Question about Datamax M-Class 4208 Thermal Label Printer
DatamaxI class 4208 top of form fault
I am having a problem with My datatmax I class 4208 printer it is printing 1 1/2 labels and says top of form fault
  • 1 more comment
  • stikkas Jul 09, 2008
    Yes, exactly same.
  • Anonymous Jul 25, 2008
    Same problem.
    Gap labels can be printed if setup printer and soft to print at Continuous media.
  • baatarsukh Dec 29, 2008
    Top of form fault
  • 155 Answers
The printer must be calibrated or the type of sensor is wrong. Verify that the sensor type is correct for your label (gap or black mark) and you can calibrate it by pressing the FEED key for about 5 seconds approximately.
Posted on Mar 13, 2009
    Problem Solver:
First thing u need to do that is to clean the media sensor, if it doesn't work than check and make sure media sensor eye is the middle of two label cutting mark (if it is gap label).i hope it solve your prob if not go for a sensor calibration.
Posted on Sep 23, 2012
SOURCE: 4208 Datamax M Class printer Problems
After changing the size of your labels the printer needs to measure the new label length. Press the feed button for four seconds (wiht new labels loaded & printhead locked down). If this doesn't fix your problem you need to correctly position the media sensor.Make sure the short white line on the media sensor is above the label gap.
Posted on Aug 21, 2007
SOURCE: I-4208 DataMax printer
I am sorry to tell ya but you have a bad Media Sensor. They are not too hard to replace once you get the part so if you are looking to do it yourself I would say it can take about 20 minutes as long as you are patient. Good Luck.
Posted on Nov 04, 2008
  • 87 Answers
SOURCE: top of form fault
You need to calibrate the printer using the instructions located in the manual. This should be in area 5.2 of the manual. If you don't have the manual you can download them at this address along with software updates and firmware updates.
Hope this helps you.
Posted on Nov 22, 2008
  • 54 Answers
SOURCE: Datamax I 4208 prints slow when set to landscape
try using a seagull sceintific driver.
also if you are sending graphics (barcode) instead of an actual barcode decoded font, the printer will process as a graphic.
If serial, speed up to max, if parallel it should print quite fast
Posted on Feb 25, 2009
  • 67 Answers
SOURCE: will not feed full length of label. display reads
You may need to take out the whole ribbon assembly by removing 3 screws. The ribbon sensor looks like a L shaped clear plastic glass.
If still not working. buy the ribbon assembly.
Posted on Nov 07, 2009
Adjusting Datamax i class
If the ribbon is moving right on the I-4208 so far that you aren't getting print on the left of your label, the typical solution is to make sure that your ribbon roll is pushed all the way in, as far as it will go (at the top center of the printer on the black hub where the ribbon and it's cardboard core slide on). Similarly, make sure that the used ribbon that is winding on to the Rewind Hub at the top front is also in (to the left) as far as it will go).
Jun 26, 2014 | Datamax DMX-I-4208 Label Printer
Why datamax M class 4208 only prints on one side of the label?
When printing on less than full width media, the printer has a printhead-leveling cam to adjust the right side of the printhead
for even pressure distribution. To adjust the leveling cam:
1. With media loaded in the printer, print a label (press the
FEED + CANCEL buttons simultaneously) and
examine it..
2. While observing the printed labels, loosen the
Thumbscrew and move it to the left most position. (see
Example 1, below).
3. Next, move the Thumbscrew to the right until the
printed labels contain a complete, even image (see
Example 2). Tighten the Thumbscrew.
Apr 30, 2014 | Datamax I-4208 Thermal Label Printer
Datamax I-Class I-4208 void
If the word "VOID" prints, turn the printer off, reboot your computer, turn the printer back on, and try printing again.
Oct 23, 2011 | Datamax I-4208 Thermal Label Printer
My printer DMX M-4208, can not print when i try to "Test Print" from the machine, could you help me to solve it
doni_s: After printing some labels, test print can not function properly. Reboot the printer and try the test print again.
Roberto Martinez
Jul 28, 2011 | Datamax M-CLASS DMX-M-4208 Label Printer
I have got a datamax m class mark II and i have got a fault top of form and i can not print anything or i can not connect to printer from my computer. i have all drivers on and i think all is fine but i...
Apr 15, 2011 | Datamax M-4208 Thermal Label Printer
The printer is datamax I 4208 give me an error top of form fault
Try moving the sliding green media guide out from the wall about 1/4 to 1/2 inch, until the white line is under the label path. This green piece holds the label sensor, which needs to be under the labels so it can sense the gap between labels (or the black mark on the bottom side of the backing, if there is no gap). Also, on the printer menu you must choose whether your stock has a gap (aka web) or black mark (aka reflective).
Oct 12, 2010 | Datamax I-4208 Thermal Label Printer
Top of Form Fault error
It means that the printer did not get a good calibration on the label. First make sure the label sensor is in the proper position. Look at the green bar that the label passes underneath and make sure that the white line (the sensor) is positioned over the label. Then calibrate by pressing and holding the FEED key for about 5 seconds until the labels start to feed. After a few labels feed out, the printer should now have a good read on the size of the label and be ready to go.
Hope that Helps !
May 14, 2010 | Datamax DMX-I-4208 Label Printer
Prints on two cards
You can modify the position in the menu.
The start position can be prgrammed in the personal settings.
Moving the paperwon't change anything because the printer will always check the top of feed
Sep 03, 2009 | Datamax I-4208 Thermal Label Printer
Top of form fault
Top of form fault - I assume you hit "Feed" button and still got the form fault... if so:
1. check paper sensor position, sometimes just 1/8" one way or the other will make a difference.
2. calibrate the printer to the stock you have loaded - calibration is EASY, just press and hold the feed button until the printer cycles 8-10 times. Let go, should say "Calibration Complete". Hit "Feed" again to see if your top of form fault is fixed.
Jun 10, 2009 | Datamax M-4208 Thermal Label Printer
Datamax I-4208 Cutter Fault
if the cutter cycles on start up up?
if not, check connector(RJ45) underneath platen assy.
I connected the I class should immediately recognize the cutter.
If it does not cut ever, check you format to see if the cutter is turned on in the driver.
I have seen some failures from wear on the bell crank that cycles the cutter.
Oct 02, 2008 | Datamax M-4208 Thermal Label Printer
Datamax M-Class 4208 Thermal Label Printer Logo
5,562 people viewed this question
Top Datamax Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Greg Cann
Greg Cann
Kevin Brown
Level 1 Expert
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
