Question about E-Machines eMachines Desktop PC
Emachines desktop model T2899
My computer shuts off without warning. It can happen within a 5 to 60 minute time frame from turn on. Any ideas why?
    President:
  • E-Machines Master
  • 1,314 Answers
This problem can be any number of issues.
1. Heat. Make sure the air vents on the tower are free from dirt and debris. Open the side up and, using a can of air found in most electronic departments at stores, blow off the dust on the fan and heatsink which resides on top of the CPU. Also blow out as much dust as you can. If your computer is fairly dusty then this should solve your problem, if not check out the other things.
2. Power supply. Sometimes when a power supply begins to fail, it doesn't put out enough voltage to the various devices inside your PC when under load. Swap out the power supply with one from a know working system to verify.
3. Memory. Remove and reseat the memory chips inside the computer. Download a program like memtest to run checks on your memory.
4. Hard Drive. Sometimes when a hard drive begins to fail, it loses valuable windows files. The computer chugs along up until a point it looks for a file then it kills the system.
Based on the issue you described, I believe it to be a heat issue as the computer is designed to automatically shut down if the CPU reaches a critical temperature to protect the internal components.
Posted on Jun 22, 2008
Retail drivers xp
http://support.gateway.com/us/en/emac/product/default.aspx?tab=1&modelId=1537
Or is there something I'm missing by the reference - Retail?
All the drivers I pulled up are XPx86.
Means XP and 32-bit version.
What drivers do you need? Post back in a Comment.
The eMachines T2899 Desktop PC uses an FIC AU31 motherboard.
(First International Computers)
Also known as the K7M-NF18G.
This is the download link to the motherboard manual,
http://www.elhvb.com/mboards/OEM/eMachines/manuals/index.html
Click on the blue - FIC AU31 - in the left column.
Regards,
joecoolvette
Dec 16, 2012 | E-Machines T2899 PC Desktop
I have an Emachine W6409 Desktop, it was turned off(proper shut down) after an hour or so, pressed the on button, nothing happened, power supply was replaced, attempted to turn on and again nothing...
It sounds like you dont have the motherboard/case wiring input properly, without a specific diagram of your computer, i cant really tell you what to plug in, but your computer could have come with the correct wiring guide.
Feb 05, 2011 | E-Machines eMachines Desktop PC
My computerjust Shut Downs And When I turnn It On It Says A Problem Happen!(overheating!) What Should I Do For This cant happen No More??
Overheating - as the warning says.
Open the case and clean the inside, check the fans and add extra ones and, as a last resort, use the pc without the side panel to have a better cooling.
May 10, 2010 | eMachines T5048 PC Desktop
Can't restore emachine
Telephone eMachines, and order a replacement "System Recovery" set of CDs. Given the serial-number and model-number of your computer, they know what O.S. originally was factory-shipped with your computer, and they will replace that part.
Probably, a small fee for courier-shipping.
Feb 03, 2010 | eMachines T3604 PC Desktop
CD drive not working
Based on your indication the CD drive is clean, and you know the cables are attached to it, inside the computer. (Flat ribbon IDE interface cable, and 4-pin Molex connector power cable)
1.Go to Device Manager
Left-click on Start. Right-click on My Computer. Go down, and Left-click on Properties. Left-click on the Hardware tab. Go down, and Left-click on Device Manager.
Left-click on the + sign to the left of, DVD/CD-ROM drives.
Right-click right on the name of the CD drive.
(Example: Lite On DVDRW LH-20A1P.
eMachines Support indicates the T5212 has a DVD burner drive, and a CD drive. Right-click on the CD drive name))
In the drop down list, Left-click on Properties.
Left-click on the Driver tab
Go below, and Left-click on the Update Driver 'button'. Now go below, and Left-click on OK.
Close all windows, go back to your desktop screen.
Shut your computer down normally. (Start>Turn Off Computer>Shut Down)
Do Not Restart. We need a 'Hard Shut Down'.
Wait 1 minute, turn your computer on.
Still doesn't work?
Let's play hard ball.
2.Go back to Device Manager. Left-click on the + sign to the left of DVD/CD-ROM drives. Right-click on the name of the CD drive. Left-click on Properties. Left-click on the Driver tab.
This time go down, and Left-click on the Uninstall 'button'. Go below, and Left-click on OK
There will be a Microsoft 'squawk box' that comes up. "Warning you are about to uninstall this device"
Left-click on OK. (It IS okay!)
Close all windows. Shut down your computer normally. (Again, we need a 'Hard Shut Down'. To Restart a computer is known as a 'Soft Shut Down')
Wait 1 minute. Turn your computer on.
After Windows loads all the way, and all of your Start Menu programs have loaded, you should see a pop-up out of your system tray. (Bottom of Windows desktop screen)
"Found New Hardware", and perhaps another one, "Found XYZ CD drive". (XYZ = the CD drive name)
No still?
The driver for your CD drive, is located within the Windows XP operating system on your computer.
If your CD drive does not work now, I suggest it has failed.
Drives such as Optical drives, and Harddrives, are mechanical devices. Their 'Lifespan', is rated in so many hours of usage. Your CD drive may be at the end of it's 'Lifespan'.
Oct 04, 2009 | Sony VAIO PCV-RX462DS PC Desktop
Emachines w2828 keeps shutting down reboot/Screen Freeze
I dont thing this is a virus problem but a heat problem. if you dont mind getting inside the box see how clean it is and put your hand on the power box case .. then unplug all the hardware except the mother board then turn the unit on, if it goes on then plug 1 hardware at a time.
Sep 04, 2009 | E-Machines eMachines Desktop PC
The PSU fan does not run, computer shutsdown.
Check the CPU fan, it may be faulty and causes the CPU to overheat and shut down.
Sep 02, 2009 | E-Machines eMachines Desktop PC
Emachines t2899 will come on and fans run but screen is still blank
Actually, the monitor is fine. The problem is that the computer isn't booting. The power comes on and the fans spin, but the system board isn't starting. Try reseating the memory modules in their sockets and clearing the CMOS memory using the jumper on the system board. If the problem continues, try another power supply. Finally you may need to replace the system board.
May 13, 2009 | E-Machines T2899 PC Desktop
AcerPower 1000 keeps shutting down
you mean the computer power off automaticaly.
check the all cable of mother board.
Jan 21, 2009 | AcerPower Sn PC Desktop
T2899 emachine startup cd needed ill pay$$$
what you need is to reinstall windows not a start up cd any win xp cd will do
Jan 11, 2009 | E-Machines T2899 PC Desktop
E-Machines eMachines Desktop PC Logo
88 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
