a certifies Sebo dealer and he can fix it in just a minute.
Nov 26, 2009 | Sebo Automatic X1 Bagged Upright Vacuum
Sebo vacuum cleaner cuts out ?why
it might be the bag.just check with your local vacuum store
Jun 04, 2009 | Sebo X4 Bagged Upright Vacuum
Sebo automatic x1 -
Check the hose for a clog, also check the dirt inlet by the brush roll, it may have a clog also.
May 20, 2008 | Sebo Automatic X1 Bagged Upright Vacuum
Sebo X4 Bagged Upright Vacuum Logo
545 people viewed this question
Top Sebo Vacuums Experts
Nick Olsen
Chris Nomland
Chris Nomland
Are you a Sebo Vacuum Expert? Answer questions, earn points and help others
