Question about Indesit W 123 Front Load Washer
Indesit WIE 1375 error code?
Error code comes up F 04 and does not finish cycle, please help
    Genius:
  • 1,036 Answers
This is a pressure switch error.
It still thinks the machine is empty because the switch sees no pressure (simple dip tube).
But this may be as simple as a vent hose come off.
To check,
First isolate supply, then remove screws at top rear of the machine.
Slide the lid rearwards, and remove.
The small hoses should go to the drawer area, and the pressure switch will sit at the end of one of them.
If there are any rips or damage to a hose it need replacing.
Check all hoses are where they should be.
If this doesn't work, please ask here again so I can troubleshoot further.
Thanks for using Fixya!
Posted on Jun 22, 2008
My sharp phohtocopy showing call for service F2-04 after opening the cover when booting please help me with the code to fix it
F2-04- Improper cartridge (destination error, life cycle error)
Identification error
model error
type error
destination error
data abnormality
Misc error
Jul 03, 2011 | Sharp AR-275 Copier
Indesit Evolution W16s washing machine H20 error code
if there a advance cycle button push it an see if the timer will advance to spin if not turn the power off to washer an wait a couple mintue an the door will open
Apr 24, 2010 | Washing Machines
It flashes f o7 on my wie 127
hi sir, It seems that a common error code on Indesit washing machines is error code 7. This code can show itself as F 007 or with washing machines that have a rotating control dial the door lock light can flash in cycles of seven times.
This error code usually means, “heater relay stuck”.
The heater is switched on via a relay built into the main PCB. This relay is known to get jammed causing error code 7. In my experience this has usually meant a new PCB needed fitting and as the PCB comes without the main processor EEPROM chip one of those is needed also.
This repair is going to be expensive. I have heard anecdotally of engineers freeing off the jammed relay by giving it a firm tap. However, I would not expect such a repair to last as the chances are the relay would just get stuck again later on.
If a washing machine is still under the five-year parts warranty it would be cheaper to let the manufacture fit these parts but although the parts would be free the labour is going to be about £90.
kindly rate me..
thanks for using fixya..
Feb 12, 2010 | Indesit Washing Machines
Indesit DIF 04 error lights halted cycle
i have a indesit dif 04 that starts a cycle fills with water and then the lights on door start to flash,leving all the water in the bottom?
Jan 10, 2010 | Dishwashers
Indesit WIE 147 - Display 'F-03' fault
Indesit washing machine error code 3 (F03) On certain Indesit washing machines, if the on off light is flashing 3 times, with a slight pause, followed by flashing a further 3 times, or if it is didplaying F03 you have an error code that is explained as follows -
NTC fault - check Thermistor and module connections.
The NTC is the thermistor, which is a modern-day thermostat. It’s inserted into a tube in the heating element and is filled with heat sensitive crystals that change their electrical resistance according to their temperature. By knowing what electrical resistance the crystals have at given temperatures they can tell the water temperature.
With this fault the NTC is either faulty, or there’s a dodgy connection to or from it or there’s a connection problem where it connects to the main PCB.
It’s not something you can easily fault find yourself unfortunately, apart from if there was an obvious broken wire.
Feb 10, 2008 | Indesit W 123 Front Load Washer
Help
al indesit washer have a reset pattern
switch of with on/off button
turn selector to a large 'off dot' position
wait a couple of mins then switch back on
wait 2 mins
then switch off again and turn selector to a cycle start position
wait 2 mins turn back on and let it run the FULL cycle do not mess it about.
Sometimes it takes 2 or3 attempts so be patient
If there is a fault it will appear again within the cycle and give you an error code eg E7/E1 etc note this and call a repair man he will track it from this code.
Jan 26, 2008 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
291 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
