Question about Hamilton Beach Stay or Go 45234 Coffee Maker
Stay or Go Carafe explosion
I was cleaning the unit as usual with vinegar and baking soda solution and
a soft plastic brush (no metal) when it just exploded. Glass shattered
inside the carafe.
Scared the dickens out of me!
  • 6 more comments
  • vryan438 Jan 01, 2009
    The same thing happened to my husband. He was rinsing the pot and just getting ready to clean it when the whole inside shattered inside the carafe and all over my kitchen sink ans counter. Why did this happen? Can I get a replacement carafe.
  • jhschuter Jan 02, 2009
    I can't believe it! The EXACT same thing happened to us yesterday. My husband was cleaning the carafe with a plastic brush, he had just filled it with water and it just exploded internally, some glass got around the sink. It scared the living daylights out of us with a loud pop. I'm in the process of looking for a replacement carafe. But after seeing others with the exact problem I'm not certain I want to stick with this brand.
  • adylordo Jan 13, 2009
    Same issue with mine - shattered when cleaning - sounded like an explosion - glass went everywhere - not even a year old.
  • jlanger Jan 23, 2009
    same issue though I got a good 2 years of service out of mine before this happened.
  • kzab Feb 14, 2009
    my husband also was cleaning and it shattered...I can seem to find where to get a replacement carafe...it's only 1 year old!
  • Anonymous Feb 27, 2009
    This is the second one I had explode while I was cleaning it. I got a replacement carafe a little over a year ago but cannot find another one now.  I was very gentle cleaning the second one with a soft brush and hot water but it went anyway. Perhaps this is why they may have stopped making them.
  • Anonymous Mar 22, 2009
    When I was cleaning my carafe it also exploded. I have been using the "go" cup and for some reason they will not filter all the coffee through and it ends up all over my counter
  • Anonymous Mar 29, 2009
    I had the same problem. The carafe exploded while cleaning.
    Has anyone found a replacement part? For now I 'm able to use a Carafe from an old maker.
5 Suggested Answers
SOURCE: Replacement coffee carafe
I have a complete Salton Three for all EX20 I'll be listing the carafes on e-bay soon.
Posted on Feb 06, 2008
SOURCE: need a replacement carafe for salton espresso maker EX-96
You can call them directly 800-947-3745. Just a note.. they wanted $21 (including shipping) for a replacement expresso carafe (4-cup) for my MEX1B model. I thought this was a bit pricy and found a generic 4-cup espresso pot at Target.com for $10. Good luck!
Posted on Aug 29, 2008
SOURCE: Replacement Carafe
Go to Kalorik.com and search under 'parts and accessories'. You'll be able to to find it there for $16.99.
They have chocolate fountains, ice makers, and waffle makers too!
Posted on Oct 28, 2008
  • 373 Answers
SOURCE: need thermal carafe for stay & go hamilton beach maker.
check walmart and see if they have them
or do you have your order sheet
try hamilton web site too
Posted on Feb 04, 2009
SOURCE: replacement carafe
Send a $15.00 check to:
Emerson Radio Corp.
Consumer Affairs Dept
9 Entin Road
PO Box 430
Parsippany, NJ 07054-0430
Tell them you need a new carafe for #CCM901 sent to your address.
Posted on May 27, 2009
How to clean coffee stains on white coffee maker
Plastic can absorb Stains, so you will need to use some kind of bleaching poduct.
some products you can try individually:
  • Baking soda
  • Bleach
  • Water
  • Vinegar
  • Rubbing alcohol
Dilute with luke warm water , except for Rubbing Alcohol
Use some kind of tray which you don't mind if it gets bleach stains to protect your countertop. put the device on the tray.
If you can't soak an item, try disconnecting the device, then wrapping a lightly soaked hand towel or paper towel over the area that is discolored
Rinse with luke warm water, and make sure device has completely dried before reconnecting.
Aug 03, 2016 | Cuisinart DCC Coffee Makers & Espresso...
Clogged and won't let coffee run
Clean it out using baking soda and water. Or a little vinegar and baking soda and see if that removes the calcium deposits. Let it soak for a while in hot water in the vinegar-baking soda mixture. Make sure you always use filtered water when you make coffee.
Mar 07, 2015 | Breville Coffee Makers & Espresso Machines
How do I santized the fresh water tank in my raptor 365 LEV
You might as well sanitize the whole unit. Fill the carafe half with water, half with "cleaning vinegar." Run several brew cycles, pouring the hot vinegar-water mix back into the reservoir. Then empty the carafe, and fill it with fresh water, and run several brew cycles to rinse out all traces of vinegar.
I suppose you could use white vinegar, but the cleaning vinegar has a higher acidity.
Oct 06, 2014 | Coffee Makers & Espresso Machines
My 12 Cup grind and brew coffee maker needs a good cleaning. How do I do it?
To clean the inside of the coffee maker, fill the reservoir with water as you would to prepare coffee, except add 2 tablespoons of vinegar to the reservoir. Place a clean filter in the basket and run the solution through. When it is complete turn off the unit and let it cool for 2 minutes and then pour the hot solution back into the reservoir for a second run, you can reuse the filter that you placed in it the first time. After it is finished this second time, turn off the unit for 2 minutes and pour the used solution down they kitchen sink. Allow the carafe to cool for a couple of minutes and fill with cold water and run it through as you did the solution, but put a clean filter in this time. Repeat this one more time to remove the vinegar solution and discard the used filters. Once the carafe is cooled fill it about 1/3 full of water, add several ice cubes and 1 tablespoon of baking soda swirl this around in the carafe for a minute or so. Rinse the carafe and run it and the basket through a cycle in the dishwasher or wash by hand with warm soapy water. Rinse thoroughly and you're done. Good luck.
Aug 28, 2013 | Cuisinart Grind and Brew 10 Cup Coffee...
I have my Mom's 193909WB coffeemaker, It runs like a top! How do I clean it?
Here are the cleaning instructions directly from West Bend's instruction manual. Good luck!
Cleaning Instructions
1. Unplug coffeemaker and allow to cool before cleaning.
2. Clean basket, stem and cover in hot soapy water with a dishcloth, rinse and dry. Coffee stains on underside of cover or stem may be removed by scouring with a damp cloth and a non-abrasive cleanser.
3. Clean inside of coffeemaker by filling with hot water until about one-third full. Add small amount of liquid dishwasher detergent and wash with a dishcloth or sponge. Then clean the heating unit well (where stem fits) with a scouring pad, to remove coffee residue. Twist pad inside heating unit well to clean thoroughly. IMPORTANT: If heating unit well is not kept clean, coffeemaker will not perform properly.
4. After cleaning inside of coffeemaker, drain and rinse inside. Clean faucet by letting clear water run through it into sink, while moving faucet handle up and down. Drain water from inside of coffeemaker and dry.
5. Clean outside of coffeemaker with a damp cloth and dry with a soft cloth. Do not use abrasive metal scouring pads or cleansers on outside of coffeemaker as scratching will occur.
DO NOT WASH COFFEEMAKER PARTS IN AN AUTOMATIC DISHWASHER.
Special Cleaning Instructions
To Remove Mineral Deposits: If coffeemaker is used daily, a special cleaning every 2 weeks OR every week if used for heating water, is necessary. Fill coffeemaker with 1 quart each of water and white distilled vinegar. (If a white mineral buildup has formed on inside of coffeemaker, use an additional 2 cups of vinegar.) Place stem and empty coffee basket in place, secure cover onto coffeemaker and plug in. Allow coffeemaker to complete perking cycle, then let stand for 10 to 15 minutes. Unplug and drain coffeemaker. Allow to cool and follow general cleaning instructions.
To Remove Discoloration: Inside of the coffeemaker can discolor when used for heating water, which is normal. To remove/lighten discoloration, fill coffeemaker with water to the level of discoloration (at least to the 12 cup level, but not past maximum cup level). Place stem and empty basket in place. For every 12 cups of water added to coffeemaker, add 2 teaspoons cream of tartar to basket. Secure cover onto coffeemaker, plug cord into coffemaker and then into outlet and allow coffeemaker to complete perk cycle. Let stand for 15 to 20 minutes or until discoloration is lightened. Unplug cord and drain coffeemaker. Allow to cool and follow general cleaning instructions.
Do not use baking soda to clean coffeemaker, as it will discolor inside metal.
After frequent use, coffee residue may collect inside faucet. To clean, unscrew top half of faucet. Move a small brush up and down through faucet. Insert brush through opening inside coffeemaker to clean faucet connection. Rinse and replace top half of faucet.
Jan 11, 2011 | West Bend (58036) 36-Cup Coffee Maker
I lost my manual and don't know how to clean the machine. I have hard water so there are deposits near the water tank.
Instructions vary a bit according to machine, but a safe bet is to use a mix of 1/3 white vinegar to 2/3 water. If you are uncertain, you can always type the name or model number for the coffeemaker into a search engine along with the words "owner's manual" or "user guide" or words to that effect. The other option is to visit the manufacturer website. There should be a search box or a "support" section of the website where you can look up your coffeemaker and view a PDF of the owner's guide (the PDF will either download to your desktop or open in your web browser).
In general:
1) Put the filter basket in place and set the machine up as if you were going to brew coffee. 2) If there is a charcoal water purification filter in the machine, take it out.* 3) Run the aforementioned vinegar solution through as if you were brewing coffee. (Just hit the brew button after adding at least 6 carafe cups of diluted white vinegar.) 4) Wait about 10-15 minutes to let the machine cool down and then "brew" the vinegar solution through again if it has been a long while and the deposits are particularly severe. (Note: Some owner's manual will have you pour the vinegar that is in your carafe back into the water tank and run it again, and others will call for you to discard the first batch and brew through a fresh solution.) 5) Follow the same instructions as written above but this time with a full carafe of fresh water (no vinegar). Repeat 2-3 times to rinse out the vinegar odor/taste. 6) To clean your carafe use hot water, baking soda and vinegar. Place the carafe in the sink, fill with hot water, pour in some baking soda and add in a 1/4 cup or so of white vinegar. The foaming action will help release stains and stale coffee odors. If the stains are particularly severe, dissolve a tablespoon or so of liquid dishwasher detergent in extremely hot water — be careful! — and pour it into the carafe. Let it soak for an hour or overnight and rinse with hot water about 4-6 times to make sure the solution is entirely rinsed out.
* Tip: If your coffeemaker has a water purification filter, do not reinstall after cleaning your machine if you can't recall the last time you replaced it. A worn out charcoal filter cannot be cleaned, may slow down the brew speed or make the coffee taste "off". The only option is to remove or replace it with a fresh water filter. This is only applicable if your coffeemaker came with a charcoal water filter. If present, you will typically find it inside the water tank inside a plastic holder of some sort.
Mar 05, 2010 | Starbucks Barista Quattro Coffee Maker
Coffee leaks all over the counter every time coffee is made. coffee appears to be coming out of bottom of machine Coffee pot lid is on correctly.
I had this problem after about a year of use. The thermal carafe lid had become clogged enough with coffee sludge (fine grounds/oil) and hard water deposits to slow the flow through the lid. I soaked the lid in a bowl of 2 cups hot soapy water + 2/3 cup white vinegar for a few hours, agitating the lid in the mixture every 1/2 hour or so.
Then, I rinsed the lid and packed baking soda in every opening and dropped it back into the mixture - hoping the fizzing action of the baking soda+vinegar would help loosen any remaining sludge.
I rinsed it again, and whacked it against the side of the sink for a final effort to loosen sludge. Repeated the baking soda + rinse + whacking a couple of times. No more problems.
In the future, I plan to do the soak at every Cleaning cycle/every couple of months.
Or, if you don't want to deal with it, replacement thermal carafe lids are available from Cuisinart for $6 + shipping.
Jul 29, 2009 | Cuisinart DCC-1200 Coffee Maker
Inside of the carafe
The only thing that work well for me was Dishwasher liquid. put a litle in the pot with some real hot water, put the lid on and swirl for a minute, being careful not to spill. Then place in the maker filled with just enough water to fill the pot the rest of the way. Then shake and swirl over the sink, being very careful not to get that very hot water on you. You may have to do this twice. You will be surprized with all the junk that come out. Then rinse it a lot. Then I place vinegar and baking soda in the bottom and run it through the cycle twice . Very clean and fresh and the coffee tastes great. A lot of work though.
Apr 06, 2009 | Cuisinart DTC-975 Coffee Maker
Lasting plastic smell
Obviously, this should not be! First, we need to know if the coffee maker is working correctly. If you have a candy/oven thermometer, check the output temp of the water. Be careful...it will be hot! The correct temp should be about 180-185 degrees. If it is hotter than that...return the machine. It has a defective thermostat.
What you can do about the taste: try taking some baking soda and mix it with the feed water. Use about 2 tablespoons in at least two cups of water. Then, add plain water. The baking soda can't hurt you but throw it away and clean the pot. Now, take some water and run it through. If the taste is gone...enjoy! If not, try another unit.
Nov 20, 2007 | KitchenAid Pro Line Coffeemaker Coffee...
Rust on magnet
You may be able to clean up the magnet with a bit of vinegar and an old tooth brush. Make sure to leave the tank open to the air at all other times. Be sure to rinse the tank with a baking soda and water solution to get the taste of the vinegar out of there.
Oct 29, 2007 | Gaggia Titanium Espresso Machine
Hamilton Beach Stay or Go 45234 Coffee Maker Logo
98 people viewed this question
Top Hamilton Beach Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
joecoolvette
joecoolvette
Are you a Hamilton Beach Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
