For a Hoshizaki 250 baf. after making 1 round of ice, it makes 1 beep and whole machine turns off. Then i have to turn it off and turn it back on and it repeat itself. Can it be something is wrong with the thermostat kit?
The machine, all in one, not indoor/outdoor split type, will make beeping sound when something is wrong and stops working until it is turned off and turned back on. Some times the machine needs to be reset with the power on, covers removed, reset button inside on electronic mother board. The ice machine covers have instructions and information on beeping sounds.
You have a relay or starter going bad. It definitely needs servicing. I am assuming you have called tech. I would turn it off until you get it fixed even if it is still making ice. This may indicate something is seriously wrong or about ready to shut down.
I am assuming that it has run two consecutive cycles. I would first clean the machine inside and out. it should drop ice once cleaned, if not then open up the control box and find out which lights are flashing. I am almost certain that once it is cleaned it will drop ice.
3 beeps means the machine has ran two 1 hour cycles back to back to make ice an average timeframe for ice making is 25-30 min. Could be several issues, float switch dirty, water valve leaking by, dirty spray tubes, dirty evap., then go to refrigeration Expansion valve, compressor, charge, Hot gas valve leaking by,,,,,
I don't have the details on you machine but if I were going to trouble shoot this problem, assuming its a temperature probe I would power off the machine, remove the access panel and remove the temperature probe and check it with an Ohm meter or continuity checker for proper functioning by putting the probe in ice and see if it opens electrically. Sometimes the probe is not a simple thermostat type. The bin control on some machines is optical. The ice pile breaks a light beam to turn off ice making. Sometimes the probe is a thermistor. These latter two kinds of probes have electronics connected to them. A simple ohm check will not work for these cases. You can tell what kind you have by looking at it carefully. The thermostat kind that can be checked with a continuity checker or ohm meter is a sealed metal tube. The optical type has a light source and a separate pick up sensor. The thermistor type is a very small device on the end of a pair of wires. For the optical type or the thermistor type write back for more details.
km-450mwb hoshizaki problem is machine strate is ok but to long time ice making , not dropping, two beeps every three seconds what problem i don't no pleas help mi
I have a Hoshizaki KM-250BAF that is making 3 beeps then pauses and them makes 3 beeps again. If I unplug the ice maker and plug it in it continues to make the 3 beeps. The manual does not mention anything about beeps. Can anyone help?
